› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › ASUS RT-AX88U Hardware Specs ASUS RT-AX88U Hardware Specs ‘ASUS’ first 802.11ax (4 x wifi (AC) speed increase) (total wifi throughput) CPU1: Broadcom BCM49408 (1.8 GHz, 4 cores) FLA1: 256 MiB (Macronix NAND) RAM1: 512...
- This topic has 0 replies, 1 voice, and was last updated 7 years, 7 months ago by
- August 28, 2018 at 3:00 pm #404
RAM1: 512 MiB (Micron DDR3)Expansion IFs: USB 3.1 (Gen 1), USB 3.0
USB ports: 2
WI1 chip1: Broadcom BCM43684
WI1 802dot11 protocols: an+ac+ax
WI1 MIMO config: 4×4:4
WI1 antenna connector: U.FL, RP-SMA
WI2 chip1: Broadcom BCM4366E
WI2 802dot11 protocols: bgn
WI2 MIMO config: 4×4:4
WI2 antenna connector: U.FL, RP-SMAETH chip1: Broadcom BCM49408
ETH chip2: Aquantia AQR107
ETH chip3: Aquantia AQR407
Switch: Realtek RTL8370MB
LAN speed: 100/1000/10000
LAN ports: 8
WAN speed: 100/1000/10000
WAN ports: 1UK Sentinel
