Asus RT-AX88U / Pro – Firmware Updates Thread ============================ Router Model – Asus RT-AX88U Firmware Version – 3.0.0.4.384.7756 Firmware Release Date – 2019/11/25 ============================ Changelog – – Enhanced the Wi-Fi 6 performance with Apple® iPhone11, Samsung® S10. –…
› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › Asus RT-AX88U / Pro – Firmware Updates Thread ============================ Router Model – Asus RT-AX88U Firmware Version – 3.0.0.4.384.7756 Firmware Release Date – 2019/11/25 ============================ Changelog – – Enhanced the Wi-Fi 6 performance with Apple® iPhone11, Samsung® S10. –...
Viewing 15 posts - 121 through 135 (of 139 total)
  • #20657
    • Replies 8,722
    Seems you are able to change the listening port on Wireguard and changing the default listening port could be a good idea just as it is a good idea to change the port on OpenVPN and others VPN servers if possible.
    #21029
    • Replies 8,722
    New firmware release for ASUS RT-AX88U Firmware version – a big security update
    ASUS RT-AX88U Firmware version 3.0.0.4.388.20558
    2022/09/21
    Bug fixes
    – Fixed port status UI bugs
    – Modified WireGuard VPN server default setting to fix iOS WireGuard app connection issues. If you have iOS connection issues on the previous version(3.0.0.4.388.20518), please upgrade to this version and reset the router.
    – Fixed VPN fusion connection issues with Surfshark WireGuard profile.
    – Improved the AiMesh stability.
    Security
    – Fixed HTTP response splitting vulnerability. Thanks to Efstratios Chatzoglou, University of the Aegean.
    – Fixed status page HTML vulnerability. Thanks to David Ward.
    – Fixed CVE-2018-1160. Thanks to Steven Sroba.
    – Fixed cfg_server security issue.
    – Fixed CVE-2011-0719, CVE-2012-2812, CVE-2012-2836, CVE-2012-2837, CVE-2012-2841, CVE-2012-3868, CVE-2013-0172, CVE-2013-4124, CVE-2014-3493, CVE-2015-0240, CVE-2015-5252, CVE-2015-5296, CVE-2015-5299, CVE-2015-5370, CVE-2016-2110, CVE-2016-2111, CVE-2016-2112, CVE-2016-2115, CVE-2016-2118, CVE-2016-4425, CVE-2016-6328, CVE-2016-10196, CVE-2018-5743, CVE-2018-13305, CVE-2018-15822, CVE-2018-20030, CVE-2018-1999012, CVE-2019-9278, CVE-2019-17498, CVE-2020-0093, CVE-2020-0182, CVE-2020-12767, CVE-2020-13112, CVE-2020-13113,CVE-2020-13114, CVE-2020-13904,CVE-2020-14323, CVE-2020-20450, CVE-2020-20451, CVE-2020-20891, CVE-2020-20892, CVE-2020-20896, CVE-2020-20898, CVE-2020-21041, CVE-2020-21688, CVE-2020-21697, CVE-2020-22016, CVE-2020-22017, CVE-2020-22020, CVE-2020-22022, CVE-2020-22023, CVE-2020-22025, CVE-2020-22026, CVE-2020-22027, CVE-2020-22028, CVE-2020-22030, CVE-2020-22031, CVE-2020-22032, CVE-2020-22036, CVE-2020-22038, CVE-2020-22039, CVE-2020-22040, CVE-2020-22041, CVE-2020-22042, CVE-2020-22043, CVE-2020-22044, CVE-2020-22046, CVE-2020-22048, CVE-2020-22049, CVE-2020-22051, CVE-2020-22054, CVE-2020-23906, CVE-2022-35401,CVE-2021-38090,CVE-2021-38091, CVE-2021-38092, CVE-2021-38093, CVE-2021-38094, CVE-2021-38114, CVE-2021-38171.
