DSL-AC68U – firmware 3.0.0.4.386_38832 AiMesh Node Broken DSL-AC68U – firmware 3.0.0.4.386_38832 AiMesh Node Broken Ok, so I have been speaking with ASUS as the latest DSL-AC68U firmware seems to have broken AiMesh for the nodes. ASUS have…
UKTH forums 🛜 Wireless Routers & Modems ASUS & Wireless DSL-AC68U – firmware 3.0.0.4.386_38832 AiMesh Node Broken DSL-AC68U – firmware 3.0.0.4.386_38832 AiMesh Node Broken Ok, so I have been speaking with ASUS as the latest DSL-AC68U firmware seems to have broken AiMesh for the nodes. ASUS have...
  • #8832
    • Replies 8,460
    ASUS have confirmed that DSL-AC68U when used as AiMesh nodes will not mesh with DSL-AC68U primary, (others AiMesh primaries may also be effected if DSL-AC68U are used as AiMesh nodes) not confirmed as yet.
    So ASUS have released the below beta firmware for the DSL-AC68U (AiMesh) nodes fix for nodes or just roll back to previous official firmware and AiMesh should work as expected.
    DSL-AC68U_9.0.0.4_386_39341-g4d8b015.trx  –
    DSL-AC68U_9.0.0.4_386_39341-g4d8b015.trx.zip (663 downloads )
    #8854
    RavenRaven
    • Replies 28
    Thanx!
    I’ve a network made of 3 dsl-ac68u (1 primary and 2 nodes)… I confirm that with latest firmware the nodes are broken, but is sufficient to revert to the previous version only the nodes… the “master” can use latest version…
    • Replies 8,460
    Thanx! I’ve a network made of 3 dsl-ac68u (1 primary and 2 nodes)… I confirm that with latest firmware the nodes are broken, but is sufficient to revert to the previous version only the nodes… the “master” can use latest version…
    Thanks for the confirmation
