› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › AX DSL-82U on ECI Unfortunately I am on a ECI cabinet I have the AX RT-82u and an old BT modem as my set-up on talktalk at the moment, I am looking for a...
- This topic has 9 replies, 2 voices, and was last updated 4 years, 11 months ago by
Chelsea maniac.
- May 9, 2021 at 11:29 pm #13226
I am looking for a bit of help will the DSL AX 82 version work well on a ECI cabinet or is it best to stick with my current set up, as I was going to use the other as AI mesh.
I have heard some modems do not like BT ECI cabinets and will keep dropping the connection
Any help on this will be appreciated they are great routers so want to pair with the modem version and update the whole network
May 10, 2021 at 5:43 am #13227Welcome, yes you have lucked out with the ECI cabinet as these currently do not support G.INP
If you planned just to keep your existing RT-AX82U, then I would say purchase a new modem (vigor 130) and that should help by replacing you older modem and be the less expensive option.
Or….
If you are planning to go AiMesh, then in theory the new DSL-AX82U used as AiMesh Primary and your rt-X82u used as Node (Child) should work very well, alas the dsl-AX82U is still very new so firmware needs to mature.
Both Broadcom and Lantiq DSl chipset work well on ECI cabs, Broadcom is usually rock solid and that is what the DSL-AX82U has
Hope that helps
(P.S) what a game between City ;-)
May 10, 2021 at 11:07 am #13236Thank you for your reply uk-sentinel I will go the DSL route as I would have to buy another node anyway, One thing I will say about the AX82u it squeezed another 5MBps out of my line was getting 40 down on netgear x6 r8000 now getting 45, and I love the settings page the only thing I do not like is you can not all block new connections
May 10, 2021 at 11:09 am #13237Sor4ry just read about the game with City I was on the edge of my seat and still laughing at that penalty
May 10, 2021 at 1:50 pm #13243so have you purchased the DSl-AX82U already ? or was the RT-AX82u so good it outperformed your Netgear x6 r8000Â ?
Luckily Mendi managed to get back to the centre of the goal mouth, he is good
May 10, 2021 at 1:51 pm #13244May 10, 2021 at 1:55 pm #13245No I have the AX Rt-82u not the DSL version
Understood, hopefully with the DSL-AX82U, you might even get a little more synch speed from the DSL side also
May 10, 2021 at 2:11 pm #13246That’s what I am hoping and also fed up with not being able to access line states on my ECI modem
May 10, 2021 at 2:13 pm #13247That’s what I am hoping and also fed up with not being able to access line states on my ECI modem
Any probs, let us know as I am sure we can help when your DSL-AX82U arrives
May 10, 2021 at 2:32 pm #13248Thank you, you have been a great help it won’t be for a few weeks before I get it anyhow
