ASUS DSL-AX82U IPv6 Issue Current FW Version : 3.0.0.4.388_22048-gf313579 When I activate IPv6, the device does not detect the Internet presence and blocks the internet access of other devices (DHCP passive access point). The…
› UKTH forums › Wireless Routers & Modems › ASUS & Wireless › ASUS DSL-AX82U IPv6 Issue Current FW Version : 3.0.0.4.388_22048-gf313579 When I activate IPv6, the device does not detect the Internet presence and blocks the internet access of other devices (DHCP passive access point). The...
Viewing 15 posts - 1 through 15 (of 68 total)
  • #22120
    Black Bird
    • Replies 146
    The settings that worked before were adjusted again in the same way, but they failed.
    IPv6
    Basic Config > WAN Selection >WAN
    Connection type > Passthrough
    Interface > PPP
    WAN > Dual WAN > Auto Network Detection > Detect Interval Every 8 seconds
    #22115
    Avatarvitt13
    • Replies 45
    [quote quote=22110]I set it up again by taking it to the factory settings, there is a problem.[/quote]
    Do you really need “Dual WAN” ?
    here is my settings:
    Avatarvitt13
    • Replies 45
    I’ve just activated IPv6, all is working fine, connection shows as connected no issues,
    by the way, I have a direct DSL connection (VDSL),
    my advice is keep IPv6 deactivated, it brings more problems in my view
    • Replies 8,738
    If IPv6 is enabled on your DSL-AX82U – if you use a windows PC, go to CMD and type IPCONFIG
    What are the results ? (block out first two octets)  etc.
    #22132
    Black Bird
    • Replies 146
    I barely got this print out because of the constant presence and absence.
    • Replies 8,738
    All you IPv6 screen dumps look good, do you need DUAL WAN, if not as @Vitt13 said, disable it to see if the bug is the DUAL WAN setting ?
    #22139
    Black Bird
    • Replies 146
    [quote quote=22136]All you IPv6 screen dumps look good, do you need DUAL WAN, if not as @Vitt13 said, disable it to see if the bug is the DUAL WAN setting ?[/quote]
    No, I don’t normally use it, the last time I reset it I turned on to set up WAN (because this is a modem, DSL is the default). This issue persists when Dual WAN is off. It’s constantly taking IP and releasing it.
    last night modem log
    Dec 31 00:39:49 pppd[9546]: Connect: ppp0 <–> wan0
    Dec 31 00:39:50 pppd[9546]: PAP authentication succeeded
    Dec 31 00:40:31 WAN(0) Connection: WAN(0) link down.
    Dec 31 00:40:38 pppd[11074]: Connect: ppp0 <–> wan0
    Dec 31 00:40:39 pppd[11074]: PAP authentication succeeded
    Dec 31 00:41:19 WAN(0) Connection: WAN(0) link down.
    Dec 31 00:41:28 pppd[12502]: Connect: ppp0 <–> wan0
    Dec 31 00:41:29 pppd[12502]: PAP authentication succeeded
    current modem log
    Dec 31 18:19:38 WAN Connection: WAN was restored.
    Dec 31 18:20:05 WAN Connection: Fail to connect with some issues.
    Dec 31 18:24:13 WAN Connection: WAN was restored.
    Dec 31 18:24:41 WAN Connection: Fail to connect with some issues.
    Dec 31 18:27:00 WAN Connection: WAN was restored.
    Dec 31 18:27:27 WAN Connection: Fail to connect with some issues.
    Dec 31 18:28:06 WAN Connection: WAN was restored.
    Dec 31 18:28:34 WAN Connection: Fail to connect with some issues.
    Dec 31 18:29:01 WAN Connection: WAN was restored.
    #22142
    • Replies 8,738
    After disabling Dual WAN, reboot rooter and see if that helps.
    Is there any logs that suggest a problem ?
