ASUS ZenWiFi BT10 Whole Home Tri-Band Mesh WiFi 7 System – Official Thread I am thinking of upgrading from my XT8’s to the BT10. My 4x XT8 setup have been an absolute champ after the first few months of buggy FW releases from…
› UKTH forums › Wireless Routers & Modems › ASUS & Wireless › ASUS ZenWiFi BT10 Whole Home Tri-Band Mesh WiFi 7 System – Official Thread I am thinking of upgrading from my XT8’s to the BT10. My 4x XT8 setup have been an absolute champ after the first few months of buggy FW releases from...
Viewing 15 posts - 61 through 75 (of 100 total)
  • #38091
    • Replies 8,739
    Great news, is AiProtection still enabled ?
    #38092
    AvatarSimmoUK
    • Replies 14
    Yes, I never disabled AIProtection.
    #38093
    • Replies 8,739
    AdGuard and AiProtection working side by side , good to know and thanks for sharing
    #38094
    AvatarSimmoUK
    • Replies 14
    No problem, the manual set-up rather than using the built in toggle switch in the Web GUI to enable it solved the problem (it still shows as disabled in the WebGUI)
    The manual set-up also added and extra IP4 and 2 x IPv6 address details to the DNS over TLS server list.
    All DNS traffic is now encrypted which I can see on the AdGuard dashboard.
    Happy to have got this working
    #38102
    AvatarSimmoUK
    • Replies 14
    Has anyone got any experience of adding a BT8 node to an existing BT10 AIMesh set-up?
    I have 2 x BT10 devices – One set up as the primary, in router mode and connected direct to ISP ONT, and the second as a node connected to the primary using the Ethernet Backhaul.
    I need to add a couple of more nodes to provide additional coverage and have been looking at the slightly cheaper BT8’s and wondered if these would work without issue in an AIMesh with the BT10s as they are part of the same family with same features etc or if I should just spend the extra and keep all units the same.
    All nodes will be connected via Ethernet Backhaul.
    #38106
    • Replies 8,739
    The BT8 and BT10 can work together in an AiMesh network and as you are utilising Ethernet backhaul, then most of your mesh problem will be removed, both models belong to the ASUS ZenWiFi AX (WiFi 6) family and support AiMesh, so they are designed to be compatible.
    Only issue I see is that if you introduce a 2x BT8 nodes into a BT10 system, then small chance there could be issues due to nodes running different firmwares compared to Primary, but issue is only a small one.
    Mixing BT8s with BT10s is a sensible, cost-effective option but just be aware that direct WiFi performance for clients connecting to the BT8 nodes may be a little lower compared to BT10 nodes, but with wired backhaul, your core network stability and speed should remain strong.
    If you can add a switch to the setup. this then gives you more options to connect TV,s PC’s etc via LAN cables and gives you the option for future scalability and a centralised wired network.
    #38109
    AvatarSimmoUK
    • Replies 14
    Thank you for your guidance.
    I have a central switch that is connected to the main BT10, everything else is cabled back directly to the switch.
    Everything that can be connected via Ethernet is connected that way, the only devices using WiFi are mobile devices, laptops when not working from a desk and IoT devices that can’t be wired.
    Thanks for the information RE BT8 and BT10, it was aligned with my thoughts.
    I have some security cameras that have low signal strength due to their location and distance from nearest node, this is the reason to add one of the nodes.
    The other node will go into a room where I am seeing my laptop, when connected via WiFI6, struggling to maintain a connection and dropping out as when in this location it is the middle of the two nodes. (It works fine when I bind it to one of the nodes as a workaround but this isn’t an ideal solution).
    Even the BT8 nodes are probably overkill for these use cases but want to ensure I maintain a secure and stable home network.
    #38110
    Too many APs are bad for your home network and WiFi connectivity.
    You should set an additional different SSID on your repeaters instead of an overkill extra AP, so you can connect your laptop in this room to a dedicated AP.
    #38111
    AvatarSimmoUK
    • Replies 14
    OK, thank you.
    I will give that a try for the laptop situation first and just put one extra AP in to provide coverage to the Security Cameras
    #38112
    Nick HollandNick Holland
    • Replies 41
    I disagree with Grisu. The BT10 and BT8 will operate as a mesh network and not as a router with APs. You do NOT need a different SSID. I am running an ASUS BT8 mesh network with 8 x BT8s. I have SSIDs for the 5 Ghz and 6 Ghz bands and added an IOT network for the 2.4 Ghz band (so only 3 SSIDs in total). I will be adding a further 2 x BT8s to complete my network (previously had 3 x ET12s and 9 x XD4s in my network).
    As to adding the BT8 to the BT10, it should be the same process as for the BT10. The easiest method I have found for wired backhaul is to firstly ensure the ‘AiMesh node Ethernet auto setup’, ‘Hide Backhaul SSID’ and ‘Ethernet Backhaul Mode’ are set to on in ‘System Settings’, then just connect the new node in its new location with the ethernet cable and then just click ‘Add AiMesh Node’ (so you don’t need to have the new node close to the router node). It will find the new node very quickly. You must also manually update it immediately with the latest firmware downloaded from ASUS.
    Hope this helps.
    • This reply was modified 1 year, 4 months ago by Nick HollandNick Holland.
    #38121
    AvatarSimmoUK
    • Replies 14
    Thanks for the advice, Nick
    #39662
    • Replies 8,739
    ASUS ZenWiFi BT10 Firmware version 3.0.0.6.102_38991
    2025/09/16
    Security Enhancements:
    – Password Policy Upgrade – Minimum 10 characters with at least 1 letter, 1 digit and 1 special symbol, and no consecutive identical characters; hardens defense against brute-force attacks.
    System Improvements:
    – Client List Maintenance – Resolved an issue that prevented offline devices from being removed from the client list.
    Bug Fixes:
    – Fixed abnormal client list.
    – Fixed abnormal GUI behavior of Wireguard VPN.
    – Fixed USB internet backup conflict with main WAN.
    – Fixed abnormal WAN detection while AiDetection is enabled.
    – Improved AdGuard DNS GUI issues.
    – Fixed IPv6 related issues.
    – Improved USB tether compatibility for pixel phones.
    https://www.asus.com/uk/networking-iot-servers/whole-home-mesh-wifi-system/zenwifi-wifi-systems/asus-zenwifi-bt10/helpdesk_bios?model2Name=ASUS-ZenWiFi-BT10
    #39663
    • Replies 148
    Interesting update. I wonder what i’ll be missing out on by not factory resetting afterwards? defaults on the password and upnp (which i’d enable again anyway?)
    Not sure I want to go through and re-do all the settings again. Pretty chunky update though
    #39664
    • Replies 8,739
    The factory resetting option is a tricky consideration, as the update includes deep security changes (not just bug fixes) and some new features or security hardening which only take full effect after wiping old settings.
    Factory resetting is the best, most secure option and also reduces possible connectivity problems, instability etc. I’ve seen a few of these over on Reddit likewise, some users have reported no problems after dirty flash and possible due to the configuration they are using etc.
    Security–Performance–Usability Triangle
    Conceptual Frameworks for Balancing Tech Trade-offs
      • Security often reduces performance.
      • Performance improvements can weaken security
      • Usability/time constraints may force compromises in both.
    • This reply was modified 1 year, 2 months ago by UK SentinelUK Sentinel.
    #39694
    AvatarSimmoUK
    • Replies 14
    Has anyone installed this latest firmware upgrade? Is it stable?
    I note that a factory reset is recommended, I assume a config backup / restore should put the device back to it’s current config post the reset?
