› UKTH forums › Wireless Routers & Modems › ASUS & Wireless › Asus RT-AX88U / Pro – Firmware Updates Thread ============================ Router Model – Asus RT-AX88U Firmware Version – 3.0.0.4.384.7756 Firmware Release Date – 2019/11/25 ============================ Changelog – – Enhanced the Wi-Fi 6 performance with Apple® iPhone11, Samsung® S10. –...
- This topic has 138 replies, 7 voices, and was last updated 7 months, 3 weeks ago by
February 13, 2025 at 12:17 pm #35614
New ASUS RT-AX88U Firmware version 3.0.0.4.388_24224
2025/02/11
1.Fixed the UI issue in Chrome.
2.Fixed client binding issues in Mesh scenariosYou need to login in order to vote
February 26, 2025 at 7:55 am #35729Latest ASUS RT-AX88U Firmware Version 3.0.0.4.388_24232
2025/02/25
1.Enhanced input parameter handling techniques to improve data processing stability and system security.
2.Enhance system access control mechanisms.You need to login in order to vote
March 19, 2025 at 6:47 pm #36070New ASUS RT-AX88U Pro Firmware version 3.0.0.6.102_33352
2025/03/19
4. Enhance system access control mechanisms.You need to login in order to vote
March 25, 2026 at 8:12 am #42282Latest RT-AX88U Pro Firmware Version 3.0.0.6.102_37421
2026/03/24
Bug Fixes and Enhancements:
– Improved WiFi roaming behavior to reduce temporary disconnections in some scenarios.
– Improved roaming compatibility for certain client devices.
– Improved App Remote Connection stability in certain scenarios to prevent unexpected connection drops.
– Improved AiMesh onboarding reliability, addressing cases where the onboarding process could stall and fail to complete.
– Fixed an issue where the guest network client list might not display correctly in certain scenarios.
– Fixed an issue with Web history display.
– Fixed an issue where the app could not remove offline devices.
– Fixed an issue where specific IPv6 configuration flows could cause IPv6 connectivity problems on the main network.
– Fixed an issue where enabling System Diagnostics and staying on a specific page could cause repeated reboots.Security Fixes:
– Enhanced input validation and protection to reduce the risk of command injection and SQL injection.
– Hardened environment variable handling.
– Hardened protections around specific logging/command composition flows to reduce potential injection risks.
– Patched a command injection risk in a specific network diagnostic function.
We recommend upgrading to this version to maintain best protection.You need to login in order to vote
