› UKTH forums › Wireless Routers & Modems › ASUS & Wireless › Asus DSL-N16 Packet Loss in Apex Legends Pc and PS4 Over sixty percent of packet loss have in The Apex Legend Game (PC and PS4 Platform) with the ASUS modem DSL-N16 A1 and not all the troubleshooting were resolved. I...
- This topic has 26 replies, 3 voices, and was last updated 7 years, 1 month ago by
Meisam.
September 8, 2019 at 2:30 am #4223
Over sixty percent of packet loss have in The Apex Legend Game (PC and PS4 Platform) with the ASUS modem DSL-N16 A1 and not all the troubleshooting were resolved. I had to buy a TP-Link 9970 V2 modem which solved the packet loss problem. With the same provider and the same cable.
What could be the problem with the ASUS modem?
I tried to check in ASUS:
-Port forwarding
-Port trigger
-Upnp
-DMZ PS4 IP or PC IP
-Firewall
-Bridge connection for NAT1
-IP Static
-MTU and MSS-QoS
-Change cable
-Change provider
-Firmware Update———————————-
TP-Link TD-W9970 V2
https://wikidevi.com/wiki/tp-link_td-w9970_v2———————————-
ASUS DSL-N16
https://wikidevi.com/wiki/asus_dsl-n16Firmware Version: 1.1. 2.3_743-GF5B4545
DSL Driver Version: FwVer: 5.5. 2.11_A_A60901 HwVer: T14.F7_0.2SysLog:
Kernel: FW version: V5.5. 2.11_20190418
Kernel: Compile option: C3C0A
Kernel: Release Testlab NUM: All
Kernel: FW version [ADSL]: V3.12.8. 0_MT7510
Kernel: VDSL2 (Multi)
Kernel: Annex A
Kernel: STD: G.992.5
Kernel: Profile: ADSLPlease advise what should I do?
Best Regards
September 8, 2019 at 8:18 am #4228Welcome, so I understand better, you are still having packet loss with you TP-Link, but with the ASUS, packet loss is greater – is that correct ?
Are you connecting to PS4 via Wifi or Ethernet cable, if wifi try ethernet connection, I assume firmware is updated to latest release (yours start with a 1, where as mine starts with a 9)
https://www.asuswebstorage.com/navigate/a/#/s/9A11A78AD414465B853617379C50D180Y
September 9, 2019 at 4:23 pm #4266Overall, the value of the Pocket LOSS for TP-LINK is below 5% and the Asus DSL-N16 firmware version is also the latest version, as I have attached Screnshot.
aslo Having tested with the LAN cable there is still a problem with the Asus modem.
September 9, 2019 at 4:32 pm #4268[quote quote=4266]
[/quote]
When u tested with LAN cable, did TP-Link have problem still ?
Has this packet loss only happened since firmware upgrade on ASUS, or was it a problem on old firmware also ?
Maybe a line fault or ASUS router needs a factory reset ?
September 9, 2019 at 11:38 pm #4276- Please forget TP-Link because TP-Link has no problem I’m looking for a solution to find to why Asus have over 60% Packet loss ?
- This problem also occurs in the old version of the firmware and the latest version of the firmware DSL-N16 A.
- I did a factory reset but it didn’t work.
September 10, 2019 at 1:44 am #4277Can you post a Traffic Manager – Spectrum screenshot from the DSL-N16 ?
Also what are your sync speeds ? DSL-N16 = 21184 kbps/ TD-W9970 V2 = ?
September 10, 2019 at 2:56 am #4279Sure! Please Check attachments
Asus Spectrum Graph I Can’t Understand , Can you explain the graph quality is good or bad? please
Best Regards
September 10, 2019 at 8:54 am #4283From a windows PC /Laptop (if you have one) go to CMD prompt and type the below as this should help determine if packet loss is occurring ?
ping -n 20 8.8.8.8
And check results to see if any packets was lost. if not increase the n 20 value t0 50 then 100 and see if this makes any difference to ping results
Note: forgot to say, try with both a wired and wireless connection
September 10, 2019 at 12:04 pm #4286Thanks for the Spectrum Graph. You have 4 severe drops and 1 minor drop, which indicates there is a lot of interference (noise) going on on your line.
