› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › ASUS ZenWiFi BQ16 BE25000 Whole Home Quad-Band Mesh WiFi 7 System I took the plunge and bought the 2 pack BQ16 and put the 3 pack BT10 on sale for £650. Been using them for the past 2 days. It came...
- This topic has 83 replies, 5 voices, and was last updated 7 hours, 26 minutes ago by
MultiDoc.
- October 4, 2026 at 2:55 am #43866
The built in speedtest in the web GUI looks borked now. Hopefully the fix is included in the other models and will come to the BQ16 soon.
October 4, 2026 at 1:17 pm #43867ASUS are currently making changes to the built-in Speedtest feature across their routers. No word on a BQ16-specific fix, but I’d keep an eye on upcoming firmware releases.
October 15, 2026 at 12:31 pm #44411ASUS ZenWiFi BQ16 Firmware version 3.0.0.6.102_39441
Version 3.0.0.6.102_39441
62.03 MB
2026/10/15This update includes a required change for the Speedtest service. If Speedtest is supported on your model, you must install this update to continue using it. Please refer to Speedtest Service Announcement for details.
Security Fixes
AiCloud: Strengthened the data handling mechanism for the network neighborhood host list.
AiCloud: Improved how share link identifiers are generated, and adjusted the file and disk information query process.
AiCloud: Strengthened authentication and path validation for remote file access.
VPN and account authentication services: Adjusted the handling of connection settings and account data, with stricter parameter validation.We recommend updating to this version to maintain optimal protection.
ZIP SHA-256 : D7690CBBDE1EFD79450A8DC0CC0A0418CDFF7ADB90EDF8AB64AFF3700D158832
FW SHA-256 : ACA7A90733F7891758B5FE13F4E15FA9A9C577D77706CCBDE368CE1243867DE4Download:
(Copy the link and paste it into your browser.)
Looks like a significant FW update
This reply was modified 1 day, 12 hours ago by
dodgydrains.
October 15, 2026 at 8:12 pm #44413
October 15, 2026 at 8:52 pm #44414Thanks for this, but checking either through the phone app and/or the browser, it says there’s no update available and that I have the latest firmware already (first time this happens). In any case I’ll do a manual update.
Appreciate it, thanks!
October 15, 2026 at 9:13 pm #44415The download can also be located here for a manual download.
October 15, 2026 at 11:47 pm #44416. MultiDoc Said:Thanks for this, but checking either through the phone app and/or the browser, it says there’s no update available and that I have the latest firmware already (first time this happens). In any case I’ll do a manual update.
Let us know how you get on. I am testing Reaper beta firmware, helping as much as I can to get it stable.
October 15, 2026 at 11:51 pm #44417I am not familiar with the Reaper, any info ? I have only been using ASUS’s firmwares and I haven’t had any issues so far and the mesh system has been rock stable since day one for me (2 x BQ16’s and a BD4 Outdoor). I’ll manualy update the firmware tonight and post if any issues.
October 16, 2026 at 5:44 pm #44434 -
