› UKTH forums › PC & Laptop Gaming › Gaming Monitors › Which is better LED or LCD monitor for gaming There are a few different types of monitors on the market, however the most popular by far are LED and LCD monitors. But what is the difference between these two...
- This topic has 2 replies, 2 voices, and was last updated 5 years, 9 months ago by
Grisu.
February 13, 2021 at 7:02 am #11911
There are a few different types of monitors on the market, however the most popular by far are LED and LCD monitors. But what is the difference between these two types of displays?
Well, there are some subtle but quite significant differences between products, which could influence your buying decision. However, in short: LCD is aĀ typeĀ of LED display.Ā Not all LED displays are LCD, but all LCD are LED.
Read on:
LED vs LCD Monitors
Both LCD and LED are often confused for each other. Itās best to start by explaining what each of them stand for, and what they actually do.LED stands for light-emitting diode and LCD for liquid crystal display. The actual name for LCD should be āLED-lit LCD displayā, but it is normally shortened to just LCD.
These names reference the way that they work, however all LED screens are LCD screens; LED screens just have an extra functionality that makes them work slightly differently.
LED screens are named so because of the light-emitting diode lights that are installed in the screen themselves. These screens can be volatile or static; some of them will only respond to touch and others will display a picture even when they are turned off.
There are benefits to these types of monitor, like a better quality picture. Another potential benefit is local dimming. The local dimming feature essentially dims down the certain areas of the backlight of your television. This can make the screen itself appear darker, and better at producing blacks.
How are LCD monitors different?
The main difference is that LCD screens feature a layer of liquid crystal. This is put in between two plates, and images are made by light passing through parts of liquid crystal.Older LCD screens used CCFLs, or Cold Cathode Fluorescent Lamps, to light the screen. These use electron discharge and fluorescence to illuminate a screen behind them. However, LEDs have taken over from CCFLs because they are brighter, last longer, leave higher quality images and are more environmentally friendly.
This means that LCD screens lit with CCFLs (known also as LCD screens or monitors) are fading from importance in the market, and LED screens are becoming more and more popular.
So is LED better than LCD for Gaming ?
There are different types of monitor which are better for different things. But if weāre talking in terms of monitors, then yes, and LED monitor is definitely going to be better. An LED monitor will typically give you;Better ColourĀ ā An LED monitor will give you better colour and contrast on the screen, which in turn give you a sharper image.
Longer life āĀ LCD monitors last on average 30-50,000 hours. LED monitors however last anywhere between 50,000-100,000 hours.
Cheaper to run āĀ LED are the better choice if youāre trying to keep costs down, as they are more energy efficient of the two. However, they are more expensive, so you will have to lay out more initially.
Slimmer design āĀ We can make LED monitors in a thinner, slimmer design than an LCD monitor.
Better resolution and response time āĀ If youāre often going to be playing games of watching videos, youāll want to get an LED monitor as they will give you a more responsive display.
February 13, 2021 at 7:11 am #11912OLED vs. QLED Monitor Screens
Want to get more granular in your choice of LEDs? New screen technology typically hits the TV market first, but trickles down to computer monitors in short time. Two new such monitor types are OLEDĀ ā Organic Light Emitting DiodeĀ ā and QLEDĀ ā Quantum Light Emitting Diode.Every pixel in anĀ OLED monitorĀ is its own miniature LED light. Unlike regular LED monitors, OLED monitors arenāt technically backlit because each pixel produces its own light and color. If an individual pixel doesnāt receive electricity, it will appear dark. OLED technology offers amazing picture contrast as a result. And because each pixel is individually lit, OLED has an incredibly low response timeĀ ā 0.1 millisecond ā that is great for crisp images and gaming.
QLED monitorsĀ use nanoparticles called quantum dots that act as color and light filters. Millions of quantum dots can produce stunning displays of brightness and color. QLEDs offer full color saturation even in brightly-lit rooms. But the downside is that QLEDs have to dim their backlights for dark colors, which makes it difficult to produce a pure black effect like on an OLED. QLED monitors are also best viewed from dead center, so they might not be the best choice for workspaces that need wide viewing angles.
OLED – ‘but not cheap’
February 13, 2021 at 5:26 pm #11917 -
