› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › Asus DSL-N16 not connecting to internet Hi, I have recently switched to one stream and as the charge a monthly fee for a a router and I already had a mesh network setup (old house thick...
- This topic has 7 replies, 2 voices, and was last updated 2 years, 5 months ago by
- April 30, 2024 at 6:18 pm #32061
Hi, I have recently switched to one stream and as the charge a monthly fee for a a router and I already had a mesh network setup (old house thick stone walls) successfully for several years I thought I could buy a cheap old vdsl router and use this as a modem similar to my old setup with nowtv.
My problem is I’m getting a DSL light on the router but the internet isn’t connecting and one stream are saying that they cannot help me with a 3rd party router.
As I bought the router 2nd hand (from CEX) then I’m sure if it’s a faulty router or it’s a fault of the settings
This topic was modified 2 years, 5 months ago by
TheJamMan. Reason: Upload settings had to switch from phone to hotspot and laptop
April 30, 2024 at 6:22 pm #32063This is the log file sorry wouldn’t let me upload directly
<!–more–><!–more–>
2011-01-01 00:00:45 syslogd started: BusyBox v1.00 (2023.10.31-19:04+0000)
2011-01-01 00:00:45 WAN Connection: Wan link down.
2011-01-01 00:00:45 stop_nat_rules: apply the redirect_rules!
2011-01-01 00:00:46 kernel:
2011-01-01 00:00:48 kernel: [route_setting]remove interface[0]=[ppp80]
2011-01-01 00:00:50 kernel: Firmware version=[1.1.2.3]
2011-01-01 00:01:02 kernel: Link State: DSL link up.
2011-01-01 00:01:04 kernel:
2011-01-01 00:01:04 kernel: $s: go into unregister_mulif_device
2011-01-01 00:01:04 kernel: nas8_0: vifname = unregister_mulif_device
2011-01-01 00:01:04 kernel: vdev is NULL
2011-01-01 00:01:04 kernel: unregister autopvc cmd from sys
2011-01-01 00:01:04 kernel: mt7510_atm_exit: ATM SAR RX NAPI Mode
2011-01-01 00:01:04 kernel: mt7510_netdev_close
2011-01-01 00:01:04 kernel: atm_dev: stoping interface.
2011-01-01 00:01:05 kernel: atm_exit_wrappter
2011-01-01 00:01:05 kernel: br2684_exit
2011-01-01 00:01:05 kernel: pppoatm_exit
2011-01-01 00:01:05 kernel: qdma_set_channel_retire
2011-01-01 00:01:05 kernel: qdma_txdscp_recycle_mode
2011-01-01 00:01:05 kernel: qdma_recycle_receive_buffer
2011-01-01 00:01:05 kernel: qdma_recycle_transmit_buffer
2011-01-01 00:01:05 kernel: QDMA_EVENT_NO_RX_BUFFER
2011-01-01 00:01:05 kernel: atm_msg_buffer_free
2011-01-01 00:01:05 kernel: qdma_deinit
2011-01-01 00:01:05 WAN Connection: Fail to connect with some issues.
2011-01-01 00:01:05 kernel: mt7510ptm 2.00-NAPI 19.Jun.2012
2011-01-01 00:01:05 kernel: PTM reset release
2011-01-01 00:01:05 kernel: nas8: MT7510 PTM Ethernet address: A8:5E:45:F7:4D:CC
2011-01-01 00:01:05 kernel: nas9: MT7510 PTM Ethernet address: A8:5E:45:F7:4D:CC
2011-01-01 00:01:05 kernel: ptm_L2encap_init
2011-01-01 00:01:05 kernel: nas8: starting interface.
2011-01-01 00:01:06 syslog: Initialize LCP.
2011-01-01 00:01:06 syslog: Plugin libpppoe.so loaded.
2011-01-01 00:01:06 syslog: RP-PPPoE plugin version 3.8p compiled against pppd 2.4.7
2011-01-01 00:01:06 syslog: pppd 2.4.7 started by admin, uid 0
2011-01-01 00:01:06 syslog: LCP is allowed to come up.
