Viewing 15 posts - 1,066 through 1,080 (of 1,421 total)
  • #25363
    Jim W
    • Replies 8
    Running Firmware Version:3.0.0.4.388_23012, I have the same problem – the node will drop back to 2.4GHz once or twice per week. Id like to know more about your comment re. DFS channels, unticking the include box, and Smart Connect. What do you recommend and how do these settings affect the node dropping back to 2.4 GHz?
    Here are some of my backhaul settings – if anyone spots something amiss, please let me know!
    #25366
    Welcome, might be good if you could check your system log and see if there is any mention of ‘Radar detected‘ as this would indicate DFS radar detection is in action.
    You might try the latest firmware version 3.0.0.4.388.23285 on AiMesh master and nodes, response from others is mixed:
    • Hard factory reset all and build from scratch (not back-up config)
    https://www.asus.com/support/FAQ/1046973/#:~:text=1
    Then try the below one at a time and test.
    • Set 80 MHz on the backhaul if possible
    • Select Non DFS channel 5GHz-2 for backhaul
    • Disable Smart Connect
    • Disable guest network
    • Disable WMM APSD (automatic power save delivery)
    • Disable 5Ghz roaming assistant
    Most of this you have already achieved and another option to consider is Modulation Scheme could be lowered depending on what you main connections speeds are.
    Only other area to check is the 5GHz-2 backhaul wifi signal strength between the AiMesh nodes to ensure the value of -50 to -60dBm shows a good connection but anything higher and the AiMesh node maybe to far away for stable connection.
    Note: If you do wish to persist with 160Mhz, set protected management frames to capable.
    #25388
    Jim W
    • Replies 8
    Hello UK Sentinel,
    Thank you for your detailed reply. I checked my General Log and found no indication of DFS or Radar. But when I checked my Wireless Log, I found the following (but I’m afraid I don’t know how to interpret this):
    Following are details for 2.4 GHz:
    SSID: “Heart of Gold2.4”
    noise: -87 dBm Channel: 10
    BSSID: D4:5D:64:8B:61:20 Capability: ESS ShortSlot RRM
    Supported Rates: [ 1(b) 2(b) 5.5(b) 6 9 11(b) 12 18 24 36 48 54 ]
    HE Capable:
    Chanspec: 2.4GHz channel 10 20MHz (0x100a)
    Primary channel: 10
    HT Capabilities: 40Mhz SGI20 SGI40
    Supported HT MCS : 0-15
    Supported VHT MCS:
    NSS1 Tx: 0-11 Rx: 0-11
    NSS2 Tx: 0-11 Rx: 0-11
    Supported HE MCS:
    80 Mhz:
    Interference Level: Acceptable
    Mode : AP Only
    Following are details for 5 GHz-1:
    SSID: “Heart of Gold”
    noise: -88 dBm Channel: 44/80
    BSSID: D4:5D:64:8B:61:24 Capability: ESS RRM
    Supported Rates: [ 6(b) 9 12 18 24(b) 36 48 54 ]
    HE Capable:
    Chanspec: 5GHz channel 42 80MHz (0xe22a)
    Primary channel: 44
    Supported VHT MCS:
    Supported HE MCS:
    80 Mhz:
    Mode : AP Only
    DFS status: state IDLE time elapsed 0ms radar channel cleared by DFS none</p>
    Following are details for the backhaul 5 GHz-2:
    SSID: “96D8D99FA6AD79135C46647FA0D3B750”
    noise: -88 dBm Channel: 100/80
    BSSID: D4:5D:64:8B:61:28 Capability: ESS RRM
    Supported Rates: [ 6(b) 9 12(b) 18 24(b) 36 48 54 ]
    HE Capable:
    Chanspec: 5GHz channel 106 80MHz (0xe06a)
    Primary channel: 100
    Supported HT MCS : 0-31
    Supported VHT MCS:
    NSS3 Tx: 0-11 Rx: 0-11
    NSS4 Tx: 0-11 Rx: 0-11
    Supported HE MCS:
    80 Mhz:
    160 Mhz:
    Mode : AP Only
    DFS status: state In-Service Monitoring(ISM) time elapsed 53676600ms radar channel cleared by DFS channel 100/80 (0xE06A)
    Channel Information
    Channel 100 A Band, RADAR Sensitive
    Channel 104 A Band, RADAR Sensitive
    Channel 108 A Band, RADAR Sensitive
    Channel 112 A Band, RADAR Sensitive
    Channel 116 A Band, RADAR Sensitive, Passive
    Channel 120 A Band, RADAR Sensitive, Passive
    Channel 124 A Band, RADAR Sensitive, Passive
    Channel 128 A Band, RADAR Sensitive, Passive
