› UKTH forums › Wireless Routers & Modems › ASUS & Wireless › Nokia 8 usb tethering HI guys Bit of a Mystery – I am trying to USB tether my Nokia 8 (latest patch on 8.1.0) to my asus router in a vehicle.. its an Asus...
- This topic has 3 replies, 2 voices, and was last updated 8 years, 1 month ago by
October 6, 2018 at 4:44 pm #1029
HI guys
Bit of a Mystery – I am trying to USB tether my Nokia 8 (latest patch on 8.1.0) to my asus router in a vehicle.. its an Asus DSL-N55U c1and basically the tethering doesnt work.. it’s running the latest beta .572 ( I have tried several)
If i plug my wifes Sony Z2 it works fine.. straight away.. no issues.
Nokia – not a blink of anything – basically it seems that the asus finds the sony and hotplug does its thing to create the usb as an ethernet connection for the WAN – with the nokia it just stops at the add high speed device.
I’m sure that VF Aus dont limit USB tethering.. based on that it works fine on my windows 10 laptop!
log extract from the nokia connecting
2011-01-01 08:04:44 kernel: usb 1-1: new high speed USB device using rt3xxx-ehci and address 14
2011-01-01 08:04:45 kernel: usb 1-1: configuration #1 chosen from 1 choiceit never gets to the hotplug entry that the sony does… that was the end of the log after switching tethering on
the sony looks like
2011-01-01 08:02:10 kernel: usb 1-1: new high speed USB device using rt3xxx-ehci and address 3
2011-01-01 08:02:10 kernel: usb 1-1: configuration #1 chosen from 1 choice
2011-01-01 08:02:10 kernel: usb0: register ‘rndis_host’ at usb-rt3xxx-1, RNDIS device, 02:10:05:6c:01:7d
2011-01-01 08:02:11 hotplug: add net usb0.
2011-01-01 08:02:12 hotplug: Got net usb0, vid 0xfce, pid 0x71af.
2011-01-01 08:02:13 hotplug: set net usb0.
2011-01-01 08:02:17 WAN(11) Connection: Wan link upInterestingly this also happens on my RT ac68u (Merlin) no USB fallback same log entry…
Anyone got a Nokia 8 to try?
Steve
October 6, 2018 at 5:40 pm #1030So you have set up as follows:
In Advanced WAN: Dual WAN
Enable Dual WAN – On
Primary WAN – WAN
Secondary WAN – USB
Dual WAN mode – Fail OverIn Advanced WAN: Internet Connection
WAN Type – USB
Enable USB Modem – Yes
Location – ManualThen enable Tethering on your USB Tethering on Phone after plugging in USB cable.
I realise you say, you had this working for the Sony, but if this does not work, then I assume the Router does not support this phone, maybe try an much older router firmware just for testing purposes ?
Was Sony cable and Nokia Cable the same, or are they different, maybe try a second Nokia USB cable ?
To test Nokia Tehering, can you tether your Nokia via a laptop etc. and does it work?
FYI -Does not support iPhone either (or at least did not last time I tested), so a workaround can be found here?
October 7, 2018 at 1:35 am #1032[quote quote=1030]So you have set up as follows:
Primary WAN – WAN
Secondary WAN – USB
WAN Type – USB
[/quote]
Nope even simpler – under WAN – type USB – and then android phone – so its the primary WAN and dual WAN is disabled. (for the DSL-N55u) on the RT-AC68u however then yes I tested it this way.. with the same result.
[quote quote=1030]
[/quote]
Tried the release firmware with same result – with android tethering there should be no support required – its vanilla android same as the pixel etc..
[quote quote=1030]
[/quote]
Yep 2 different cables for the nokia – and as the nokia and sony use different connection (USB C and micro usb) they were not the same.
[quote quote=1030]
[/quote]
Yep works fine..
[quote quote=1030]
FYI -Does not support iPhone either (or at least did not last time I tested), so a workaround can be found here?[/quote]
Noted – but I’m not buying additional hardware – its purely for a local network on a vehicle with the bonus of internet when the phone is plugged in – if I go that route i’ll just buy a usb modem
Thanks for your help :)
Steve
October 7, 2018 at 8:29 am #1033@ 5teve, no problem, alas with an ASUS router and Nokia. it appears your aptions are limited.
Alas I am iPhone, so cannot test ;)
