UKTH forums 🛜 Wireless Routers & Modems ASUS & Wireless ASUS ZenWiFi AX Whole Home Tri-Band Mesh WiFi 6 System   Not sure if this is the right place to ask…. I am thinking of upgrading my Google Mesh wifi to the above.  Has anyone used this and does it...
Viewing 15 posts - 886 through 900 (of 1,417 total)
  • #22570
    • Replies 622
    Thanks UK Sentinel, much appreciated.  I am pretty sure ASUS know people have been complaining about this.
    #22571
    • Replies 8,675
    I did read that for Wireless connections, manually selecting WPA2 does seem to help with node stability as does manually selecting Channel Bandwidth 80MHz for wireless backhaul has helped ?
    But in reality, this is just tinkering with a buggy solution, so hopefully ASUS will address this and I will keep chasing them
    #22575
    • Replies 94
    I’ve been running 3.0.0.4.388_22068 for ages now and not had any issues at all. Can’t even remember the last time I saw the mesh node dropping to 2.4GHz. RAM usage seems fine and so too is the USB flash drive I have hooked up to the main router to share a selection of movies to smart TVs.
    I have forced 80MHz backhaul and gave up on 160MHz because it seems that with that enabled, I get the problems. As ever, you can never be 100% certain that changing a setting has helped when also changing the firmware, but with this version it is very much a case of ‘set it and forget it’. I too have WPA2-Personal and have a fixed channel rather than auto.
    #22577
    • Replies 8,675
    Thanks for letting us know and good to see the WPA2-personnel and 80MHz backhaul settings are proving reliable for the XT8 3.0.0.4.388_22068  release .
    #22641
    AvatarLarryR
    • Replies 33
    I’ve been running 3.0.0.4.388_22068 for ages now and not had any issues at all. Can’t even remember the last time I saw the mesh node dropping to 2.4GHz. RAM usage seems fine and so too is the USB flash drive I have hooked up to the main router to share a selection of movies to smart TVs. I have forced 80MHz backhaul and gave up on 160MHz because it seems that with that enabled, I get the problems. As ever, you can never be 100% certain that changing a setting has helped when also changing the firmware, but with this version it is very much a case of ‘set it and forget it’. I too have WPA2-Personal and have a fixed channel rather than auto.
    I just decided to try the same as you. Upgraded back to latest official 388 release. WPA2_Personal. Wireless backhaul to 80 only. No more auto for channel selection on all bands. Let’s see how stable we are.
    #22642
    • Replies 622
    I am pretty sure that setting 80MHz on the wireless backhaul and WPA2 with fixed channels will ‘resolve’ most of the issues.  I am on 386.49873 for nearly 2 weeks with my normal settings and 160MHz backhaul, it has been virtually flawless throughout.  It is my go to FW when I encounter issues.
    #22643
    robgbcrobgbc
    • Replies 40
    Nice to see folks trying 80Mhz backhaul. I haven’t had any issues with 3.0.0.4.388_22068
    Current backhaul connect time 349 hours. WPA3/AX Only/80Mhz/Auto. Free ram 163 MB
    Edit: As per screenshot, I have backhaul set to 20/40/80, so that device can respond to unexpected interference, but I have yet to see it drop off 80Mhz
    • Replies 8,675
    Good to see 80MHz backhaul seems to be the key for 388 builds
    #22648
    • Replies 622
    I do not have the option for 20/40/80 MHz on 5GHz-2.  Mine is 20/40/80/160 MHz.  Am I missing something?  This is on 22068
    edit.  Worked it out.  Disabled 160MHz now.
    #22652
    • Replies 8,675
    I do not have the option for 20/40/80 MHz on 5GHz-2. Mine is 20/40/80/160 MHz. Am I missing something? This is on 22068 edit. Worked it out. Disabled 160MHz now.
    being brave moving to 3.0.0.4.388_22068 are you 😉
    #22653
    • Replies 622
    I will give it a try with 80MHz, in the name of science .  Speedtest has gone down from 490Mbps to 340Mbps.  Lets see what happens.
    #22654
    AvatarLarryR
    • Replies 33
    I will give it a try with 80MHz, in the name of science<noscript></noscript>. Speedtest has gone down from 490Mbps to 340Mbps. Lets see what happens.
    Speedtest from a device connected to that node or from the GUI? I know in my case, 80mhz on 802.11ax provides more than enough bandwidth for my 500/20 Spectrum connection at max speed (I speedtest out around 590/24 during “quiet” times).
    #22655
    • Replies 622
    My setup is – ISP Router – XT8 router – XT8 Node 1 – XT8 Node 2 – XT8 Node 3
    Wireless speedtest from device connected to Node 1 is basically full speed 750Mbps+.  The one in my room is Node 2.  From there I get 490Mbps with 160MHz and 340Mbps with 80MHz.
    #22656
    AvatarLarryR
    • Replies 33
    My setup is – ISP Router – XT8 router – XT8 Node 1 – XT8 Node 2 – XT8 Node 3 Wireless speedtest from device connected to Node 1 is basically full speed 750Mbps+. The one in my room is Node 2. From there I get 490Mbps with 160MHz and 340Mbps with 80MHz.
    I only have a 1 router, 1 node XT8 system. Wonder if it’s the daisy chaining that slows things down? Have you manually selected a backhaul channel that seems clear of any other interference?
    I’m just surprised that being an extra hop away would slow things down that much. Not that 340Mbps isn’t enough for just about anything ^_^.
    #22659
    robgbcrobgbc
    • Replies 40
    Very interesting, with the network idling, I speedtest around 650-750, router and node: WPA3/AX Only/80Mhz/Auto
