ASUS DSL-AX82U IPv6 Issue Current FW Version : 3.0.0.4.388_22048-gf313579 When I activate IPv6, the device does not detect the Internet presence and blocks the internet access of other devices (DHCP passive access point). The…
› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › ASUS DSL-AX82U IPv6 Issue Current FW Version : 3.0.0.4.388_22048-gf313579 When I activate IPv6, the device does not detect the Internet presence and blocks the internet access of other devices (DHCP passive access point). The...
Viewing 15 posts - 31 through 45 (of 68 total)
  • #22203
    • Replies 8,687
    I had tried testing on an old ZTE modem a while ago and it worked, so I don’t think this has to do with the ISP. It’s only on Asus that it doesn’t detect the presence of the internet and it prevents it from working.
    #22204
    Black Bird
    • Replies 146
    I wanted to share the settings that are working in the interface of a different device.
    GUA: DHCPv6
    Gateway: SLAAC
    #22205
    • Replies 8,687
    I wanted to share the settings that are working in the interface of a different device. GUA: DHCPv6 Gateway: SLAAC
    Thank you, I will share this with ASUS also
    #22206
    Black Bird
    • Replies 146
    Please turn off “Network Monitoring > DNS Query” first.
    Sam suggested this and solved the problem
    • Replies 8,687
    Glad Sam was able to advise – Do you know if DNS Query with firmware that worked with IPv6 was also disabled?
    #22211
    Black Bird
    • Replies 146
    I wasn’t changing the default so this option was being checked.
    • Replies 8,687
    Good to know and thanks for sharing this useful information from ASUS
    Hope users on forum.turk.net will benefit from this also for IPv6
    #22215
    Black Bird
    • Replies 146
    Good to know and thanks for sharing this useful information from ASUS Hope users on forum.turk.net will benefit from this also for IPv6
    I will share this with the turknet forum and a few other places related to the modem.
    #22217
    • Replies 8,687
    Don’t forget to put in a good word for UKTechHub.com
    #22273
    • Replies 8,687
    Has disabling “Network Monitoring > DNS Query” for your DSL-AX82U fix still working for your IPv6 issue in Turkey ?
    (note: I removed a couple of our above posts as not really useful as was general chat)
    #22283
    Black Bird
    • Replies 146
    Yes, after these operations, it is still working.
    #22291
    • Replies 8,687
    Great news, thanks for letting us know
    #23148
    Black Bird
    • Replies 146
    That is interesting as the norm for PPPoE is IPv6 Native not Passthrough, but obviously a special feature with Turknet Broadband as you detailed above I will chat with ASUS and hopefully they can help >Internet Connection> WAN Connection Type set [PPPoE], please select IPv6 Connection type set [Native] https://www.asus.com/support/FAQ/113990
    You are right about this because I have been using Native mode for 2 days without any problems. As a result of the backup restore (I had reset the device while shooting a narration video) the already selected Passthrough WAN did not receive the IP. For a change, I switched to Native mode and noticed that it started working. I haven’t changed it for 2 days and it continues to work.
    The inconsistent way of working is caused by FW, it has absolutely nothing to do with operator support.
    #23259
    • Replies 8,687
    Good to know and thanks for the update
    “shooting a narration video” a budding voice actor
    #23270
    Black Bird
    • Replies 146
    Good to know and thanks for the update “shooting a narration video” a budding voice actor
    silent modem setup video :)
