Dishwasher not washing (gets water but circulating it) The issue is that my old dishwasher Siemens Lady 150 doesn’t wash (meaning it is not sprinkling water). I am trying to troubleshoot what component failed Observations the bottom is…
UKTH forums 📺 White & Brown Goods DishWashers Dishwasher not washing (gets water but circulating it) The issue is that my old dishwasher Siemens Lady 150 doesn’t wash (meaning it is not sprinkling water). I am trying to troubleshoot what component failed Observations the bottom is...
  • #27895
    Avatarfonsde
    • Replies 2
    Observations
    1. the bottom is filled with water but I am not sure however, if it’s getting enough water or not. The resistance metals are not covered by water
      1. I tried adding more water manually but nothing changed
    2. Draining works fine
    3. I took the motor off, looks fine and propeller spins freely
    4. No obvious clogging
    Is the motor that does the draining the same as the one that does the circulation? I am getting a polymeter to check the components tomorrow.
    From the pictures I have access to
    1. water intake
    2. Motor
    3. there are 2 things on the left, not sure what they do. took 1 off
    • Replies 8,462
    Welcome, what model is your dishwasher ?
    #27906
    Avatarfonsde
    • Replies 2
    Hey! Siemens Lady 150 – also updated the desc.
    Messed up with the photos :/ cant remove duplicates or oversized
    • Replies 8,462
    No problem, had a quick look online and looks (not 100% guarantee) as thought the Siemens Lady 150 has a separate drain pump and a Heat Pump & Motor Assembly.
    To test water heat pump, you could use a multimeter to test the ohms (Ω -resistance) across is connectors when dishwasher is unplugged.
