› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › Define/save a script within the ASUS routers memory A few have asked if there is a possibility to define/save a script within the ASUS routers memory i.e, arp command to be executed on each restart of the router....
- This topic has 0 replies, 1 voice, and was last updated 7 years, 7 months ago by
- August 26, 2018 at 6:01 pm #363A few have asked if there is a possibility to define/save a script within the ASUS routers memory
I communicated with ASUS regarding startup scripts and their Feedback from ASUS regarding startup scripts is below, only limitation is that your particular ASUS model supports Download Master.
Actually it can be done, you could inform users to install USB App such as Download Master(DM), once installed then under USB disk root > DM directory one could find script file that would be executed for perform DM related tasks, that script could be altered to suit ones need. Thanks.
UK Sentinel
