› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › ASUS ZenWiFi BQ16 BE25000 Whole Home Quad-Band Mesh WiFi 7 System I took the plunge and bought the 2 pack BQ16 and put the 3 pack BT10 on sale for £650. Been using them for the past 2 days. It came...
- This topic has 86 replies, 5 voices, and was last updated 1 day, 20 hours ago by
MultiDoc.
- June 10, 2025 at 8:32 pm #37985. UK Sentinel Said:
Auto-Update is always fun, let us know how stability is after a few days
14 days now, everything has been rock solid
July 19, 2025 at 2:54 am #38795ASUS ZenWiFi BQ16 Firmware version 3.0.0.6.102_36935Version 3.0.0.6.102_3693563.74 MB2025/07/18SHA-256 :5576D650BC9E724C6A9572133544251103EDDD6399BDFC72DCF85B79FB9B6C341. Applied Broadcom patch to resolve a potential 5 GHz Wi-Fi vulnerability that, in rare cases, could trigger temporary disconnections for connected devices; updating ensures normal operation and enhanced protection.
2. Fixed MAC Filter inconsistency with MLO devices
3. Improved Network Map client list accuracy-
This reply was modified 1 year, 3 months ago by
dodgydrains.
July 19, 2025 at 2:59 am #38797Over 30 days uptime with the previous FW, hopefully this one is as stable.
July 19, 2025 at 5:39 am #38798Good news there is a new release for the ASUS ZenWiFi BQ16, are you going to flash to this version 3.0.0.6.102_36935 ?
July 19, 2025 at 9:28 am #38809July 19, 2025 at 11:18 am #38810. dodgydrains Said:Already dirty flashed to the latest 3.0.0.6.102_36935 FW.
August 9, 2025 at 1:19 am #39014Looks like a significant update with a number of security fixes.
Version 3.0.0.6.102_36998
63.18 MB
2025/08/08
SHA-256 :6151AE66806CE60E15E72FFB8A79527E05B4E79B21E0B9B5214D1648AC7D45CD
Important: After installing this firmware, we strongly recommend performing a factory-default reset to activate every new security adjustment.Security Enhancements
– Detailed Audit Trails – Expanded logging within the authentication module.System Improvements
– Client List Maintenance – Resolved an issue that prevented offline devices from being removed from the client list.You need to login in order to vote
August 9, 2025 at 5:42 am #39015Does look like from this update, ASUS are addressing concerns about brute-force attacks and weak passwords and AiCloud etc.
August 29, 2025 at 2:29 pm #39376Asus churning out another update in August 2025. I will update to it later in the afternoon:
Version 3.0.0.6.102_37000
63.17 MB
2025/08/28
SHA-256 :6EA50B402F043D8531074AA185D6FE08343D8D7BE64AEFC037B63DD577749A8FSystem Improvements
1. Enhanced AiMesh stability and overall system reliability
2. Improved CSS handling to ensure consistent display behaviourYou need to login in order to vote
August 29, 2025 at 3:48 pm #39377August 29, 2025 at 8:43 pm #39379Hopefully they start pushing these out to the bt10 it is now 2 versions behind this
September 8, 2025 at 6:58 am #39453. Superhands Said:Hopefully they start pushing these out to the bt10 it is now 2 versions behind this
I asked ASUS regarding the next release for the ASUS Zenwifi BT10 firmware and ASUS kindly responded with…
The new firmware is currently being tested. If no critical issues are found, it will be released soon.
September 8, 2025 at 9:57 am #39454October 23, 2025 at 1:44 pm #39896Firmware version 3.0.0.6_37012-g4353103_1436-g20c97
– Release Note –System Improvements:
1. Apple Compatibility – Improved stability and compatibility with Apple devices and the latest OS updates.
2. Connection Stability – Enhanced AiMesh stability and overall system reliability.
3. Dual WAN – Optimized switching behavior when secondary WAN is unavailable.
4. Offline Status – Enhanced accuracy in UI display.This update is available via the web UI
October 23, 2025 at 4:03 pm #39922After each update or reboot, why does it ask for a certificate to be installed to access the web GUI? It looks like a new certificate is needed after every reboot. Is there a way to stop this?
