ASUS ZenWiFi ET12 and Pro ET12– Official Thread New ASUS ZenWiFi Pro ET12 Firmware version 3.0.0.4.388.21739 2022/11/28 Version 3.0.0.4.388.21739 1. Supported WireGuard VPN server and client. 2. Supported VPN fusion. It can easily achieve VPN connection to network…
› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › ASUS ZenWiFi ET12 and Pro ET12– Official Thread New ASUS ZenWiFi Pro ET12 Firmware version 3.0.0.4.388.21739 2022/11/28 Version 3.0.0.4.388.21739 1. Supported WireGuard VPN server and client. 2. Supported VPN fusion. It can easily achieve VPN connection to network...
Viewing 15 posts - 1 through 15 (of 87 total)
  • #21877
    • Replies 8,699
    2022/11/28
    7. Fixed HTTP response splitting vulnerability. Thanks to Efstratios Chatzoglou, University of the Aegean.
    8. Fixed status page HTML vulnerability. Thanks to David Ward.
    9. Fixed CVE-2018-1160. Thanks to Steven Sroba.
    10. Fixed cfg_server security issue.
    11. Fixed miniupnpc vulnerabilities, CVE-2015-603, CVE-2017-1000494.
    12. Fixed IPSec server vulnerability, CVE-2022-40617.
    13. Improved connection speed with Verizon FIOS.
    14. Fixed IPTV compatibility issue with Movistar. Thanks to Sergio de Luz from RedesZone.net.
    https://dlcdnets.asus.com/pub/ASUS/wireless/ZenWiFi_ET12/FW_ZENWIFI_ET12_300438821739.zip
    #21938
    • Replies 8,699
    For those interested in the ASUS ZenWiFi Pro ET12 it does support 6GHz as dedicated backhaul option.
    #22421
    • Replies 8,699
    New ASUS ZenWiFi ET12 Firmware version 3.0.0.4.388.22127
    Version 3.0.0.4.388.22127
    1. Improved system stability.
    2. Fixed the IPsec VPN compatibility issue with Win10.
    3. Fixed the VPN fusion user interface issues under the HTTPS connection.
    4. Fixed Client DOM Stored XSS vulnerability.
    5. Improved Wireguard performance.
    Download:
    https://www.asus.com/networking-iot-servers/whole-home-mesh-wifi-system/zenwifi-wifi-systems/asus-zenwifi-pro-et12/helpdesk_download/?model2Name=ASUS-ZenWiFi-Pro-ET12
    #22422
    • Replies 8,699
    (Early Beta Version) not sure why, but assume changelog is explanation as VLAN on LAN has been added, which is great news ?
    New ASUS ZenWiFi Pro ET12 Firmware version 9.0.0.6.102.3506
    Version 9.0.0.6.102.3506 (Beta Version)
    2022/12/30
    Be noted: This is an early stage beta, there might be bugs. This version can be downgraded via web GUI only.
    New Features:
    1. Add Guest Network Pro:
    • Kids WiFi: Create a network for kids that blocks access to adult content and has a schedule to control when the network is available.
    • VPN WiFi: Create a VPN network that connects to 3rd party VPN services or with ASUS site to site VPN(https://www.asus.com/support/FAQ/1048281/) to encrypts your internet connection and hides your IP address to protect your online activities from being tracked or monitored.
    • IoT WiFi : Create an IoT (Internet of Things) network that blocks malicious traffic* and only allows 2.4GHz devices to connect.
    • Guest WiFi: Create a guest network with a WiFi schedule and access rights to control when and how guests can use the network.
    2. Add VLAN in LAN settings.
    3. Add Multi-services WAN, create multiple profiles on a single WAN interface.
    https://dlcdnets.asus.com/pub/ASUS/wireless/ZenWiFi_ET12/FW_ZENWIFI_ET12_300438822127.zip?
    #22529
    Nick HollandNick Holland
    • Replies 41
    Hi @UK Sentinel – I have a mesh network with three ET12 and seven XD4 all hardwired connected to a 2.5 gb switch and a 1g internet connection. The ET12’s wired nodes keep dropping connections (the ET12 as the router is OK) showing a solid red LED. This is very frustrating and I couldn’t resolve the issue. Please let me know if you get an answer from ASUS.
    There is a firmware Beta Version 9.0.0.6.102.3506 48.84 MB 2022/12/30 – do you imagine this will resolve the 388 FW issue or is it a hardware issue?
    I also have another issue with an XD4 where intermittently the 1g wired connection drops to 10/100. Is this a related issue?
    Always embrace change and new technology. Never say "I can't do that" instead say "I haven't done that before, but I'll give it a try"
    #22535
    • Replies 8,699
    I would assume this is not a hardware issue as ASUS routers are usually well made.
    I had a quick look at below link, seems the beta for ET12 you mention has no details of bug fixes, only new features, so unlikely to improve you connections
    https://www.asus.com/us/supportonly/zenwifi%20pro%20et12/helpdesk_bios/
    When I chat with ASUS next week, I will ask also for ET12
    Edit: what happens if switch is removed, any change in ET12. I assume XD4 all work Ok and are wired also via switch, apart from the connection drops to 10/100 ?
    #22573
    • Replies 8,699
    @nickholland
    So I have touched base with ASUS and explained that a few of there ZenWifi models are having Wifi and Ethernet node issues with the 388 builds and screen shotted a few comments from this forum for there reference.
    ASUS have said they would look into this but did not hint as to whether this was already a known problem to them
    #22576
    • Replies 41
    Hi @UK Sentinel,
    Thanks for the suggestions and your follow-up with ASUS. I followed your suggestion and made the following hardwired connections: ISP modem / router in Bridge Mode to ET12 in AiMesh Router Mode to ET12 in AiMesh Node Mode. The connection still failed after some hours but the LED on the node stayed white instead of red, but in the Web GUI the node was shown as disconnected. The issue with the XD4 dropping to 10/100 was also caused by the ET12. Rebooting the XD4 made no difference, but rebooting the ET12 fixed the issue. I also had issues with some IOT 2.4GHz not connecting to the nearest node, so I increased the dBm from -70 to -60 in Roaming Assistant. I also found that disabling the WMM APSD helped with the IOT connection stability. I also enabled the Reboot Scheduler to reboot every morning, but it didn’t completely resolve the ET12 node disconnection issue, so I downgraded the firmware on all three ET12s to release 386.48823 and it has been reliable so far (all the XD4s are also on release 386).
    #22578
    • Replies 8,699
    Your problem is interesting as you are on Ethernet Backhaul, with ET12 release 386.48823, are the XD4s which are on a 368 release now stable ?
    #22579
    • Replies 41
    Since the automatic reboot at 07:45 CET, the system has been stable including the XD4s on release 386.49599.
    Is it worthwhile or necessary for me to raise this issue directly with ASUS?
    #22580
    • Replies 8,699
    I may have missed this bit, but what happens if you disable the daily automatic reboot, how long does node stability last now that the ET12’s are all release 386.48823?
    #22587
    • Replies 41
    I have not tried without the daily automatic reboot since the firmware downgrade. Daily automatic reboot is now switched off and the node stability is currently 10 hours!! I will keep you informed.
    #22620
    • Replies 8,699
    Will be an interesting test and hopefully verification that the 386 build is indeed stable for wired backhaul with the ET12s  and XD4s
    #22665
    • Replies 8,699
    How has the stability been after a few days since you disabled the daily automatic reboot ?
    #22681
    • Replies 41
    The stability is great. Now 82 hours without an issue and 88 devices connected. Is it worthwhile for me to raise this as a separate ethernet backhaul issue with ASUS for release 388.22127?