    #22145
    Black Bird
    • Replies 146
    The status has not changed, more modem logs are as follows. I replaced the special parts with ff)
    May 5 08:05:41 pppd[1861]: PAP authentication succeeded
    May 5 08:05:41 pppd[1861]: peer from calling number ff:ff:ff:ff:ff:ff authorized
    May 5 08:05:41 pppd[1861]: local LL address fe80::ffff:ffff:c006:83fc
    May 5 08:05:41 pppd[1861]: remote LL address fe80::ffff:ffff:fe0d:bfc0
    May 5 08:05:41 pppd[1861]: local IP address 100.82.178.86
    May 5 08:05:41 pppd[1861]: remote IP address 172.17.1.250
    May 5 08:05:41 pppd[1861]: primary DNS address 193.192.98.8
    May 5 08:05:41 pppd[1861]: secondary DNS address 212.154.100.18
    May 5 08:05:41 rc_service: ipv6-up 2006:notify_rc start_rdisc6
    May 5 08:05:41 rc_service: ipv6-up 2006:notify_rc start_dhcp6c
    May 5 08:05:41 rc_service: waitting “start_rdisc6” via ipv6-up …
    May 5 08:05:41 miniupnpd[1749]: SendNATPMPPublicAddressChangeNotification: cannot get public IP address, stopping
    May 5 08:05:41 wan: finish adding multi routes
    May 5 08:05:42 miniupnpd[1749]: shutting down MiniUPnPd
    May 5 08:05:42 miniupnpd: it is advised to use network interface name instead of 10.1.1.1/255.255.255.0
    May 5 08:05:42 miniupnpd[2058]: HTTP listening on port 35093
    May 5 08:05:42 roamast: ROAMING Start…
    May 5 08:05:42 rc_service: ip-up 2009:notify_rc start_tr
    May 5 08:05:42 miniupnpd[2058]: Listening for NAT-PMP/PCP traffic on port 5351
    May 5 08:05:42 TR-069 agent: version match
    May 5 08:05:43 usb: USB ntfs fs at /dev/sda mounted on /tmp/mnt/ffff.
    May 5 08:05:43 asusware: umount partition /dev/sda…
    May 5 08:05:43 disk monitor: unmount partition
    May 5 08:05:43 hotplug: USB partition unmounted from /tmp/mnt/ffff
    May 5 08:05:43 asusware: Automatically scan partition /dev/sda…
    May 5 08:05:43 disk monitor: scan partition
    May 5 08:05:44 asusware: re-mount partition /dev/sda…
    May 5 08:05:44 disk monitor: re-mount partition
    May 5 08:05:44 usb: USB ntfs fs at /dev/sda mounted on /tmp/mnt/ffff.
    May 5 08:05:44 asusware: done.
    May 5 08:05:44 disk monitor: done
    May 5 08:05:49 kernel: [ 61.361936] SHN Release Version: 2.0.2 d2ff630
    May 5 08:05:49 kernel: [ 61.366428] UDB Core Version: 0.2.20
    May 5 08:05:49 kernel: [ 61.390387] sizeof forward pkt param = 192
    May 5 08:05:49 BWDPI: fun bitmap = 43f
    May 5 08:05:55 transmission-daemon[3520]: UDP Failed to set receive buffer: requested 4194304, got 1048576 (tr-udp.c:84)
    May 5 08:05:56 miniupnpd[2058]: shutting down MiniUPnPd
    May 5 08:05:56 kernel: [ 68.823499] CPU: 1 PID: 3537 Comm: dm2_amuled Tainted: P O 4.1.52 #4
    May 5 08:05:56 kernel: [ 68.831047] Hardware name: Generic DT based system
    May 5 08:05:56 kernel: [ 68.835866] task: cccfc400 ti: cd8ca000 task.ti: cd8ca000
    May 5 08:05:56 kernel: [ 68.841313] PC is at 0xb6baf5c8
    May 5 08:05:56 kernel: [ 68.844466] LR is at 0x6
    May 5 08:05:56 kernel: [ 68.847007] pc : [<b6baf5c8>] lr : [<00000006>] psr: 20000010
    May 5 08:05:56 kernel: [ 68.847007] sp : b6a60840 ip : 00000dd1 fp : 00289464
    May 5 08:05:56 kernel: [ 68.858506] r10: 00289464 r9 : b6a60c80 r8 : 00000000
