help needed with asus tuf ax4200 Hi i have the asus tuf ax4200 would like to use it as a replacement for my eero6+ router supplied by giffgaff on a 500 mbps plan. signal slows to…
› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › help needed with asus tuf ax4200 Hi i have the asus tuf ax4200 would like to use it as a replacement for my eero6+ router supplied by giffgaff on a 500 mbps plan. signal slows to...
Viewing 15 posts - 1 through 15 (of 18 total)
  • #42772
    Avatarreptile11
    • Replies 10
    Hi i have the asus tuf ax4200 would like to use it as a replacement for my eero6+ router supplied by giffgaff on a 500 mbps plan. signal slows to 50mbps as i move around the house due to frquency changing from 5ghz to 2.4ghz.
    I think giffgaff require Vlan setting 911. Is there a workaround such as putting eero6+ in bridge mode or should i change asus router entirely
    #42775
    Welcome, Your ASUS TUF‑AX4200 will work fine as a full replacement for the Eero 6+ if you set VLAN ID 911 on the WAN.
    Giffgaff broadband runs on the same platform as Virgin Media O2 wholesale FTTP services and typically requires VLAN ID 911 on the WAN connection and WAN Connection Type is set to Automatic IP (DHCP)
    Not sure on you specific router model, but generally ASUS routers have the following option;
    check:
    LAN → IPTV settings
    Look for:
    • ISP Profile = Manual
    • Internet VLAN ID = 911
    • This reply was modified 5 months, 1 week ago by UK SentinelUK Sentinel. Reason: WAN reference changed to LAN
    #42776
    Avatarreptile11
    • Replies 10
    hi, no such setting on this asus tuf ax4200 cant change to Vlan911
    #42777
    Apologies, I meant LAN → IPTV settings
    Avatarreptile11
    • Replies 10
    nope nothing. All i have is
    LAN>IP Binding
    • This reply was modified 5 months, 1 week ago by Avatarreptile11.
    #42783
    Sounds like your router is set to Access Point mode, not Router mode.
    Need to change it back to Router mode,
    Administration > Operation Mode > Wireless Router Mode, click apply and reboot.
    #42784
    Avatarreptile11
    • Replies 10
    hi found in ‘about my router’.operation mode >set as wireless router mode. was set to this anyway
    #42786
    Strange as the ASUS specs details IPTV is supported, does your Advanced Settings / LAN page look like anything like this ?
    https://www.asus.com/uk/networking-iot-servers/wifi-routers/asus-gaming-routers/tuf-gaming-ax4200/techspec/
    #42788
    Avatarreptile11
    • Replies 10
    nothing like that
    #42789
    This video shows the ASUS TUF AX4200 and go to 14:25 minuites and you can see the LAN page options.
    If you cannot see these on your router and your are running the latest ASUS firmware for this router, a factory reset is advisable.
    #42790
    Avatarreptile11
    • Replies 10
    hi thanks for the video i will go through it all later on. One problem i see straight away is on set up …connecting to the internet. I cant without Vlan setting. firmware is 3.0.0.4.388_34011 which i think is too old and does not support Vlan
    think i need 3.0.0.6 firmware
    #42793
    3.0.0.4 firmware as per the video supports IPTV which is where you will add 911.
    Giffgaff is not preset on ASUS routers wizard as a preset option unlike Sky and BT, you have to in essence bypass the setup wizard and enter the VLAN ID via IPTV manually.
    Personally I would just run through the ASUS setup Wizard via computer browser (not app) and configure it with your SSID’s etc, and configure it for say BT, which uses no VLAN’s for Full Fibre connections , after you have configured the router, quickly go to the LAN page > IPTV and add 911
    I.e.
    • Add;  LAN → IPTV → Internet VLAN ID → 911
    • Apply
    • Change; WAN → Automatic IP (DHCP) (was set to PPPOE after BT setup)
    • Apply
    • Reboot router
    ISP Network WAN Type VLAN Required? Notes
    BT FTTP Openreach PPPoE ❌ No ONT strips VLANs; router receives untagged PPPoE
    Giffgaff FTTP CityFibre Automatic IP (DHCP) ✅ Yes (911) No PPPoE, no Option 61, no credentials
    #42794
    Avatarreptile11
    • Replies 10
    wow thanks  just to be clear the process is as follows:
    disconnect eero router
    connect asus router with ethernet cable then connect router to laptop with ethernet cable
    search for 192.168.50.1 online ( if i can get access to the internet)
    then set up router
    is this correct?
    rep
    #42795
    Yes, in essence,
    1. Disconnect the Eero completely
    Unplug its Ethernet from the ONT.
    2. Connect the ASUS to the ONT
    • ONT → ASUS WAN port (blue port)
    3. Connect your laptop to the ASUS Router
    Use Ethernet into any LAN port (yellow ports). (Wi‑Fi also works, but Ethernet is safer during setup.)
    4. Open your browser and go to:
    192.168.50.1 This works without internet, it’s the router’s local address.
    If it doesn’t load, try:
    #42801
    Avatarreptile11
    • Replies 10
    Hi great help I’ve got to here
    Think I’ve configured it clicked: advanced>lLAN>IPTV
    what do I do now, sadly can’t see in video on phone
