New FTTP order placed So following on from my new build dilemma, after contacting openreach and BT several times I checked online today and I can now place an order!  I was considering Zen…
› UKTH forums › Broadband Tech & ISP’s › BT › New FTTP order placed So following on from my new build dilemma, after contacting openreach and BT several times I checked online today and I can now place an order!  I was considering Zen...
  • #1126
    AvatarRetired Account
    • Replies 19
    So following on from my new build dilemma, after contacting openreach and BT several times I checked online today and I can now place an order!  I was considering Zen but for the top package 300mbps download was £72 per month, I decided to go with BT instead same speed for £55 per month.  I will get cashback and a reward card for my order so can’t be all bad, they are sending me a HH6 but I will be using my 3490 :)
    #1128
    £55 sounds a good price for FTTP, I had read via ISP Preview that BT had cut back on its deployment plans for G.fast in favour of FTTP, so looks like you got onto the bandwagon, just Intime ;)
    I assume you will also be getting a Huawei / ECI Modem (suitable for fibre) from BT, to plug into your Home Hub 6 or Fritz!Box?
    ISPReview
    #1130
    • Replies 19
    There is an ONT installed at the new property (see attached) They are sending me a Home Hub 6 but i’m going to be using the FRITZ!Box :)
    #1132
    I have learnt something new today, ;)
    #1135
    • Replies 19
    First time plugging the Home Hub in, ran a quick speed test.  At least there is some internet there, I have not moved in yet.  When I do the FRITZ! Box gets plugged back in :)
    https://www.speedtest.net/my-result/a/4338978460
    #1141
    [quote quote=1135]First time plugging the Home Hub in, ran a quick speed test. At least there is some internet there, I have not moved in yet. When I do the FRITZ! Box gets plugged back in 🙂 https://www.speedtest.net/my-result/a/4338978460[/quote]
    Nice, I like the ping also, it will be interesting to see how well the Fritz!Box compares ;)
    #1183
    @ryan806 – did you manage to get the Fritz!Box working and if so, did you have any issues with VLAN (802.1q) ? was it needed?
    #1299
    • Replies 19
    [quote quote=1183]@retired account – did you manage to get the Fritz!Box working and if so, did you have any issues with VLAN (802.1q) ? was it needed?[/quote]
    Hi.  I have just switched over to the 3490 today, It’s working with out inputting the VLAN ID but speeds are all over the place?  Maybe I have done something wrong?
    I put in username as bthomehub@btbroadband.com
    Password was left blank
    I had to manually put in the download speeds (see attached screens)
    #1306
    Thanks, from those settings, you are on 100Mbps ?
    #1308
    • Replies 19
    [quote quote=1306]Thanks, from those settings, you are on 100Mbps ?[/quote]
    Hello.  Yes I had changed that to 300mbps, I had done that after i took the screenshot.  I ran a few tests and on my PC which has one of these. https://www.asus.com/uk/Networking/PCE-AC55BT/
    Speeds were just over 300mbps down and 60mbps up which is what i expected, but using a direct connection with ethernet its under 40mbps download and around 60mbps upload?
    #1315
    Might be a restriction via Fritz!Box, what’s your Ethernet cable connecting to?