    May 5 08:05:56 kernel: [ 68.863741] r7 : 0000010c r6 : 00000001 r5 : 01d9f7c0 r4 : b6bf51dc
    May 5 08:05:56 kernel: [ 68.870293] r3 : b6a69950 r2 : 00000006 r1 : 00000dd1 r0 : 00000000
    May 5 08:05:56 kernel: [ 68.876873] Flags: nzCv IRQs on FIQs on Mode USER_32 ISA ARM Segment user
    May 5 08:05:56 kernel: [ 68.884177] Control: 10c5387d Table: 0b43804a DAC: 00000015
    May 5 08:05:56 kernel: [ 68.889970] CPU: 1 PID: 3537 Comm: dm2_amuled Tainted: P O 4.1.52 #4
    May 5 08:05:56 kernel: [ 68.897463] Hardware name: Generic DT based system
    May 5 08:05:56 kernel: [ 68.902298] [<c00270a0>] (unwind_backtrace) from [<c0022cf8>] (show_stack+0x10/0x14)
    May 5 08:05:56 kernel: [ 68.910072] [<c0022cf8>] (show_stack) from [<c045551c>] (dump_stack+0x8c/0xa0)
    May 5 08:05:56 kernel: [ 68.917325] [<c045551c>] (dump_stack) from [<c003acf0>] (get_signal+0x490/0x558)
    May 5 08:05:56 kernel: [ 68.924750] [<c003acf0>] (get_signal) from [<c0022290>] (do_signal+0xc8/0x3ac)
    May 5 08:05:56 kernel: [ 68.932004] [<c0022290>] (do_signal) from [<c0022718>] (do_work_pending+0x94/0xa4)
    May 5 08:05:56 kernel: [ 68.939602] [<c0022718>] (do_work_pending) from [<c001f58c>] (work_pending+0xc/0x20)
    May 5 08:05:57 miniupnpd: it is advised to use network interface name instead of 10.1.1.1/255.255.255.0
    May 5 08:05:57 miniupnpd[3788]: HTTP listening on port 59836
    May 5 08:05:57 kernel: [ 69.865613] Archer TCP Pure ACK Enabled
    May 5 08:05:57 rc_service: ip-up 2009:notify_rc stop_samba
    May 5 08:05:57 rc_service: ip-up 2009:notify_rc start_samba
    May 5 08:05:57 rc_service: waitting “stop_samba” via ip-up …
    May 5 08:05:57 miniupnpd[3788]: Listening for NAT-PMP/PCP traffic on port 5351
    May 5 08:05:57 Samba Server: smb daemon is stopped
    May 5 08:05:58 miniupnpd[3788]: shutting down MiniUPnPd
    May 5 08:05:59 Samba Server: daemon is started
    May 5 08:05:59 miniupnpd: it is advised to use network interface name instead of 10.1.1.1/255.255.255.0
    May 5 08:05:59 miniupnpd[4079]: HTTP listening on port 43836
    May 5 08:06:00 miniupnpd[4079]: Listening for NAT-PMP/PCP traffic on port 5351
    May 5 08:06:01 zcip client: configured 169.254.97.144
    May 5 08:06:03 rc_service: hotplug 2160:notify_rc restart_nasapps
    May 5 08:06:03 iTunes: daemon is stoped
    May 5 08:06:03 FTP Server: daemon is stopped
    May 5 08:06:03 wsdd2[4046]: Terminated received.
    May 5 08:06:03 Samba Server: smb daemon is stopped
    May 5 08:06:04 Timemachine: daemon is stoped
    May 5 08:06:04 miniupnpd[4079]: shutting down MiniUPnPd
    May 5 08:06:04 avahi-daemon[4211]: WARNING: No NSS support for mDNS detected, consider installing nss-mdns!
    May 5 08:06:04 Samba Server: daemon is started
    May 5 08:06:04 miniupnpd: it is advised to use network interface name instead of 10.1.1.1/255.255.255.0
    May 5 08:06:04 miniupnpd[4230]: HTTP listening on port 37259
    May 5 08:06:04 miniupnpd[4230]: Listening for NAT-PMP/PCP traffic on port 5351
    May 5 08:06:05 avahi-daemon[4211]: Alias name “DSL-AX82U” successfully established.
    May 5 08:06:08 WAN Connection: WAN was restored.