    https://dlcdnets.asus.com/pub/ASUS/wireless/RT-AX88U/FW_RT_AX88U_300438820558.zip
    #22400
    • Replies 8,722
    New ASUS RT-AX88U Firmware version 3.0.0.4.388.22237
    Version 3.0.0.4.388.22237
    1. Improved system stability.
    2. Fixed the IPsec VPN compatibility issue with Win10.
    3. Fixed the VPN fusion user interface issues under the HTTPS connection.
    4. Fixed Client DOM Stored XSS vulnerability.
    5. Improved Wireguard performance.
    6. Optimized memory usage and improved system stability.
    7. Fixed USB HDD compatibility issue with the Time machine.
    8. Added a new web GUI login URL http://www.asusrouter.com
    9. Fixed IPTV compatibility issue with Movistar. Thanks to Sergio de Luz from RedesZone.net.
    10. Fixed VPN fusion, AiMesh, and Network map GUI bugs.
    https://www.asus.com/networking-iot-servers/wifi-6/all-series/rt-ax88u/helpdesk_bios/?model2Name=RT-AX88U
    #24175
    • Replies 8,722
    New ASUS RT-AX88U Pro Firmware version 3.0.0.4.388.23110
    Version 3.0.0.4.388.23110
    Release date: 2023/04/26
    New features:
    -Built-in Surfshark in VPN Fusion allows you to surf the internet anonymously and securely from anywhere by encrypting connections. Please refer to https://asus.click/SurfsharkVPN
    -iPhone/Android USB auto backup WAN allows you to connect your phone to the router’s USB port and use it as an internet source. Please refer to https://asus.click/AutobackupWAN
    -DDNS transfer allows you to transfer your ASUS DDNS hostname from your original router to the new one. Please refer to https://asus.click/ASUSDDNS
    -Fixed the AiCloud login issue after unplugging and plugging the HDD into the USB port.
    -Modified the USB application option text in dual WAN.
    -Allowed WireGuard Server clients to access the Samba server.
    -Fixed memory leak issue.
    -Enabled the failback function when using the iOS/Android USB backup WAN.
    Security updates:
    -Fixed null pointer dereference vulnerabilities. Thanks to Chengfeng Ye, Prism Research Group – cse hkust contribution.
    https://www.asus.com/networking-iot-servers/wifi-routers/asus-gaming-routers/rt-ax88u-pro/helpdesk_bios/?model2Name=RT-AX88U-Pro
    #25320
    • Replies 8,722
    Latest ASUS RT-AX88U Pro Firmware version 3.0.0.6.102_21514
    Version 3.0.0.6.102_21514
    Release date: 2023/06/20
    New features for ASUSWRT 5.0
    -Kids’ Wi-Fi: Create a separate network specifically for children, complete with scheduled controls. This is suitable for children who use multiple network devices that have enabled the randomized MAC address function and are not easily recognized.
    -VPN WiFi: Create a VPN network that connects to 3rd party VPN services or with ASUS site to site -VPN(https://www.asus.com/support/FAQ/1048281/) to encrypts your internet connection and hides your IP address to protect your online activities from being tracked or monitored.
    -IoT WiFi : Create an 2.4G spearate network for IoT (Internet of Things) devices.
    Guest WiFi: Create a guest network with a WiFi schedule and access rights to control when and how guests can use the network.
    -VLAN, allow you to segment a network into smaller, virtual sub-networks, which can be used to isolate traffic, please refer to https://www.asus.com/support/FAQ/1049415/
    -Multi-services WAN, create multiple profiles on a single WAN interface. (https://rog.asus.com/au/support/FAQ/1050072)
    -Port isolation and AP isolation to restrict device access to each other.
    Bug Fixes and Enhancements:
    -NowTV profile has been added under new IPTV profiles.
    -IPTV settings have been updated for better compatibility with Unifi Biz VoIP service.
    -Fixed a GUI bug that occurred when adding port range rules in the Network Service Filter.
    -Resolved an issue that caused hostname errors in the DDNS service.
    Security Fixes:
    -Fixed several curl vulnerabilities including CVE-2023-28322, CVE-2023-28321, and CVE-2023-28319.
    -Fixed FFmpeg vulnerabilities, specifically CVE-2022-3964, CVE-2022-48434, and CVE-2022-3109.
    -Corrected an OpenVPN vulnerability categorized as CWE-134.
    -Fixed the Hostap vulnerability CVE-2019-10064.
    -Patched a command injection vulnerability to improve overall security.