    Channel 132 A Band, RADAR Sensitive, Passive
    Channel 136 A Band, RADAR Sensitive, Passive
    Channel 140 A Band, RADAR Sensitive, Passive
    Channel 144 A Band, RADAR Sensitive, Passive
    Channel 149 A Band
    Channel 153 A Band
    Channel 157 A Band
    Channel 161 A Band
    Channel 165 A Band
    Channel 169 A Band
    Channel 173 A Band
    Channel 177 A Band
    Stations List
    idx MAC Associated Authorized RSSI PHY PSM SGI STBC MUBF NSS BW Tx rate Rx rate Connect Time
    24:4B:FE:74:01:B8 Yes Yes -52dBm ax No Yes Yes Yes 4 80M 1621.3M 1621.3M 14:52:47
    I’m afraid there’s much I don’t understand about how to configure this mesh system! It would be really great if there were a book/tutorial for configuring wifi networks using 5 GHz and mesh.
    I’ve not yet updated the firmware or made the changes you suggest, but will follow up when I do.
    Best Regards,
    Jim
    #25390
    @Dodgydrains over to you hopefully as you are our resident XT8 guro
    #25400
    • Replies 634
    I am no expert, just like tinkering around and updating my XT8’s .  I am not very upto speed on these logs.  Do you live in the UK, the reason I ask is that you seem to have additional channels on the 5GHz-2 that I think are only available in the US model.
    Have you tried checking your PHY rate?  (see attachment).  All mine have a PHY rate above 2,000Mbps.
    My XT8’s were previously dropping to 2.4GHz due to placement of one of my XT8 next to a fridge which was most probably causing interference.  Also due to a damaged extenstion cord.
    Can you check on the android/ios app check the RSSI.  I made sure all my XT8’s have RSSI below 65 dBm.  This also stabilised my mesh, so much so that I am now on 36 days 18 hour(s) 25 minute(s) 31 seconds on 160MHz – Channel 100 wothout a single hiccup that I have noticed.  This is on FW 23285.
    #25847
    Jaime Salud CastilloJaime Salud Castillo
    • Replies 36
    Hi Jim. Had the same pesky problem for months until I’ve found the most stable settings that worked for me.
    I’ve set up my 5ghz-2 settings to:
    • AX only
    • Wifi6 enabled
    • Channel Bandwidth 80mhz
    • Control Channel Auto
    Btw, am using the latest firmware and this setting works perfectly (at least for me).  Been over a month and the 2nd node never reverted to 2ghz (weak signal).
    Hope this helps
    Please refer to the screenshot below for a better view:
    #25852
    • Replies 634
    After around 57 days devices were able to connect wirelessly to the mesh network but no web pages were loading ‘connected-no internet’.  Could not even log into the router UI to check stats.
    Restarted the main node and everything was fine again. Anything I should look out for in the logs?  It happened between 11am-12.30pm.
    #26027
    Great up time that was, more than likey DFS or memory related issue.
    I forget what build you are using, but the 388 are still have memory leak issues
    Is DFS disabled on your AiMesh Primary, if not then there maybe a log entry pertaining to ‘Radar detected‘ .
    #26028
    • Replies 634
    No mention of radar in the logs.  I am more than happy with 50+days uptime on 160MHz mesh connection.
    #26030
    Maybe worth looking in log also incase there are entries like ‘failed to write’ or ‘No space left on device’ which may give a clue.
    #26031
    • Replies 634
    Nothing that mentions this.  Are you ok if I email or PM the logs to you to see if you can see anything?
    #26032
    Sure, I will drop you an email and you can respond to that if OK with yourself, or just respond to one of our previous emails we have communicated with in the past
    #26035
    I received you logs, thanks and does look like a mem type issue or very high CPU usage that caused a service not to work correctly.
    If OK with yourself, can I send the logs to ASUS so they can add it to their list
    #26036
    • Replies 634
    Please send to Asus, I will also send logs and mention you?
