help needed with asus tuf ax4200 Hi i have the asus tuf ax4200 would like to use it as a replacement for my eero6+ router supplied by giffgaff on a 500 mbps plan. signal slows to…
› UKTH forums › Wireless Routers & Modems › ASUS & Wireless › help needed with asus tuf ax4200 Hi i have the asus tuf ax4200 would like to use it as a replacement for my eero6+ router supplied by giffgaff on a 500 mbps plan. signal slows to...
Viewing 3 posts - 16 through 18 (of 18 total)
  • #42802
    Avatarreptile11
    • Replies 10
    Ok completed but message
    Connected but no internet access
    #42803
    Avatarreptile11
    • Replies 10
    oops something i missed maybe
    #42804
    Interesting, as connected to Internet I believe means VLAN 911 is working.
    • ONT needs rebooting after swapping routers
    • VLAN 911 isn’t applied
    • WAN type is wrong (not Automatic IP)
    If above has been applied correctly, switch off you ONT and Router for half an hour and then power back on your ONT first and then your Router so its receives a new IP address (DHCP).
    If this doesn’t work, can you show me or detail the IPTV settings page on your TUF AX4200 and if WAN type has been set to Automatic IP.
