ASUS DSL-N16 issue with l2tp vpn connection Hello.my asus dsl-n16 reboot itself when i connected to l2tp vpn connection  after few minutes please help me .
› UKTH forums › Wireless Routers & Modems › ASUS & Wireless › ASUS DSL-N16 issue with l2tp vpn connection Hello.my asus dsl-n16 reboot itself when i connected to l2tp vpn connection  after few minutes please help me .
Viewing 9 posts - 31 through 39 (of 39 total)
  • #5269
    Avatarkamiboy
    • Replies 32
    [quote quote=5240]We are still awaiting new firmware from ASUS for the MediaTeK devices, hopefully new firmware will have VPN fix [/quote]
    Me too, but a solution to this issue is to use dsl-n16 as a router only i bridge a broadcom modem to it and reboot issue fixed.
    #5451
    AvatarShadowFAX
    • Replies 4
    I have just updated to the latest firmware (1.1.2.3_790) released by ASUS yesterday and L2TP problem is still there.
    #5452
    [quote quote=5451]I have just updated to the latest firmware (1.1.2.3_790) released by ASUS yesterday and L2TP problem is still there.[/quote]
    Have you tried a factory reset, It would be good to hear from @@kamiboy as they also had issues  ?
    Edit: try a wired connection as issue via wifi was original problem ?
    See https://uktechhub.com/forums/topic/asus-dsl-n16-issue-with-wifi-show-me-password-is-incorrect/page/2/#post-4997
    #5456
    Avatarkamiboy
    • Replies 32
    Hello dears,i also updated to .790 with factory reset but l2tp problem is still there.i think next release will fix it and we have to wait.
    #5458
    [quote quote=5456]Hello dears,i also updated to .790 with factory reset but l2tp problem is still there.i think next release will fix it and we have to wait.[/quote]
    Thank you for update, hopefully next firmware will be fix for L2TP
    #5460
    AvatarShadowFAX
    • Replies 4
    [quote quote=5452]
    Have you tried a factory reset, It would be good to hear from @@kamiboy as they also had issues ? Edit: try a wired connection as issue via wifi was original problem ? See https://uktechhub.com/forums/topic/asus-dsl-n16-issue-with-wifi-show-me-password-is-incorrect/page/2/#post-4997%5B/quote%5D
    Already tried factory resetting the modem with no luck.
    The reboot happens even without any device connected via WiFi. It is only my PC connected to the modem through a Ethernet cable.
    #5461
    [quote quote=5460]
    ShadowFAX wrote: I have just updated to the latest firmware (1.1.2.3_790) released by ASUS yesterday and L2TP problem is still there. Have you tried a factory reset, It would be good to hear from @ @kamiboy as they also had issues ? Edit: try a wired connection as issue via wifi was original problem ? See https://uktechhub.com/forums/topic/asus-dsl-n16-issue-with-wifi-show-me-password-is-incorrect/page/2/#post-4997
    Already tried factory resetting the modem with no luck. The reboot happens even without any device connected via WiFi. It is only my PC connected to the modem through a Ethernet cable.[/quote]
    Looks like next firmware release should fix issues, alas no idea when this will be.
    #5457
    AvatarShadowFAX
    • Replies 4
    [quote quote=5452]
    Have you tried a factory reset, It would be good to hear from @ @kamiboy as they also had issues ? Edit: try a wired connection as issue via wifi was original problem ? See https://uktechhub.com/forums/topic/asus-dsl-n16-issue-with-wifi-show-me-password-is-incorrect/page/2/#post-4997[/quote]
    Yes, I have tried factory resetting with no luck.
    The reboot also happens when no device is connected with WiFi, it is only my PC connected to the modem via Ethernet cable.
    It seems that we should wait a few months for ASUS to fix this in the next firmware update.
    #5470
    Avatarkamiboy
    • Replies 32
    try this :
    1.turn off your wireless radio and connect the modem to pc via Ethernet cable
    2.activate l2tp vpn connection
    you should not have issue after turning off wireless radio or maybe it will occurs only once . after first reboot you should not have any issues and second reboot will not occur .
