› UKTH forums › ๐ Wireless Routers & Modems › D-Link & Wireless › D-Link Dir-1960. No Support Hello, I bought a D-Link 1960 router before realising that D-Link has no real support in Europe. I need to know how to set the device up so that I...
- This topic has 15 replies, 2 voices, and was last updated 5 years, 2 months ago by
Cheemag.
- January 2, 2021 at 5:24 pm #10980
Hello,
I need to know how to set the device up so that I have two separate networks at 2.4 and 5 GHz. At the moment it is only allowing the one (composite?) band.
I can find nothing on the Web for this problem and others. The FAQs provided by D-Link are useless only a few FAQs which only go up to Windows 7 and a couple of videos. Their forums are restricted to users in the US. They don’t answer emails.
Any help or links will be greatly appreciated.
Regards
Cheemag
January 2, 2021 at 5:58 pm #10982Not used a D-Link before, but under Setting > Wireless is there an option to disable ย ‘Smart Connect’ย hopefully that will reveal the second SSiD option ?
or ย Setup/Wireless/Manual, I forget whichย ?
January 2, 2021 at 7:59 pm #10984Not used a D-Link before, but under Setting > Wireless is there an option to disable โSmart Connectโ hopefully that will reveal the SSiD option ? or Setup/Wireless/Manual, I forget which ?
Thanks for that.ย We got there. Many thanks.
Smart connect forces connects to the best signal, so you only get one networks.
I need two as the smart TV won’t connect to the Smart Connect.
I don’t suppose you know how to utilise the USB port. I have a flash drive plugged into it with a few files on it, but can’t discover what to put into the Windows 10 search box to find the USB modem slot on the network. The manual is no help and the FAQs stop at Windows 7.
Thanks again. Very much.
Regards
Cheemag
January 2, 2021 at 8:10 pm #10985My LG TV does not like ASUS Smart connect either, Try this for Shared USB , should work for Windows 10 also – https://support.dlink.com/FAQView.aspx?f=Sssy5ZaMp4Dah9k7UajFYA%3D%3D
January 3, 2021 at 12:24 pm #11003My LG TV does not like ASUS Smart connect either, Try this for Shared USB , should work for Windows 10 also โ https://support.dlink.com/FAQView.aspx?f=Sssy5ZaMp4Dah9k7UajFYA%3D%3D
Hello again,
I found that page some time ago, but it only goes up to Windows 7. I can’t find an equivalent of ย ‘Start > All Programs > Accessories > Run’ย in Windows 10.
Although I now have the tablet and phone showing both 2.4 and 5 GHz networks, the smart TV no longer works. It doesn’t appear on the local net and cannot connect to the internet although the parameters it hasย are exactly the same as before, including the password.
It looks like I shall have to go back to the X4S D-7800, on which Readyshare stopped working after an update.ย ย I’m getting less from the D-Link than I was from the Nighthawk !
Regards
Cheemag
January 3, 2021 at 12:29 pm #11004Can you Screen dump the Wireless settings on D-Link router so we can have a look ?
Did you re-add TV to new SSID, even if SSID name is the same as before ?
January 3, 2021 at 1:03 pm #11006Can you Screen dump the Wireless settings on D-Link router so we can have a look ?
I’ll have a go later.
Not quite with you there.ย I could try taking the TV off line, then try setting it up again.
Because I have a Roku stick which only works on 2.4 GHz I have to have the TV on that band as well and they appear to be on the same channel, if that means anything.
I got as far asย >run with Windows 10, but its response toย ย \\192.168.0.1 wasย ย > Network 192.168.0.1ย : This folder is empty, although there are files on the flash drive.ย An empty folder in File Explorer.ย I’ve named the flash drive DIR-1960, but >runย \\192.168.0.1\DIR-1960 gives a security access problem box.
I’ll get back on the screen dump.
Thanks for sticking with me !
Regards
Cheemag
January 3, 2021 at 1:18 pm #11007Can you Screen dump the Wireless settings on D-Link router so we can have a look ?
Iโll have a go later.
Iโll get back on the screen dump.
Regards
Cheemag
January 3, 2021 at 1:35 pm #11010I see, a Roku stick, Did you have you TV connected to wifi before also or just the Roku stick ?
Either way, if both where or just one was connected before you disabled Smart connect, then remove them from wifi and re-add and see if that helps ?
I am sure we will get there in the end
January 3, 2021 at 3:29 pm #11011I see, a Roku stick, Did you have you TV connected to wifi before also or just the Roku stick ?
Both yes. There were no problems with that.ย I could watch TV via Roku or directly from the TV’s apps.
re-add and see if that helps ? I am sure we will get there in the end
I’ll take Roku off.ย TV still doesn’t show …
Took TV off-line and back on – works on both 2.4 and 5GHz; shows up on the network (twice) ย :o)
Put Roku back on – it all works.
I’m now back to where I was with the Netgear Nighthawk. Leaves the problem of not being able to use a USB drive on the DIR-1960 – possibly something to do with needing a passwordย (?)
Again many thanks for your help. Way and above D-Links paltry effort !
Regards
Cheemag
January 3, 2021 at 4:42 pm #11012
January 4, 2021 at 2:24 pm #11050
Despite setting myself up as User with a password, connecting to 192.168.0.1, all I get is an empty directory on both tablet and W10 desktop.
Tablet asks for a password, which is accepted.ย Not asked for a password on desktop,
The USB stick is in the router, shows in the USB Device page and all its directories are given as choices when setting up User, yet the stick cannot be accessed and doesn’t appear in Windows 10 File Explorer > Network or in Total Commander’s network slot.
Any further ideas or have I exhausted your store of ideas,
Regards
Cheemag
January 4, 2021 at 7:43 pm #11053Page 82 if you do not have this manual already
https://uktechhub.com/wp/wp-content/uploads/2021/01/DIR-1960_man_revA1_1-01_eu_multi_20190828.pdf
January 5, 2021 at 2:09 pm #11072Hello again,
I’ve been looking at that page for some weeks without DHCP meaning anything to me. I doubt I need it.
The network itself has gone completely astray. Today neither of the two desktop machines wired into the modem show even themselves on Network
never mind each other.ย All the Network settings are correct in Windows.
in File Explorer or Total Commander although they’re available via the W10 search boxย ย ย \\<machine name>ย . No amount of rebooting will get it back again.
Looks like I’ll have to go back to the Netgear router and keep this as a spare.
Again, thanks for your help.
Regards
Cheemag
January 5, 2021 at 3:10 pm #11074No problem, before you put your D-Link into retirement, just make sure you are using the latest firmware, if you are using the latest firmware, then hopefully you will look at Netgear or ASUS for future router options
DIR_1960_V1.11B03
https://support.dlink.com/productinfo.aspx?m=DIR-1960-US
