Asus xt8 settings Hi guys I know your all busy,I believe your probably the only technical genius’s answer my questions about Asus xt8s settings, I have set up gig fibre 940 through 61…
UKTH forums 🛜 Wireless Routers & Modems ASUS & Wireless Asus xt8 settings Hi guys I know your all busy,I believe your probably the only technical genius’s answer my questions about Asus xt8s settings, I have set up gig fibre 940 through 61...
Viewing 15 posts - 1 through 15 (of 30 total)
  • #29027
    AvatarKi11sh0t87
    • Replies 41
    Hi guys I know your all busy,I believe your probably the only technical genius’s answer my questions about Asus xt8s settings, I have set up gig fibre 940 through 61 option automatic i.p, have ai protection off, and auto smart connect off ,oqs off, bandwidth limiter on smaller devices, have no DNS connection and have LAN connection for my Amazon shield, everything else else wireless,small devices connected 2.4 and streaming devices connected 5.1/5.2 ,node on backhal wireless with 2.4 connect first.. firmware is 3.0.04 not melin yet and my issue that I speed is 700 coming through max when was 940 last year and I don’t know what It could be have hard rest them back and started from scratch , hoping your knowledge can help.sorry about the long message, appreciate your time , just a novice trying to find the way
    #29028
    • Replies 8,675
    Welcome and thank you for registering
    I assume you are a SKY broadband customer in uk ?
    Is the only change the firmware revision versions since your tests last year
    If not already, try updating to latest firmware 3.0.0.4.388.23285 as you state you are on 3.0.04 ?
    #29030
    AvatarKi11sh0t87
    • Replies 41
    Hi skipper, thanks for having me , sorry my firmware is 3.0.04.<!–more–>388.23285, I don’t know exactly remember what my settings was last year,I couldn’t get on the router, or Asus app without factory reset,so didn’t get a chance to see what was set.???? For some reason I could never log into the router even tho I changed the password,but sorted all that mess out and trying to see if I have it all set up correctly ,my friend did it for me , but we know longer speak so had to kind trial and error until someone pointed me to you guys.i can send scene shots if needed.
    #29031
    • Replies 8,675
    No problem and any screen shots I think might be useful
    If they reveal to much router sensitive information, I will delete them for your benefit.
    #29032
    AvatarKi11sh0t87
    • Replies 41
    Thank skipper I ll try look now. I don’t know what’s important so mite be a few haha.
    #29033
    AvatarKi11sh0t87
    • Replies 41
    • No ideas really haha<!–more–>
    #29038
    AvatarKi11sh0t87
    • Replies 41
    Not a clue haha
    #29043
    AvatarKi11sh0t87
    • Replies 41
    AvatarKi11sh0t87
    • Replies 41
    • Replies 8,675
    Lots – I will have a look tonight and see if anything is of concern
    #29052
    AvatarKi11sh0t87
    • Replies 41
    Cheers pal think it’s all whole settings configuration haha.will probably help alot people starting off.
    #29053
    • Replies 1,032
    Nothing needed to be blanked out (only found SSID but no need to delete it without PW).
    #29054
    AvatarKi11sh0t87
    • Replies 41
    Find anything else grisu that could be slowing my connection down
    #29055
    • Replies 1,032
    Turn off all other clients when testing and be sure to use 5GHz WLAN.
    Is there any need for speeds >500Mb/s at all?
    #29058
    AvatarKi11sh0t87
    • Replies 41
    Use it mostly for steaming,had/4k and for the kids ,but even with 500+mb it still buffering some time’s ,I used to play 2g film’s with no issues.
