ASUS DSL-N16 Emulator   After speaking with ASUS, I have finally managed to obtain an emulation for the DSL-N16 (yes, an older model) but its a start ;-) It seems to mostly work,…
› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › ASUS DSL-N16 Emulator   After speaking with ASUS, I have finally managed to obtain an emulation for the DSL-N16 (yes, an older model) but its a start ;-) It seems to mostly work,...
  • #3005
    • Replies 8,707
    It seems to mostly work, Only noticed that if you change WAN > Transfer Mode > from Ethernet to VDSL causes the package to fail and General Log / Wireless Log page does not load correctly so will sort it out over the next week or so .
    Also added the emulator for the ASUS RT-AX88U
    DSL-N16 Emulator  (Link removed)
    RT-AX88U Emulator
    I might create a separate folder which contains Router emulators from different manufactures, and will post a link to it via this post
    Update: Done
    Link to Modem / Ruoter Emulators
    #9092
    AvatarItsmeryan
    • Replies 3
    Hello, I was hoping you might be able to send me a copy of the emulated for the n16 would be a big help!
    #9095
    • Replies 8,707
    Welcome, I was provided this by ASUS, so I shall have a chat with ASUS ?
    #9097
    AvatarItsmeryan
    • Replies 3
    Thank you, I have tried however they don’t seem to understand what I am asking for unfortunately, I appreciate the response
    #9098
    • Replies 8,707
    I will email you if I hear back from ASUS, I will close this thread as this is not applicable any more
    #9146
    • Replies 8,707
    — This Topic is Closed —
  • The topic ‘ASUS DSL-N16 Emulator   After speaking with ASUS, I have finally managed to obtain an emulation for the DSL-N16 (yes, an older model) but its a start ;-) It seems to mostly work,...’ is closed to new replies.
