DamnWRT DSL-N14U (New Bug) I will have to throw the modem I have used for a long time in the trash. I’m about to go crazy because of these bugs. Now the connected clients…
› UKTH forums › Wireless Routers & Modems › ASUS & Wireless › DamnWRT DSL-N14U (New Bug) I will have to throw the modem I have used for a long time in the trash. I’m about to go crazy because of these bugs. Now the connected clients...
Viewing 15 posts - 1 through 15 (of 20 total)
  • #7164
    AvatarLastWarrior
    • Replies 9
    I will have to throw the modem I have used for a long time in the trash. I’m about to go crazy because of these bugs. Now the connected clients are not visible.
    Asus feedback support is very bad. I never got a return. The importance given to the customer is very low.
    After using the device for a long time (2 weeks), the client part stops working. The “Refresh” button does not work in the screenshot.
    QoS: Disabled
    Wifi: N only / 40 MHz / Auto Channel
    If I restart the device, the problem will be temporarily fixed. Also, the latest firmware still contains this issue. And system log dont show anything.
    #7166
    • Replies 8,738
    When this next happens, check the Memory (RAM) usage as other owners have highlighted a memory usage bug and it would be interesting if this was causing your Client Status problem ?
    Does this also happen if you use a different browser to access UI ?
    Latest Official Firmware is Version 1.1.2.3_805  and below link gives access to ASUS DSL new beta firmware’s – DSL-N14U_v9.1.2.3_854-g837bd26.trx which is worth a try if you have not used already ?
    https://www.asuswebstorage.com/navigate/a/#/s/EEAC28BE937F42628055856245A0B366Y
    #7168
    AvatarLastWarrior
    • Replies 9
    3 Hours passed and the problem started again
    I first noticed this issue in version 1.1.2.3_805. I later downgraded it to the previous version. (I reset by pressing the key)
    There is free space in Ram. I guess the problem is with the modem interface. Because I can see the connected devices from “System Log – Wireless Log” section. However, the “Client Status” part, which works for a while after rebooting, stops working afterwards.
    I get the same result from different devices and different browsers.
    #7170
    • Replies 8,738
    Not a RAM problem, which is good, did you try Firmware DSL-N14U_v9.1.2.3_854-g837bd26.trx ?
    #7172
    AvatarLastWarrior
    • Replies 9
    I upgraded the modem to the “DSL-N14U_v9.1.2.3_854-g837bd26.trx” version without factory reset, and the problem still persists. I will reset the modem and install it from the beginning. I will keep you posted.
    edit: add screenshot
    #7173
    • Replies 8,738
    That would be great if you could do that, if problem remains after factory reset,  I will then contact ASUS and see if they are aware of this particular bug
    Note: After factory reset, configure routers settings manually. not via a backup config file  etc.
    #7176
    AvatarLastWarrior
    • Replies 9
    Firmware: DSL-N14U_v9.1.2.3_854
    1) I reset the modem by pressing the button on the back.
    2) Now I am waiting for it to be reset. Meanwhile, I am clearing my browser’s cookies.
    3) The modem has been reset.
    4) I connected to the ASUS network.
    5) I make DSL account and Wireless SSID settings.
    6) I connected to the network with the new SSID.
    7) I reached the modem interface.
    8) “Client Status” section does not work. Refresh button does not change the result.
    Only wireless devices are available on the network. I use only 4 devices. (all wireless). DHCP selected as default.
    #7178
    • Replies 8,738
    Understood – I will speak with ASUS
    Edit: can you try a wired (ethernet) connection, just to help with bug fix.
    #7181
    • Replies 8,738
    A new firmware from ASUS, maybe worth a try
    https://www.asuswebstorage.com/navigate/a/#/s/FE1276FC46EC4F1DBFC055BCA2F284FFY
    #7187
    • Replies 8,738
    Ok, I spoke with ASUS and they tested the DSL-N14U with wireless and wired connections and all worked as expected.
    The ASUS engineer also tried your settings and still the router worked as expected
    Hopefully other DSL-N14U owners can see if they have same bug ?
    AvatarLastWarrior
    • Replies 9
    I think I found something. The “client list” crashes whenever my ip camera is connected to the network.
    While browsing the modem interface, I noticed a problem in the camera’s DHCP host name. The modem cannot read some letters :(
    [ Some characters look like this: ����� �
    in http://192.168.1.1/Main_DHCPStatus_Content.asp page ]
    And I think this will cause a crash
    #7228
    • Replies 8,738
    Yes, that does sound like a possible cause, could I ask you to screen dump the settings which shows the above �
    And also tell us what letters/characters was causing the � change originally.
    If you change the � letters and see if problem comes back, I will tell ASUS of this bug (or get/publish a list of approved characters from ASUS) and put in in the UKTechHub Wiki
    #7229
    AvatarLastWarrior
    • Replies 9
    If we look from the good side, I think we found the problem.
    But my ip camera uses a fixed hostname
    I added the screenshot to the attachment.
    modem cannot detect the “ı” character. (Latin Small Letter Dotless I) (U+0131)
    TıLGıNı-CAM →  T�LG�N�-CAM
    #7231
    • Replies 8,738
    Fixed Host-Name,
    No attachment, is filesize over 1Mb, is so try Imgur etc to post link to image
    AvatarLastWarrior
    • Replies 9
    I reduced the size of the screenshot and uploaded it again