Since you’re on fast path (on the asus at least) this will cause packet loss / errors. With a line of that quality i am actually surprised that DLM didn’t put you on interleaved.
Try and see if you can stabilize your line , start with -5 dB in Administration > DSL Setting >ADSL Settings > Stability Adjustment.
Dynamic Line Adjustment (DLA) Disabled.or
Turn on G.INP if your exchange supports it.
Administration > DSL Setting >Common Settings > G.INP (G.998.4) Enabled
September 10, 2019 at 11:54 pm #4291Thank you for the info, I really appreciate it.
I adjusted the settings you said and attached a screenshot. Unfortunately there was no change and there are still over 60% of pack Loss over lan cable and wifi.
There are no Dsl Log in the TP-Link modem that display the path mode value. But as far as I know, as long as the provider doesn’t change the Path mode, all modems follow the same settings. which means that the TP-Link modem with path mode (fastpath) is less than 5 percent packet Loss.
The last few rows of Tp-link Log I have inserted that indicates G.992 is supported by the Provider.
September 11, 2019 at 4:16 am #4295You are on interleaved now which has your line stabilized somewhat: Upstream 0 CRC
Goto Administration > DSL Setting >
G.INP (G.998.4) : Disabled (Your exchange doesnt seem to support it ?)
SRA (Seamless Rate Adaptation) : Enabled
Rx AGC GAIN Adjustment: Stable
ESNP – Enhanced Sudden Noise Protection: Stable
Also;
If you still have a filter (line splitter) between your modem and phone socket , remove that and unplug all phones (if any)
See if that brings any further improvement.
The DLM will change your line settings to give you the optimum speed / stability depending on line quality. At least that is how it should work.
September 11, 2019 at 5:38 am #4298There is no device between the modem and the home dsl line.
I made the changes you said. There is still Packet Loss. To be honest, it didn’t make a difference
Can we say Provider deliberately and secretly works with the TP-Link brand?
For other brands the modem offers poor service Until the customer is forced to buy a TP-link modem?
They won’t change path mode unless you request as a customer. I think the path mode value does not depend on the modem to change automatically.
September 11, 2019 at 7:00 am #4299[quote quote=4283]From a windows PC /Laptop (if you have one) go to CMD prompt and type the below as this should help determine if packet loss is occurring ? ping -n 20 8.8.8.8 And check results to see if any packets was lost. if not increase the n 20 value t0 50 then 100 and see if this makes any difference to ping results Note: forgot to say, try with both a wired and wireless connection[/quote]
Ping results for values of 20 , 50 and 100 :
avg ping = 100ms
packet loss = 0%
But there are still more than 60 percent of Pocket Loss online games And the question still remains for me why the TP-link modem does not have this problem.
September 11, 2019 at 7:52 am #4305If technical stuff was easy, everybody would be doing it well ;-)
Have you enabled QoS for your games, if so try disabling and see if issue remains.
Are yo using IPv4 or IPv6? are your ip addresses fixed or assigned by DHCP (I assume only IPv4?
Try changing MTU (for testing) on router to 1400 to see if this helps
Edit: if pos, on PC run the following – netsh interface ipv4 show subinterfaces – and let us know what MTU value is ? (mine is 1500) windows 10 for all possible conections
September 11, 2019 at 9:24 am #4308Have you enabled QoS for your games, if so try disabling and see if issue remains.
yes i have enable QoS and add many record port and port rang which is accessible on site EA for your platform and some online game. after setup QoS do not change packet loss So I disabled it.
i use IPv4 and ip address is fixed.
I tried a lot of mtu but it didn’t work. Also, in this Asus model you have to change the mss value to apply mtu.
I have attached a screenshot.
