ASUS DSL-AX82U IPv6 Issue Current FW Version : 3.0.0.4.388_22048-gf313579 When I activate IPv6, the device does not detect the Internet presence and blocks the internet access of other devices (DHCP passive access point). The…
› UKTH forums › Wireless Routers & Modems › ASUS & Wireless › ASUS DSL-AX82U IPv6 Issue Current FW Version : 3.0.0.4.388_22048-gf313579 When I activate IPv6, the device does not detect the Internet presence and blocks the internet access of other devices (DHCP passive access point). The...
Viewing 8 posts - 61 through 68 (of 68 total)
  • #23614
    • Replies 8,738
    [quote quote=23612]Should I enter it in this field?[/quote]
    should be under ‘Account Settings’ unless your WAN Connection Type is STATIC, then it will be under Special Requirement from ISP = MTU
    #23618
    Black Bird
    • Replies 146
    [quote quote=23614]
    should be under ‘Account Settings’ unless your WAN Connection Type is STATIC, then it will be under Special Requirement from ISP = MTU[/quote]
    When I tried this, IPv6 access was lost.
    In addition, there is no IPv6 NAT option in VPN Fusion settings.
    #23620
    • Replies 8,738
    No idea, sorry
    #23622
    Black Bird
    • Replies 146
    [quote quote=23620]No idea, sorry[/quote]
    You don’t need to know that much detail. When we import the configuration file (such as wgcf-profile.conf), it doesn’t import correctly and doesn’t work properly, Asus just needs to be aware of this.
    • Replies 8,738
    Probable best to send a feedback form, just so that ASUS have a DSL-AX82U owner who has registered this problem incase they need to contact you etc.
    #23627
    Black Bird
    • Replies 146
    I did that but I will do it again later, because it seems busy right now as I received a response (or a general message) that I did not understand
    • Replies 8,738
    Yes, a general ‘automated’ initial response. hopefully the ASUS team will still look at your feedback and I will drop ASUS a message to say maybe an issues with DSL-AX82U and Wireguard leaking IPv6 address
    #23669
    Black Bird
    • Replies 146
    VPN Fusion not support IPv6 currently. So the IPv6 traffic of LAN devices will not be forwarded to VPN tunnel. No matter what kind of VPN.
    It was said that it is currently not supported, so I will not use this feature for now.
