› UKTH forums › Wireless Routers & Modems › ASUS & Wireless › Advice needed on what ASUS router (or other) Continuation of discussion from DSL-AX82U thread. Main points below: So my family have somehow been able to get along ok in a 3 story house with something as simple as...
- This topic has 85 replies, 4 voices, and was last updated 3 years, 8 months ago by
February 11, 2023 at 5:57 pm #22753
I can plug back in my DSL-AX82U next week, currently have my Netgear XR500 in for my Son’s gaming over the weekend etc.
What are you looking at in particular from my testing and a schedule would be handy ?
(P.S. I did mention earlier, QoS is a huge subject)
February 11, 2023 at 6:54 pm #22754No rush on it, thanks. I think basic test would be something like have cake installed on latest gnuton then:
1: Run waveform test with nothing active to make sure latency and jitter is fine.
2: Set something to download at around 60% of your total bandwidth. Helps if it’s like 10GB+ so you have time to test.
3: Run waveform again and check latency/jitter.
Ideally step 3 waveform should show all ticks even for low latency gaming.
February 11, 2023 at 7:03 pm #22755February 11, 2023 at 9:25 pm #22756You weren’t kidding about QoS being a complex subject. Another deep hole emerges…
I just decided to try downloading a Linux ISO from here in Chrome: https://ubuntu.com/download/desktop
This was with 0 throttling or anything: https://www.waveform.com/tools/bufferbloat?test-id=5276cd72-fed1-413d-80ac-bc630a04784e
Wtf… explain that. I then thought to myself maybe something is wrong with the Blizzard launcher downloader. So now I left blizzard completely unthrottled: https://www.waveform.com/tools/bufferbloat?test-id=365a5fff-e53e-46f2-b505-3deddb1f3e52
I don’t know how I failed low latency. Everything looks fine. I can only assume that the download speed is too slow to get the tick? Jitter looks more than adequate now.
Now I did what I did before… I set blizzard launcher to 20Mbps limit: https://www.waveform.com/tools/bufferbloat?test-id=7b47acc8-eede-4d03-9252-4dfb6ef4ed4d
The jitter issue came back. Now I set it to 10Mbps limit: https://www.waveform.com/tools/bufferbloat?test-id=53f75547-42bc-4708-98a1-22cfeb304b79
I got the low latency tick on the left, backs up the theory it’s about download speed. I still got the increased jitter issue.
So if I understand this correctly… you should not actually use a rate limiter on any type of traffic. It just leads to worse performance… I don’t know how but take it as you get it I guess.
Edit: Yip just checked waveform FAQ section. I did not get the tick because I was less than 10 Mbps (was at 8.31 Mbps):
So if I don’t limit anything it seems… fixed. I would still be very curious to see your results.
February 12, 2023 at 3:43 am #22764February 13, 2023 at 2:43 pm #22769Ok, so I plugged back in my DSL-AX82u and configured CAKE QoS as per you guidelines.
WAN packet overhead = 34
MPU = 68
I firstly ran the Waveform bufferbloat test with no known traffic, results below.
https://www.waveform.com/tools/bufferbloat?test-id=384bfb56-aa7d-46df-90d3-63571d7e8041
Then I downloaded a large file and whilst it was downloading, I then ran a Waveform bufferbloat test again.
https://www.waveform.com/tools/bufferbloat?test-id=55567e73-bd92-49b2-a7c4-1cae695fc38f
February 13, 2023 at 4:53 pm #22773Yeah that’s running as expected so far. Can you run a rate limited download in say qbittorrent (set it to max 20Mbps or so) and then run another waveform as it downloads? Blizzard download also a good test:
February 13, 2023 at 5:41 pm #22774February 13, 2023 at 6:25 pm #22775It’s actually pretty ridiuclous that browsers don’t have easy bandwidh controls for stuff like this.
The easiest thing to do would be get a linux fedora torrent: https://torrent.fedoraproject.org/
The top torrent works fine and should easily do what is needed (Fedora Astronomy_KDE Live x86_64 37). It’s 4.5GB so enough time to test.
In qbittorrent go to Tools > Options > Speed
Then run waveform.
February 13, 2023 at 6:37 pm #22776[quote quote=22775]It’s actually pretty ridiuclous that browsers don’t have easy bandwidh controls for stuff like this.[/quote]
That would be nice, have no dirty laptop to install a torrenting client.
February 13, 2023 at 6:44 pm #22777You can run on the same computer if that’s easier. I did the testing and it’s the same on one computer as it is on another one running the torrents/waveform.
February 13, 2023 at 7:09 pm #22778Not putting anything like that on my Desktops or Laptops etc, sorry.
Edit; would Network Throttling in Chrome be an option ?
https://www.debugbear.com/blog/chrome-devtools-network-throttling
February 13, 2023 at 8:30 pm #22780I tried that but I can’t get it to work at all. I set a 10Mbps limit and it just blazes at max speed anyway. If you can by all means try.
Also qbittorrent is open source and very trusted. It’s even featured in the very popular ninite installer along with 7-Zip etc: https://ninite.com/
I think torrent clients get a bad name because of their links to piracy but most use is very legitimate e.g. downloading a version of linux where each piece gets checksummed to make sure you get the actual file. Ofcourse you have your choice.
February 13, 2023 at 9:00 pm #22781So via Chrome, using Dev Chrome Tools, I set throttle download limit to 10Mbps and downloaded a file, then using Edge browser I ran the waveform test.
https://www.waveform.com/tools/bufferbloat?test-id=41459070-b377-428c-981c-4c488585d9ec
February 14, 2023 at 2:18 am #22782I will see if I can get chrome rate limit to work my end but even if not it doesn’t matter. Just gonna run everything non rate limited anyway.
I do actually wonder how much throughput this router can do under cake though and still be reliable. On my connection I’m seeing peaks around 50-60% on core 1 (the core actually doing the cake stuff).
If you have around 70 Mbps dowload once shaped via cake, how is your cpu peaks? I’m guessing around 80%?