    -Strengthened protection against SSH brute force attacks.
    https://www.asus.com/uk/networking-iot-servers/wifi-routers/asus-gaming-routers/rt-ax88u-pro/helpdesk_bios/?model2Name=RT-AX88U-Pro
    #26089
    • Replies 8,722
    Latest ASUS RT-AX88U Firmware version 3.0.0.4.388_23748
    Version 3.0.0.4.388_23748
    2023/07/26
    New features:
    -Resolved the issue where the USB path is not displayed on the Media Server page in the AiMesh node
    Security updates:
    -Allowed binding DDNS to a user’s account to reduce the risk of MITM attacks
    -Fixed CVE-2023-34359,CVE-2023-34358 Unauthenticated Denial of Service
    -Fixed CVE-2023-34360 Stored XSS
    -Fixed the cfg server vulnerability.
    -Fixed the vulnerability in the logmessage function CVE-2023-35086/ CVE-2023-35087.
    -Fixed lighttpd vulnerability, CVE-2023-35720.
    -Fixed openssl vulnerability, CVE-2023-0464.
    -Fixed ReadyMedia vulnerabilitym CVE-2020-28926.
    -Fixed UPnP vulnerability CVE-2020-12695.
    https://www.asus.com/networking-iot-servers/wifi-routers/asus-gaming-routers/rt-ax88u/helpdesk_bios/?model2Name=RT-AX88U
    #27655
    • Replies 8,722
    New ASUS RT-AX88U Firmware version 3.0.0.4.388_24198
    Version 3.0.0.4.388_24198
    2023/10/20
    Bug fixes and improvements:
    -Ensured consistent display of client status on the WireGuard server.
    -Enhanced system stability when accessing the WireGuard Server with DMZ enabled.
    -Improved stability when enabling or disabling the WireGuard server.
    -Addressed an issue that prevented clients from accessing the network when setting up the OpenVPN server in TAP mode.
    -Optimized memory utilization and fixed an occasional server error when registering DDNS with an app.
    -Corrected a bug encountered when adding a rule to the Network Services Filter.
    Security Fixes:
    -Upgraded to the latest dropbear version.
    -Fixed a stack overflow vulnerability.
    https://www.asus.com/uk/networking-iot-servers/wifi-6/all-series/rt-ax88u/helpdesk_bios/?model2Name=RT-AX88U
    #28244
    • Replies 8,722
    New ASUS RT-AX88U Pro Firmware version 3.0.0.6.102_32843
    Version 3.0.0.6.102_32843
    2023/11/27
    New features:
    – Added new iptv profile NowTV.
    – Resolved Guest Network Pro issues to prioritize devices for various business usages and network alternatives.
    – Resolved AiMesh-related issues to provide stable backhaul connection.
    – Resolved GUI issues to ensure that the user interface is even more user-friendly.
    – fixed build error when removing ALEXA.
    – Fixed client traffic monitor card.
    – Fixed v6plus related issues.
    – Fixed the registration failure after reboot when using account based DDNS.
    – Fixed the issue that did not send report operation after acquiring the MAP rules.
    – Fixed getting IPv6 address if setting hinet MOD mesh even router disable IPv6.
    – Fixed an issue where DHCP discover packets were not being filtered when the hinet MOD mesh IPTV profile was set.
    – Fixed offline Aimesh node can’t be removed successfully.
    – Fixed WiFi 5GHz LED control radio disabled case.
    – Fixed DDNS server error occurs when registering DDNS with ASUS Router app.
    – Resolved OpenVPN server TAP Mode Issue.
    New features:
    Security Fixes:
    – Fixed several curl vulnerabilities.
    – Fixed command Injection Issue after authentication
    https://www.asus.com/networking-iot-servers/wifi-routers/asus-gaming-routers/rt-ax88u-pro/helpdesk_bios?model2Name=RT-AX88U-Pro
    #29097
    • Replies 8,722
    Latest ASUS RT-AX88U Pro Firmware version 3.0.0.6.102_33308
    Version 3.0.0.6.102_33308
    2024/01/12
    – Resolved issues where Guest Network Pro and VPN connections were unable to access the internet due to DNS errors occurring when certain functions were activated.
    – Removed execute mode from the backup file.
    – Addressed translation issues in Guest Network Pro – Guest Portal – Terms of Service.
