- This topic has 1,438 replies, 106 voices, and was last updated 5 months, 3 weeks ago by
alt.james.
- September 14, 2019 at 10:15 pm #4407
Black Bird wrote:
UK Sentinel wrote:
camaran wrote: kittuk wrote: Could someone pm me the current beta firmware for the dsl-ac88u please. K if is available me also PM Sent
can you please send it to me
PM SentThank you, the newer version hasn’t been released for a long time. Do you have any new information on this?
September 15, 2019 at 7:14 am #4414I spoke with the ASUS DSL team Earlier this week and November is now the time they expect the new firmware to be released
Some of the issues with the current (last years) firmware release does have work arounds, so if anything in particular causing issues, let us know
September 15, 2019 at 5:27 pm #4428September 15, 2019 at 5:38 pm #4430Could you share the latest beta? Thanks in advance!
Alas no new firmware from ASUS – last one was back in January , but was later removed.
The latest is 1.10.06_Build591 but some are finding Version 1.10.05_Build503 from ASUS download servers more stable
September 15, 2019 at 5:54 pm #4431What is better in fw 1.10.05_Build503?
My original fw was v1. 10.5 build 502, but I didn’t even run on this one just updated to latest…
Now wonder if different fw may have different dsl drivers?
Edit
I can see that build 502 and 503 was with previous dsl driver. Is there a chance to get these with telnet unlocked? Pretty please :)
September 15, 2019 at 6:45 pm #4434@Mrk26 – Alas no with regards to Telnet for older firmware, I have to pull favours from ASUS and favours are limited
From Memory, Older firmware had less memory loss issues (AiProtection), and more stable wifi and DSL disconnects less often, I believe.
September 15, 2019 at 7:28 pm #4435Of course favours may be needed in future :D.
I thought you may have these already, in that case not problem, I may try locked one sometime. Only issue I have is related to amount of errors that is why I think it maybe related to dsl fw. I read somewhere that newest dsl driver from broadcom is more friendly for G.fast than standard vdsl. Apparently older broadcom driver was better for vdsl connection.
September 15, 2019 at 8:01 pm #4442Is it a one chip solution for G.fast and vdsl? I have seen other modems where they use 2 seperate chips with a small relay to switch from one to the other. They can use best driver for each chip and so less dependant on manufacturers driver.
September 15, 2019 at 8:09 pm #4444Of course favours may be needed in future :D. I thought you may have these already, in that case not problem, I may try locked one sometime. Only issue I have is related to amount of errors that is why I think it maybe related to dsl fw. I read somewhere that newest dsl driver from broadcom is more friendly for G.fast than standard vdsl. Apparently older broadcom driver was better for vdsl connection.
Indeed ;-) I have not had anything from ASUS to suggest older Firmware Drivers are better than newer for VDSL, but does sound plausible.
September 15, 2019 at 8:18 pm #4447That is the problem, all industry focus on latest tech so this what is from previous age (vdsl) it’s left behind. By focusing on polishing g.fast they not necessary do better for vdsl..
I already got previous fw for dsl-ac88u so just need to force myself to use one without telnet and probably sometime next week I will have a go ;-)
September 15, 2019 at 8:29 pm #4450That is the problem, all industry focus on latest tech so this what is from previous age (vdsl) it’s left behind. By focusing on polishing g.fast they not necessary do better for vdsl.. I already got previous fw for dsl-ac88u so just need to force myself to use one without telnet and probably sometime next week I will have a go ;-)
Let us know how it goes
September 18, 2019 at 6:27 pm #4486TSome of the issues with the current (last years) firmware release does have work arounds, so if anything in particular causing issues, let us know
I can’t activate my phone as a usb modem. It doesn’t trigger the Internet.
September 18, 2019 at 7:52 pm #4488TSome of the issues with the current (last years) firmware release does have work arounds, so if anything in particular causing issues, let us know
Did you own an ASUS router before, and if so did the USB modem option work with your phone?
What model phone is it?
Update: I contacted ASUS and they say – Indeed supported, however, only limited models. What’s the make and model of target USB modem/phone ?
September 19, 2019 at 6:36 pm #4499TSome of the issues with the current (last years) firmware release does have work arounds, so if anything in particular causing issues, let us know
Did you own an ASUS router before, and if so did the USB modem option work with your phone? What model phone is it? Update: I contacted ASUS and they say – Indeed supported, however, only limited models. What’s the make and model of target USB modem/phone ?
I have never used an asus modem before. Mobile phone is android operating system. Samsung Galaxy S7 Edge. It recognizes the phone as USB Ethernet but does not use the internet. While doing this experiment, DSL sometimes stops working on the Internet.
September 20, 2019 at 8:07 am #4501@Black Bird, I spoke with ASUS and they say you phone is not supported, from what I call, most phones are not officially supported,
This is one of the areas ASUS could do so much better in, but they do support USB modems well.
I seem to recall (I will check later as out at the moment) that you maybe be able to use an external Wifi/USB bridge or old ASUS Router to plug phone in and then connect to router ?
I am afraid in this case USB Tethering needed which is not supported by this phone model.
