Fiat 500 multijet 1.3 Diesel blowing white smoke So my daughter returned from UNI and mentioned that her Fiat 500 Diesel Multijet sometimes blows white smoke whilst driving or at start up (maybe). So I thought I would…
› UKTH forums › Life & Stuff › Cars › Fiat 500 multijet 1.3 Diesel blowing white smoke So my daughter returned from UNI and mentioned that her Fiat 500 Diesel Multijet sometimes blows white smoke whilst driving or at start up (maybe). So I thought I would...
Viewing 14 posts - 1 through 14 (of 14 total)
  • #14340
    • Replies 8,736
    So I thought I would create a log of what I do to see what the issues might be .
    White Smoke usually means either unburnt fuel or a water issue
    Grey smoke is a little more interesting
    Black Smoke usually means to much fuel being burnt (rich mixture)or Air flow restriction
    Blue Smoke means the engine is burning oil.
    #14341
    • Replies 8,736
    So I have checked the Water level and that is as it should be, I have also checked the Oil level and that is a little over the max level which I over filled from previous top up last year.
    Now to check the dashboard for any warning lights and double check Smoke is actually white and not Grey which could mean a little oil is leaking (overflowing) into fuel delivery system causing issues maybe for the diesel particulate filter (DPF) / catalytic converter being blocking or the Lambda Sensor or simular needing a clean etc.
    #14343
    FIAT: Failed Italian Automotive Technology or Fix It Again Tony
    #14344
    • Replies 8,736
    [quote quote=14343]FIAT: Failed Italian Automotive Technology or Fix It Again Tony [/quote]
    har har but back to getting the FIAT 500 working as it was intended. (Fixed It And Tested)
    #14357
    • Replies 8,736
    So the Fiat 500 had no warning lights on the dashboard and no visible exhaust smoke (white or black) was observed when the car cold starts in the Β morning and drives away .
    Will test again after it rains overnight as water condensation or the known water leak from the wiper Β blades Β grill could be dripping water onto the air filter Β housing and maybe making the air filter damp and causing white smoke.
    But good news that no water or oilΒ  is finding its way into the cylinder block over night .
    Time to dig out my ODB11 Fault code reader and see if that gives any clues ?
    #14394
    • Replies 8,736
    Still waiting for that rainy day / night – trust us to be in the middle of a heatwave.
    The Fiat 500’sΒ  Diesel Particulate Filter (DPF) dashboard warning light came on today, but alas came on as my daughter arrived home,
    So good news the DPF seems to indicate it needs a clean / regeneration Β (a proper good run) and hopefully this could be the main reason for white smoke appearing from time to time as a DPF as part of the cleaning process uses extra fuel to help burn of soot deposits (ash) in the DPF as part of the self clean process, I am slowly drawing to the conclusion that the regens are never allowed to finish.
    https://en.wikipedia.org/wiki/Diesel_particulate_filter
    #14402
    • Replies 8,736
    Well this morning the Fiat 500 Diesel Particulate Filter (DPF) warning light came on, the car cold started and white smoke came out from the exhaust, so seems that Fiat DPF was not allowed to finish its regeneration cycle yesterday, it decided to keep pumping in the extra fuel this morning even when the engine and exhaust is still cold which is not good.
    #14403
    But cleaning (burning/regeneration) is done only when the engine is warm (>60Β°C) and must not start while still cold.
    You should bring it to repair, quite sure some sensor gives wrong messurements or something like this.
    #14406
    • Replies 8,736
    Totally agree, regens should only occur when engine and exhaust are upto temperature,Β  hopefully the DPF needs a good run to clear out the soot etc. Otherwise remove the DPF Β from car and cleaned. I plan to plug in my ODB11 Fault code reader this week to see if indeed any faults (sensors – injectors ) are identified also.
    (it is a Fiat) Β but does look good
    For anybody else reading this thread, – If you ever have the message ‘antipollution filter clogged‘ this means that the DPF Regeneration process has been interrupted 3 times before it has completed its cycle (engine turned off) and usually a 20 minute drive on the motorway at high revs will allow a DPF regen to be fully completed.
    #14473
    • Replies 8,736
    So I plugged in my Autel 519 OBD2 Reader this morning and no fault (Permanent) codes where identified, the Autel 519 did identify DPF had a flow restriction problem and an Fiat Specific code was also show $80 which after Googling seems to relate to EGR valve .
    The DPF warning light is still showing so looking most lightly a DPF / Regen / Clean DPF issue.
    Time to order a bottle of STPΒ  (Diesel Particulate Filter Cleaner) and a Spray can of Wynns Diesel EGR and Air Intake Cleaner, to see if a good run and spraying the Air intake hose (beyond the air filter) will bring the Fiat back to a normal running conditionΒ
    #14477
    • Replies 8,736
    Well I added the STPΒ  (Diesel Particulate Filter Cleaner) to the fuel tank (half full) and sprayed the Wynns Diesel EGR and Air Intake Cleaner into the Air Intake hose (before the mass airflow sensor) and took the Fiat for an hour drive down the motorway and back running at around 3000 RPM.
    The DPF warning light is now off and will just have to see how long this lasts and if any more white smoke appears from exhaust
    #14478
    Our Skoda (and other VW) has a burning program which can be started via ODB (unluckily not with my simple stick-reader) and runs for about 1/2 hour to clean the filter. Doesn’t have Fiat this too?
    Often such problems occur because of martens biting hoses. Have a look at all of them. We had it 3 times already and always problems with filter and regeneration afterwards.
    #14482
    • Replies 8,736
    Most Diesel vehicles including Fiat can do what is called a forced regeneration (burning program) which can be set-up by expert equipment etc.
    Alas my ODB2 reader cannot do this, but a good drive with STPΒ  (Diesel Particulate Filter Cleaner) in tank to help lower burning temperature and get the exhaust to temp will do the same task (almost)
    Alas – this is my daughters car,Β  whilst she was driving up and down the motorway to UNI, which is hundreds of long distance miles then no issues with DPF and Regens etc.
    Alas since Covid, a lot more time at home (which is good) but Fiat 500 doing lots of very short journeys, hence problems as diesels are not designed for lots of short journeys, especially the older diesels
    Will be interesting to see if in a week if the DPF light is still off and will check hoses if light comes back on
    #14543
    • Replies 8,736
    A week later and the DPF light is still off and still no signs of any white smoke from the exhaust, it has rained a couple of times this week so we can now remove rain causing the exhaust white smoke also.
    So seems adding the STP Diesel Particulate Filter Cleaner to a half tank of fuel and a motorway journey cured the Fiat’s DPF light coming on and white smoke from exhaust problem, DPF for now is clean