2011-01-01 00:01:41 syslog: Timeout waiting for PADO packets
2011-01-01 00:01:41 syslog: Unable to complete PPPoE Discovery
2011-01-01 00:01:41 syslog: LCP down.
2011-01-01 00:01:45 syslog: LCP is allowed to come up.
2011-01-01 00:02:21 syslog: Timeout waiting for PADO packets
2011-01-01 00:02:21 syslog: Unable to complete PPPoE Discovery
2011-01-01 00:02:21 syslog: LCP down.
2011-01-01 00:02:25 syslog: LCP is allowed to come up.
2011-01-01 00:03:00 syslog: Timeout waiting for PADO packets
2011-01-01 00:03:00 syslog: Unable to complete PPPoE Discovery
2011-01-01 00:03:00 syslog: LCP down.
2011-01-01 00:03:04 syslog: LCP is allowed to come up.
2011-01-01 00:03:39 syslog: Timeout waiting for PADO packets
2011-01-01 00:03:39 syslog: Unable to complete PPPoE Discovery
2011-01-01 00:03:39 syslog: LCP down.
2011-01-01 00:03:43 syslog: LCP is allowed to come up.
2011-01-01 00:04:18 syslog: Timeout waiting for PADO packets
2011-01-01 00:04:18 syslog: Unable to complete PPPoE Discovery
2011-01-01 00:04:18 syslog: LCP down.
2011-01-01 00:04:22 syslog: LCP is allowed to come up.
2011-01-01 00:04:57 syslog: Timeout waiting for PADO packets
2011-01-01 00:04:57 syslog: Unable to complete PPPoE Discovery
2011-01-01 00:04:57 syslog: LCP down.
2011-01-01 00:05:01 syslog: LCP is allowed to come up.
2011-01-01 00:05:37 syslog: Timeout waiting for PADO packets
2011-01-01 00:05:37 syslog: Unable to complete PPPoE Discovery
2011-01-01 00:05:37 syslog: LCP down.
2011-01-01 00:05:41 syslog: LCP is allowed to come up.
2011-01-01 00:06:16 syslog: Timeout waiting for PADO packets
2011-01-01 00:06:16 syslog: Unable to complete PPPoE Discovery
2011-01-01 00:06:16 syslog: LCP down.
2011-01-01 00:06:20 syslog: LCP is allowed to come up.
2011-01-01 00:06:20 WEB: User [admin] logged in from [192.168.1.80] via WEBYou need to login in order to vote
April 30, 2024 at 7:06 pm #32064Welcome, The DSL-N16 is an old model router, but they are robust.
What ISP was you using previously and did the previous modem also act as a router.
I ask as the DSL-N16 from what I remember cannot be used as a modem only, there is no option for Bridge mode but can be used as modem and router if that makes sense ?
April 30, 2024 at 7:54 pm #32065Connected via ethernet cable to a set of three tenda nova MW3. The nowtv box is just the standard router that gets sent out when you join.
April 30, 2024 at 8:29 pm #32066Sorry just read that properly, (tried to reply whilst out with the dog). The nowtv router was the model NR801. Hasn’t got a manufacturer that I can tell
I use the modem router as a as a router just turn off the wifi as the coverage isn’t good enough and use a set of 3 Tenda Nova MW3 in bridge mode so they provide the WiFi and the router provides the internet access to them via ethernet. This has worked fine for a few years now but as it was time to switch providers I decided to give onestream a go just refused to pay £3 a month for a router that costs £25 new (Looks like a TP Link TD-W9970) . I have now ordered one from amazon to check if I can get it to work but that wont arrive till tomorrow and if I can get the Asus to work I can send it back.
April 30, 2024 at 8:31 pm #32067No problem, Does sound initially like a set-up error, have your configured the DSL-N16 for Onestream’s PPPoE username and password and you need to set VLAN to 101.
April 30, 2024 at 8:55 pm #32068Fixed thank you very much. It was the VLAN, there was no mention of setting that in the onestream instructions.
May 1, 2024 at 6:02 am #32069Great news and glad you are all sorted
Just one area to consider, ensure the DSL-N16 is running the latest firmware Version 1.1.2.3_999 as this ensures all security updates are applied.