    – Corrected the VPN WireGuard client profile name issue.
    – Modified VPN routing rules.
    – Fixed the access LAN issue after deleting the IoT Network.
    – Addressed the VPN default connection issue.
    – Fixed the problem where an AiMesh node could not broadcast WiFi signal normally when creating a Guest Network Pro WiFi-only network.
    #31724
    • Replies 8,722
    New ASUS RT-AX88U Firmware version 3.0.0.4.388_24209
    Version 3.0.0.4.388_24209
    2024/03/29
    Rlease note :
    – Fixed command injection vulnerability.
    – Fixed the ARP poisoning vulnerability. Thanks to the contribution of Xin’an Zhou.
    – Fixed code execution in custom OVPN. Thanks to the contrubution of Jacob Baines.
    – Fixed the injection vulnerability in AiCloud.
    – Fixed stack buffer overflow in lighttpd. Special thanks to Viktor Edstrom.
    – Fixed CVE-2023-35720
    – Fixed the code execution vulnerability in AiCloud. Thanks to the contribution of chumen77.
    – Fixed the XSS and Self-reflected HTML injection vulnerability. Thanks to the contrubution of Redfox Cyber Security.
    *Please be advised that due to a security upgrade in AiMesh, we strongly recommend against downgrading to previous firmware versions, as this may lead to connection issues. Should you encounter any difficulties, resetting the AiMesh router to its default settings and re-establishing the mesh connection can resolve the problem.
    https://www.asus.com/uk/networking-iot-servers/wifi-routers/asus-gaming-routers/rt-ax88u/helpdesk_bios?model2Name=RT-AX88U
    #33160
    • Replies 8,722
    ASUS RT-AX88U Pro Firmware version 3.0.0.6.102_33309
    Version 3.0.0.6.102_33309
    2024/08/19
    Changelog.
    Fixed injection vulnerability.
    https://www.asus.com/uk/networking-iot-servers/wifi-routers/asus-gaming-routers/rt-ax88u-pro/helpdesk_bios?model2Name=RT-AX88U-Pro
    #34198
    • Replies 8,722
    Latest ASUS RT-AX88U Pro Firmware version 3.0.0.6.102_33320
    Version 3.0.0.6.102_33320
    2024/09/27
    1. Optimized memory management mechanisms, improving system efficiency and stability.
    5. Perfected JavaScript-related security mechanisms, offering a more secure web interaction environment.
    6. Fixed the incorrect display of the DNS List interface.
    #34774
    Avatarcitylightwalrus
    Blocked
    • Replies 55
    ASUS RT-AX88U Pro Firmware version 3.0.0.6.102_33338
    Version 3.0.0.6.102_33338
    67.98 MB
    2024/11/06
    SHA256: 566e3072c233b020d46625b9346767a63c5571283fb1bc29275b71a9caa89055
    #34853
    Blocked
    • Replies 55
    ASUS RT-AX88U Pro Firmware version 3.0.0.6.102_33340
    Version 3.0.0.6.102_33340
    67.97 MB
    2024/11/12
    – Fixed display issues on the AiMesh page.
    Security updates:
    – Strengthened input validation and data processing workflows to further protect information security.
    – Enhanced AiCloud password protection mechanisms, safeguarding against unauthorized access attempts.
    – Enhanced device security through improved buffer handling in connection features.
    – Refined data handling processes, ensuring secure and accurate information management.
    – Enhanced file access control mechanisms, promoting a more secure operating environment.
    – Strengthened certificate protection, providing enhanced data security.
    SHA256: 46a70e35a0e57f93ac847be136f5b6012a1fe9c5b3b953bc2cf4b446a8cff3c9
    #34934
    Blocked
    • Replies 55
    ASUS RT-AX88U Firmware version 3.0.0.4.388_24221
    Version 3.0.0.4.388_24221
    67.95 MB
    2024/11/18
    SHA256: 1bcd3a7badf81d75ccb901b92cbf2ae7d77d15fae567509cb40f02a180b1a9d2
    https://www.asus.com/ie/networking-iot-servers/wifi-routers/asus-gaming-routers/rt-ax88u/helpdesk_bios?model2Name=RT-AX88U
