DSL-AC68U – Support setup as AiMesh RE node/child (Beta) ASUS have kindly given myself access to the first beta for the DSL-AC68U to now act as a Child/Node within an Aimesh configuration. ‘Note: this is a beta so normal…
UKTH forums 🛜 Wireless Routers & Modems ASUS & Wireless DSL-AC68U – Support setup as AiMesh RE node/child (Beta) ASUS have kindly given myself access to the first beta for the DSL-AC68U to now act as a Child/Node within an Aimesh configuration. ‘Note: this is a beta so normal...
Viewing 15 posts - 61 through 75 (of 80 total)
  • #5362
    • Replies 8,321
    I finally succeeded, after 3 attempts the dsl was installed as the first node, as you said the router did everything automatically. Thanks again
    I assume you tried ethernet backhaul with the DSL-AC68U as node first , which is maybe why it did not work originally  ?
    But by switching the DSL-AC68U to RT-AC68U for Ethernet, then AiMesh worked as expected because the DSL-AC68U does not support ethernet backhaul for AiMesh
    #5364
    Avataralessio51
    • Replies 10
    just like that!
    I tried again at the end of everything but as I insert the ethernet cable everything collapses, I hope in the next firmware
    • Replies 8,321
    Yes, early days for the AiMesh firmware for the DSL-AC68U, but at least we can use the DSL-AC68U as AiMesh node/child which is better than putting them in the bin
    #5713
    Avataralessio51
    • Replies 10
    hello and happy new year, the new DSL-AC68U firmware supports ethernet backhaul for AiMesh
    Thank you
    • Replies 8,321
    hello and happy new year, the new DSL-AC68U firmware supports ethernet backhaul for AiMesh Thank you
    Thanks for update, is AiMesh Ethernet Backhaul supported when DSL-AC68U router is set to Child / Node  option ?
    #5715
    Avataralessio51
    • Replies 10
    Yes
    • Replies 8,321
    That s good news, thanks for the updated news
    #5718
    • Replies 999
    Which LAN port should be used on the DSL-AC68U when setup as aimesh node?
    Is there anything to be set before it will connects as aimesh-child?
    Someone else who can commit this working?
    • Replies 8,321
    Alas my old DSL-AC68U is running RMerlin firmware, so cannot test, but issue maybe the AiMesh Primary router not having latest firmware ? what is Primary RT Model ? are there any other Nodes on AiMesh topology ?
    I am still surprised ASUS got the DSL-AC68U to support AiMesh – Node – Ethernet, so will be good if others have managed to get this to work ?
    I did notice (whilst I was testing) on my set-up that I can connect via AiMesh (wifi) and then via the Primary AiMesh wifi router change the Interface option to suit an Ethernet connection LAN 1 or LAN 4  for the Node – my set-up is via Wifi currently
    P.S are we assisting SNB Forum members again
    (pic below (not my setup) shows ‘INTERFACE’  option on far Right Lower dialogue box)
    #5724
    Avataralessio51
    • Replies 10
    I tried on lan1 but the system is still unstable. The network does not turn off but there are continuous freez … we await the next firmware bye
    • Replies 999
    Thanks, so we might have to wait.
    AvatarBoss19
    • Replies 4
    Hello @Grisu
    Coming over from the SNB forum in regards to an internet disconnect issue… noticed your PM privileges have been removed.
    In any case, regarding those commands and ATEMODE, can you provide any further insight on resolving that issue.
    Much appreciated.
    • Replies 8,321
    Welcome @Boss19, is this question relating to the DSL-AC68U (AiMesh) and please detail whole question so we can all have a look
    #5747
    • Replies 8,321
    @boss19 thread moved to Thread Moved
    #6177
    • Replies 999
    @alessio51: How did you exactly setup a DSL-AC68U as Aimesh-child node with ethernet backhaul step by step?
    Master doesnt find ethernet connection to it for mesh-pairing. If you first set LAN1 as WAN it will be reset after pairing and again using Wifi as backhaul.
