DrayTeK Vigor 166 – G.fast capable As some of you may know, Draytek produce a range of Routers and modems for the UK that comply with BT SIN498 I have recently contacted DrayTek to ask them…
UKTH forums 🛜 Wireless Routers & Modems DrayTeK & Wireless DrayTeK Vigor 166 – G.fast capable As some of you may know, Draytek produce a range of Routers and modems for the UK that comply with BT SIN498 I have recently contacted DrayTek to ask them...
Viewing 15 posts - 31 through 45 (of 79 total)
  • #11387
    • Replies 8,279
    Has anyone had any joy getting the 166 working on a BT G.Fast connection? no matter what I do the DSL light keeps flashing and never connects. Got one today, thinking about returning it already :(
    Was the G.fast service working previously or have you recently upgraded ?
    Also try using the Draytek supplied DSL cable plugged into Black port on Left ?
    #11394
    Avatarsmallal
    • Replies 23
    First question is have you bought the UK or EU version? The UK version should work ‘out of the box’ as it has special UK firmware tailored for the BT/Openreach service, but the EU version doesn’t so it’ll require a manual config.
    Avatarsmallal
    • Replies 23
    Has anyone had success using the 166 as a router instead of a modem on BT G.Fast? If so what settings did you use?
    • Replies 8,279
    Not with the Vigor 166, but have played with the Vigor 130 and the DrayTeK 2760n – if you are on the BT Firmware, can u check if the Quick Start Wizard still available, as that is the simplest option,
    #11412
    Avatarsmallal
    • Replies 23
    Thanks, I was just experimenting to see how it performed, DSL & LAN lights were on but my PC wouldn’t connect. I’ve now found the problem, in router mode the default DHCP server setting is OFF so it wasn’t giving out any IP addresses, so I turned it on! 1st router I’ve come across with that default.
    • Replies 8,279
    Glad your all sorted
    I don’t think the Vigor 166 supports jumbo frames, so another “feature” as Microsoft would say
    #11415
    Avatarsmallal
    • Replies 23
    Glad your all sorted I don’t think the Vigor 166 supports jumbo frames, so another “feature” as Microsoft would say
    Any easy way to test for jumbo frames? I have read that an MTU of 1508 is required & this router does that (it goes up to MTU=1520 max, unlike the EU version where MTU=1500 max.)
    • Replies 8,279
    That is good news and thank your for providing clarity, yes I believe review I read was an EU model
    #11470
    Avatarhushcoden
    • Replies 24
    I probed DrayTeK again and this time they kindly revealed the new Vigor 166 (Gen 1) is indeed using the VRX618 Intel chipset
    Intel AnyWAN SoC GRX350 + Intel AnyWAN Transceiver VRX618
    • Replies 8,279
    perfect
    #11630
    Avatarsmallal
    • Replies 23
    I see several EU dealers are now taking pre-orders for the new GEN2  (212Mhz) version of the EU model. (V166-A GEN2) Price seems to be the same as for the GEN 1
    • Replies 8,279
    It is good to see the GEN 2 units are finally available in the EU, for UK, GEN 2 is not usable as far as I recall as local cabs etc. are only fitted to support GEN 1 – and the emphasis is on FTTP – FTTH installs for UK,?
    But we can all hope priorities can change
    #11633
    Avataradamgibbo
    • Replies 4
    I’ve used a EU variant of the 166 (Gen 1) in the UK for around 4 month now connected via bridged mode to a firewall. Not had a single problem.
    If anyone was wondering about the UK firmware working on the EU variant, it doesn’t. Even tried using TFTP to flash the firmware. But not too bothered as I’ve had no issues so far and all it seems to do is automatically add VLAN 101 tag, rather than having do it manually.
    I can’t see the Gen 2 coming to the UK as BT are unlikely to bother with 212Mhz G.Fast, but who knows.
    Avatarhushcoden
    • Replies 24
    Which resellers, please?
    Avatarsmallal
    • Replies 23
    If you are ordering from the UK you may find it difficult as most EU retailers no longer ship due to the ridiculous new UK tax restrictions! Stock is due in the next 7 to 14 days apparently.
    allfirewalls.de
    sotel.de
    amazon.nl
    or do a search on toppreise.ch/en – The swiss are already using the 212Mhz band so lots of companies taking pre-orders there.