    May 5 08:06:08 rc_service: wanduck 1581:notify_rc start_apps_update
    May 5 08:06:09 ntp: start NTP update
    Dec 31 18:48:54 rc_service: ntp 2046:notify_rc restart_diskmon
    Dec 31 18:48:54 disk_monitor: Finish
    Dec 31 18:48:54 disk monitor: be idle
    Dec 31 18:49:15 wlceventd: wlceventd_proc_event(530): eth5: Auth ff:ff:ff:ff:ff:ff, status: Successful (0), rssi:0
    Dec 31 18:49:15 wlceventd: wlceventd_proc_event(559): eth5: Assoc ff:ff:ff:ff:ff:ff, status: Successful (0), rssi:-44
    Dec 31 18:49:40 WAN Connection: Fail to connect with some issues.
    Dec 31 18:49:45 crond[1683]: time disparity of 2450083 minutes detected
    Dec 31 18:50:12 wlceventd: wlceventd_proc_event(530): eth6: Auth ff:ff:ff:ff:ff:ff, status: Successful (0), rssi:-57
    Dec 31 18:50:12 wlceventd: wlceventd_proc_event(540): eth6: ReAssoc ff:ff:ff:ff:ff:ff, status: Successful (0), rssi:-57
    Dec 31 18:50:47 WATCHDOG: [FAUPGRADE][auto_firmware_check:(7722)]periodic_check AM 5:46
    Dec 31 18:50:47 WATCHDOG: [FAUPGRADE][auto_firmware_check:(7761)]do webs_update
    Dec 31 18:51:08 WATCHDOG: [FAUPGRADE][auto_firmware_check:(7779)]retrieve firmware information
    Dec 31 18:51:08 WATCHDOG: [FAUPGRADE][auto_firmware_check:(7782)]user in use
    Dec 31 18:51:38 WATCHDOG: [FAUPGRADE][auto_firmware_check:(7761)]do webs_update
    Dec 31 18:51:41 WAN Connection: WAN was restored.
    Dec 31 18:51:41 rc_service: wanduck 1581:notify_rc start_apps_update
    Dec 31 18:51:44 WATCHDOG: [FAUPGRADE][auto_firmware_check:(7779)]retrieve firmware information
    Dec 31 18:51:44 WATCHDOG: [FAUPGRADE][auto_firmware_check:(7782)]user in use
    Dec 31 18:52:07 WAN Connection: Fail to connect with some issues.
    Dec 31 18:52:13 WATCHDOG: [FAUPGRADE][auto_firmware_check:(7761)]do webs_update
    Dec 31 18:52:19 WATCHDOG: [FAUPGRADE][auto_firmware_check:(7779)]retrieve firmware information
    Dec 31 18:52:19 WATCHDOG: [FAUPGRADE][auto_firmware_check:(7782)]user in use
    #22146
    • Replies 8,738
    Are you using the DSL-AX82U inbuilt modem ?
    #22147
    Black Bird
    • Replies 146
    [quote quote=22146]Are you using the DSL-AX82U inbuilt modem ?[/quote]
    I using VDSL and was transferred to FTTH (same ISP). I connected DSL-AX82U directly to ONT. I’ve been using it this way for a long time. There were no problems until the FW update.
    Note: All my account and configuration information on the same ISP is the same as VDSL (username, password and VLAN ID)
    #22150
    • Replies 8,738
    That makes sense as the log was suggesting this also
    Usually for a FTTH connection, no VLAN ID is needed, but as you live in Turkey, thet maybe different, when you switched from VDSL to FTTH, did you perform a factory reset and start again, your issues are with IPv6 and on a previous firmware version also as you mentioned earlier ?
    #22151
    Black Bird
    • Replies 146
    If I install the 3.0.0.4.386_49608 version and install it from the factory settings, IPv6 works.
    Black Bird
    • Replies 146
    I upgrade to version 9.0.0.4_388_21184-g44bd437 with the same settings, it works IPv6.
    I take the modem to the factory settings and re-install it, it works again.
    • Replies 8,738
    I understand now, does ASUS DSL-AX82U Firmware version 3.0.0.4.388_22048 IPv6 work ?
