DSL-AC68U Firmwares (beta's) etc. New Topic/Forum location where I plan to post new DSL-AC68U Firmwares (beta’s) etc. ————- DSL-AC68U AiMesh issue with Lyra series ASUS have kindly informed me that they have recently  discovered…
› UKTH forums › Wireless Routers & Modems › ASUS & Wireless › DSL-AC68U Firmwares (beta's) etc. New Topic/Forum location where I plan to post new DSL-AC68U Firmwares (beta’s) etc. ————- DSL-AC68U AiMesh issue with Lyra series ASUS have kindly informed me that they have recently  discovered...
  • #4750
    ASUS have kindly informed me that they have recently  discovered one AiMesh issue which affects all models as CAP, if On Boarding with Lyra series via WiFi then 100% it will fail.
    (UKTH)
    DSL-AC68U beta firmware with fix now available. Could post on your forum.
    DSL-AC68U_9.0.0.4_384_81451-g2429703.trx.zip
    https://www.asuswebstorage.com/navigate/a/#/s/01E2DCEAF27B46BDA1DD34E9B4FB7697Y
    #4843
    Recently  customers raised Let’s Encrypt feature failed to work issue with ASUS for the DSL-AC68U. As a result ASUS  have updated the API and added ACMEv2 support(refer to link below), ASUS have asked me if I could could share following beta DSL-AC68U firmware on my  forum (for those users who are having Let’s Encrypt issues).
    (normal ASUS Beta T&Cs apply)
    https://community.letsencrypt.org/t/end-of-life-plan-for-acmev1/88430
    DSL-AC68U_9.0.0.4_386_4918-g000b0e7.trx.zip
    https://www.asuswebstorage.com/navigate/a/#/s/D428398746FD493899386CB5D21A1D84Y
    Update: ASUS have asked me to add the following note, ‘if owners upgrade to this version without reset(and previously registered with let’s encrypt) then might need to go to Web UI > DDNS page then apply again(otherwise need to wait for retry to kick in which might take hours‘.
    #4971
    Avatarmurtyolcay
    • Replies 1
    with this new beta ( DSL-AC68U_9.0.0.4_386_4918-g000b0e7.trx.zip)
    Let’s Encrypt works again without any porblems . Thank you for sharing this.
    regards
    #4973
    [quote quote=4971]Hi, with this new beta ( DSL-AC68U_9.0.0.4_386_4918-g000b0e7.trx.zip) Let’s Encrypt works again without any porblems . Thank you for sharing this. regards[/quote]
    Glad the Let’s Encrypt fix works with this new firmware release from ASUS, I am sure others after reading this post will try this new firmware
