Asus RT-AX88U / Pro – Firmware Updates Thread
UKTH forums 🛜 Wireless Routers & Modems 💬 ASUS & Wireless Asus RT-AX88U / Pro – Firmware Updates Thread
Viewing 15 posts - 1 through 15 (of 138 total)
  • #5137
    AvatarSH
    • Replies 81
    Router Model – Asus RT-AX88U
    Firmware Version – 3.0.0.4.384.7756
    Firmware Release Date – 2019/11/25
    Changelog –
    – Enhanced the Wi-Fi 6 performance with Apple® iPhone11, Samsung® S10.
    – Supported WPA3
    – Supported OFDMA
    – Supported 802.11k and 802.11v
    – Fixed Let’s encrypt register related bugs.
    – Fixed connection issues between Android and RT-AX88U IPSec VPN server.
    – Improved system stability.
    Firmware Download Link –
    https://dlcdnets.asus.com/pub/ASUS/wireless/RT-AX88U/FW_RT_AX88U_30043847756.zip
    AvatarSH
    • Replies 81
    384.7756 have broken adaptive QOS , manual bandwidth setting don’t work at all…. is there any fix from Asus for this ?
    • Replies 8,204
    That Firmware version was only released three days ago, I read on SNB that another owner had also thought QoS was broken with .7756 if the QOS is an issue, you may have to revert back to Version 3.0.0.4.384.6436
    Have you tried a factory reset and build from scratch, (not backup) just to make sure ?
    I am surprised you are not using ASUSWRT-Merlin firmware ?
    #5144
    AvatarSH
    • Replies 81
    thanks for reply UK Sentinel ….
    QOS is not a big issue
    yes i have done factory reset ….
    though i have found one more issue ….. by default 160MhHz is checked ….. this cause download speed drop issue on Intel 9560 Wi-Fi  card.
    i think these issue will be also preset in Merlin built  when he will merge GPL ?
    • Replies 8,204
    Some of those Intel wifi chipsets are troublesome, mine on my Dell Intel(R) Dual Band Wireless-AC 7265 was a royal pain with 160MHz Speeds when I was testing earlier this year.
    Hopefully others will notice QoS issue with latest RT-AX88U firmware and find solution/fix from ASUS
    Edit: Is your RT-AX88U hardware Revision is A1 or hardware Revision is A1.1. not sure if it would make any real difference but worth noting country of Assembly for future reference ?
    A1 was assembled in China
    A1.1 was assembled in Vietnam
    #5148
    • Replies 994
    I dont have problems with 160MHz and my Intel AC9260, but I use AVM7590 router with 160MHz.
    AvatarSH
    • Replies 81
    hmm 726 line up does have issue :D …. but i think they fixed it … on windows 10 best driver are seems to be that u get from windows updates.
    my hardware revision  is A1 (  assembled in China )
    i did some testing from  other laptops too  , it  turn out 160MHz was not a issue …but speedtest.net server was having an issue or overloaded .
    Thank’s Grisu
    • Replies 994
    try others like fast.com but here I got good results with speedtest.net too a minute ago.
    • Replies 8,204
    Asus RT-AX88U Firmware 3.0.0.4.384_7968 is out, not on download servers as yet:
    https://dlcdnets.asus.com/pub/ASUS/wireless/RT-AX88U/FW_RT_AX88U_30043847968.zip
    Firmware version 3.0.0.4.384_7968
    Change Log:
    1. Improve wireless compatibility.
    2. Improve wireless performance.
    3. AiProtection related issue fixes.
    4. Supports Amazon Wi-Fi simple setup : Helps you connect WSS supported devices to your Wi-Fi network and Alexa account in fewer steps.
    Enabling this feature creates a simple setup network that supported devices can use to access Wi-Fi credentials saved in the Amazon Wi-Fi Locker.
    #5480
    AvatarMrk26
    • Replies 465
    Will try this one once i back from work, fancy to see if wifi will be faster than on Merlin for mobile phones, no issues with pc, but on moblie devices strangely slow? 🤔
    • Replies 8,204
    @XRW is the expert with RT-AX88U, hopefully they can give the new firmware a test run
    #5482
    AvatarSH
    • Replies 81
    i have already tested this new firmware …. now only Upstream QOS  is broken , people also reported some other issue with it on Iphones and WAN issue where it shows disconnected ( for first few minutes when u reset or restart the router )
    Through WAN issue can be fixed -> login to your router -> click on WAN -> scroll down and select no to Enable VPN + DHCP Connection )  –> apply and reboot
    currently ASUS Stock 3.0.0.4.384.6436 and Merlin 384.14 is most stable ( does have WAN issue during reset … so be patient when u reset router )
    what are your wifi settings for 5ghz and 2.4ghz on professional tab ? @Mrk26
    • Replies 8,204
    Thanks @XRW
    #5487
    AvatarMrk26
    • Replies 465
    Hey @XRW
    My settings attached
    AvatarSH
    • Replies 81
    Thank’s Mrk26 for screenshots
    hmm there is no need to disable Multi User MIMO , 802.11 AC Beamforming ,Explicit Beamforming and Universal Beamforming  ….. by default on Merlin Firmware they are Enabled and works fine on RT-AX88U  ….
    Merlin do advice to disable Airtime Fairness and Universal Beamforming  and leave everything else to default unless you have special needs for your connected devices
    but by disabling Universal Beamforming i have noticed i do get max link speed on devices … but on some devices  link speed get locked to it for a period of time ……………. ( for example .. one of the device ( 5GHz 2×2 MIMO ) kept far from the router and got connected at link rate of 270Mbps  , now moving it next  to the router … link speed was unchanged and was stuck at 270Mbps for some unknown reasons until i disconnect and reconnect that device  )  … enabling it resolve this issue and link rate was dynamically adjusted without needing of disconnecting and reconnecting  ………………….
