› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › DSL-AC88U-B Annex B version Firmware Dear testers, I’m the Asus user from Czech Republic. I’m maybe one the first here using DSL-AC88U-B Annex B version of the relative new Asus DSL-modem-router. Several years I worked...
- This topic has 23 replies, 4 voices, and was last updated 7 years, 4 months ago by
- November 2, 2018 at 9:52 pm #1347
I’ve just found out that CETIN uses DSLAM equipment from Alcatel and Lucent in newly installed cabinets. Is that information anyhow useful?
The rollout must be in support of CETIN plans for FTTC deployments to support VDSL and Vectoring rollout in Czech with the options for VDSL Bonding next year.
Don’t think the DSl-AC88U (B) support Bonding so will be interesting to see what happens?
Edit: I cannot find what chipset these DSLAM are, will be interesting to see if they are Broadcom, or another type?
November 9, 2018 at 11:08 am #1378https://www.asus.com/ae-en/Networking/DSL-AC88U-Annex-B/HelpDesk_BIOS/
New firmware out:
Version 1.10.06_Build585 2018/11/0933.33 MBytesASUS DSL-AC88U Annex B Firmware version 1.10.06-Build585 (This product supports Annex B)
Release note:
– Fixed memory leak issue.
– xDSL Datapump updated: B2pvfbH043q. Fixed various xDSL issues.
– xDSL Driver updated: A2x027b. Fixed various xDSL issues.
– Added 35b support for VDSL Profile > Multi-mode.
– Fixed system DHCP server related issues.
– Adopt Broadcom BSP Patch5 changes.
– Fixed MDNS Multicast issues.
– Fixed AiProtection related issues.
– Fixed PS3/PS4 PPPoE pass-through issue when the WAN interface has no VLAN tag.
– Now Web UI support HTTPS option(Administration > System).
– Added “-R” option to start minidlna, force minidlna reparse USB content.
– Fixed always show alert message after finish restoring Setting file issue.
– Fixed Network Services under Firewall does not work properly issue.
– Fixed issue show incorrect message “Signature Version”.
– Fixed Web History related issues.
– Fixed the issue of firewall is not properly working by default.
– Web access from WAN, removed HTTP option, for security concern.
– Exclude G.fast capability in Auto-Sync mode for DSL modulation and removed some driver bits, for ADSL2+ compatibility.Please unzip the firmware file first then check the MD5 code.
MD5: 67a0ecd7d9136e2fe69ef012602d80a4You need to login in order to vote
November 9, 2018 at 6:35 pm #1386Hey Pavel,
I would be glad if you reported your experience with the latest beta after a few days of use. I am thinking of buying this router more than ever, but you know, it’s kinda expensive. Thanks.
Damis
November 12, 2018 at 2:50 pm #1433Hello
Bad news for the new DSL-AC88U-B – with new stable firmware, both – HW acceleration and Ai Security not work properly all together. I have also my older router DSL-AC68U, there is speed with Ai Security setup “on” preserved and all the possible bandwidth is utilized. All types of download.
My test with the DSL-AC88U-B FW 1.10.06_Build585
bittorrent download over 50Mbps/5Mbps VDSL line:
4.8-5MBps – AiProtection off, auto QoS off (one LAN host with RJ45 connection) – met my expectations
50kBps – AiProtection on, auto QoS on (one LAN host with RJ45 connection) – unusable for multimediaTo enjoy full speed I had to turn AiSecurity off. Again.
Hope it helps for the FW investigation.
But many thanks for https, it works fine.Wishlist: same functionality as DSL-AC68U plus new profiles, aimesh, WPA3 ready
Pavel
November 12, 2018 at 3:28 pm #1434Hi @Pavel
Thanks for letting us know,
can I ask, did you do a factory rest after loading latest build585, maybe worth trying,user @nofixedaddress has highlighted issue with build586 and AiProtection (DSL-AC88U) , I have tested build (stock) 585 and all good with AiProtection/wifi speeds etc, just waiting for house to empty, then can load build586 and test again?
Edit: It maybe worth disabling and then re-enabling AiProtection, to see if this helps with some of the issues you have found with build585 (stock) – other users have noted that with AiProtection working correctly, the speed is reduced with AiProtection on and hopefully ASUS will fix in future releases.
November 14, 2018 at 4:22 pm #1462I dont understand why asus stopped releasing beta firmwares for ASUS DSL-AC88U-B Annex B version?Last beta firmware i find on web is build 566.Every time i have to waiting for official stable release to fix someting,like the ram usage and it was just the same beta that release month earlier.im wondering when asus is going to add simple ASUS Router App support.I payed freaking 300€ for the router.
sorry for my english.
November 14, 2018 at 4:37 pm #1463I do chase ASUS for the Beta’s for the DSL-AC88U – B, but ASUS for some reason, do not seem keen on producing/release them.
I will chase ASUS again and add this to my list ;)
November 14, 2018 at 7:31 pm #1465November 15, 2018 at 8:17 am #1466@Cwikia
DSL-AC88U-B_v9.10.06_build586.zip
https://www.asuswebstorage.com/navigate/s/BB0A3F6421E24006BFCE3625943EF5ADY
