- July 25, 2022 at 6:23 am #20300July 25, 2022 at 7:32 am #20301
[quote quote=20299]
Did the latest firmware work with IPv6 ?[/quote]
No, none of the beta versions worked with IPv6.
July 25, 2022 at 9:21 am #20302[quote quote=20301]No, none of the beta versions worked with IPv6.[/quote]
Do you have another modem/router that does work with IPv6, for testing ?
Can you show us your WAN > Internet Connection page and General > Network Map > Primary WAN
July 25, 2022 at 9:54 am #20303[quote quote=20302]
Do you have another modem/router that does work with IPv6, for testing ? Can you show us your WAN > Internet Connection page and General > Network Map > Primary WAN[/quote]
I don’t have any other modems to test. I make the settings given by the internet service provider for IPv6. So there is nothing wrong with the settings. The problem is either in the modem or my internet service provider. Works fine on random modems. I just wanted to test new beta versions but it didn’t work.
July 25, 2022 at 10:23 am #20304Is your DSL-N16 set to dual stack IPv4/IPv6 ? is issue WAN IP not being IPv6 or LAN Clients ? or both ?
Have you tried toggling between Stateless and Stateful under IPv6 LAN Settings if issue is LAN ?
Note: I have not seen any body else with IPv6 issues within your region, so am wondering if issue is DSL-N16
@tsunami – does IPv6 work in your location for DSL-AC51 ?You need to login in order to vote
July 25, 2022 at 10:54 am #20305[quote quote=20304]Is your DSL-N16 set to dual stack IPv4/IPv6 ? is issue WAN IP not being IPv6 or LAN Clients ? or both ? Have you tried toggling between Stateless and Stateful under IPv6 LAN Settings if issue is LAN ? Note: I have not seen any body else with IPv6 issues within your region, so am wondering if issue is DSL-N16 @tsunami – does IPv6 work in your location for DSL-AC51 ?[/quote]
Yes it is set to dual stack. Modem defines IPv6 addresses to devices on local network. I can see IPv6 addresses when I check from devices. But I can’t access the internet with IPv6. Windows says no internet in network status (IPv6). IPv6 not supported in tests either.
July 25, 2022 at 11:24 am #20306July 25, 2022 at 11:43 am #20307July 25, 2022 at 12:15 pm #20308[quote quote=20307]Yes, we are both TurkNet customers. He’ll probably say it’s not working. :)[/quote]
Interesting, if that is the case, then I need to chat with ASUS to see if there are any issues with TurkNet (IPv6)
July 25, 2022 at 12:43 pm #20309[quote quote=20308]
<noscript>
</noscript>[/quote]Then I’m waiting to hear from you. :)
July 26, 2022 at 8:50 pm #20315July 27, 2022 at 6:11 am #20316[quote quote=20315]i changed my iss so i dont use ipv6 now but ipv6 was working when i was in Turknet.[/quote]
Great news, thanks
July 27, 2022 at 6:14 am #20317July 27, 2022 at 7:41 am #20318[quote quote=20317]
@TSuNaMi DSL-AC51 worked for IPv6 when he was using TurkNet, maybe send a feedback form to ASUS and asked if they can have a look at config etc, and detail you spoke with ‘UK Sentinel’ ?[/quote]
I have contacted Asus twice before. Turkish support team asked me to downgrade, but unfortunately none of the versions work with IPv6. I also sent a feedback from the modem interface, but I did not get any results. They don’t “shake” end users much. :)
July 27, 2022 at 7:44 am #20319 - AuthorPosts
