MikroTik RouterOS 7.21 Stable Update (Jan 12, 2026) What’s new in 7.21 (2026-Jan-12 14:56): Changelog: arm64 – allow enabling receive packet steering on /system/resource/irq/rps menu in order to overcome unbalanced CPU load; bgp – allow duplicate router-ids for…
› UKTH forums › Wireless Routers & Modems › Mikrotik & Wireless › MikroTik RouterOS 7.21 Stable Update (Jan 12, 2026) What’s new in 7.21 (2026-Jan-12 14:56): Changelog: arm64 – allow enabling receive packet steering on /system/resource/irq/rps menu in order to overcome unbalanced CPU load; bgp – allow duplicate router-ids for...
RELEASE
  • #41380
    • Replies 8,748
    Changelog:
    • arm64 – allow enabling receive packet steering on /system/resource/irq/rps menu in order to overcome unbalanced CPU load;
    • bgp – allow duplicate router-ids for eBGP sessions (RFC 6286);
    • bgp – always advertise extended nexthop cap for all supported address families;
    • bgp – do not allow iBGP with non-equal ASNs;
    • bgp – fixed l2vpn-cisco decoding (introduced in v7.20);
    • bgp – fixed occasional corruption of MPLS labels in BGP VPN update messages;
    • bgp – fixed route refresh subcode 0 warning;
    • bgp – fixed selection of received BGP VPN routes;
    • bgp – implement RFC 9234 route leak prevention and detection using roles;
    • bonding – added lacp-system-id and lacp-system-priority settings;
    • bonding – fixed lacp-mode=passive;
    • bonding – improved stability for 802.3ad LACP;
    • bridge – expose more DHCP snooping warning logs;
    • bridge – fixed dynamic switch-cpu VLAN creation (introduced in v7.20);
    • bridge – fixed filter and NAT matching with “mac-protocol=length”;
    • bridge – fixed missing local MAC after changing protocol-mode setting;
    • bridge – fixed multicast packet receiving on bridge as multicast-router when HW offloading is used;
    • bridge – fixed possible DHCP packet drop caused by the add-dhcp-option82;
    • bridge – fixed possible MVRP issues when STP topology changes;
    • bridge – fixed static host and MDB entry updates on VLAN add/remove;
    • bridge – improved DHCP Option 82 values (circuit-id:”interface-name:vid”, remote-id:”bridge MAC address”);
    • bridge – improved stability after failed protocol-mode=mstp change;
    • bridge – improved system stability when forwarding traffic with fast-path and bridged interface gets removed or disabled (introduced in v7.20);
    • bridge – properly apply bridge MVRP settings on the fly;
    • bth – added file-share link preview;
    • bth – fixed big file upload;
    • bth – fixed file-share expire after reboot;
    • bth – make user private-key sensitive;
    • certificate – added certificate “trust-store” parameter;
    • certificate – added option to configure built-in trust store (replaced “builtin-trust-anchors” parameter);
    • certificate – added SHA384, SHA512 support for SCEP;
    • certificate – allow ca-crl-host parameter for issued certificates;
    • certificate – fixed incorrect appearance of “invalid-before” and “invalid-after” dates;
    • certificate – improved logging;
    • certificate – on certificate import, added the “issued” flag if the certificate store contains the imported certificate’s CA and its private key;
    • certificate – refactored Certificate internal processes;
    • chr – fixed guest OS type “Other Linux (64-bit)”;
    • console – added “mvrp” to mac-protocol setting;
    • console – added delimiter parameter to :toarray command;
    • console – added fetch-changelog flag to check-for-updates command;
    • console – added reset command to settings directories;
    • console – added sensitive flag to QR code in WireGuard “show-client-config”;
    • console – added show-sensitive option for print command, hide sensitive settings in print output by default;
    • console – changed file id format;
    • console – do not allow to set value as empty for arguments that require selection of a specific list entry;
    • console – do not set values when “setup” command is interrupted;
    • console – fixed :convert from=num on MIPSBE;
    • console – fixed “special-login” setting incorrect channel;
    • console – fixed autocomplete in fullscreen editor to append tabs, spaces, etc;
    • console – fixed empty output in route menus when using “print where gateway”;
    • console – improved :toip command to get IPv4 address from IPv4 CIDR address;
    • console – improved :toip6 command to get IPv6 addresses from IPv6 prefixes;
    • console – improved hints for address arguments;
    • console – improved hints for DHCPv6;
    • console – improved printing visuals (column layout and paging);
    • console – improved stability;
    • console – remove unnecessary commands from /ip/hotspot/active menu;
    • console – removed /quickset menu;
    • console – return error values for certain commands if action failed (e.g. /system/routerboard/upgrade);
    • console – show fullscreen script editor completions above hintbar;
    • console – updated “Change your password” to “Change your password (Ctrl-C to skip)”;
    • console – updated copyright notice;
    • container – add initial Bluetooth device support;
    • container – added “/app” menu for simple containerized app installation (requires “container” package and enabled “container” device-mode);
    • container – added CPU usage;
    • container – added hosts setting;
    • container – added kill command to send signals (CLI only);
    • container – added option to limit CPUs used by containers;
    • container – added root dir size;
    • container – added run command to allow interactive mode (CLI only);
    • container – added stop-time setting;
    • container – added update command (CLI only);
    • container – allow /tmp tmpfs to be unlimited in size;
    • container – allow app network to be any bridge interface;
    • container – allow to configure extra ENV variables directly in container;
    • container – allow to disable/enable envs and mounts;
    • container – allow to specify mounts directly in container;
    • container – calculate volume sizes;
    • container – convert container mounts setting to mountlists, old mount name becomes list name, list name can map to multiple mounts;
    • container – do not allow layer-dir to be within some containers root-dir;
    • container – enable relevant kernel features to support more container apps;
    • container – fixed error for starting container which consists of large number of layers;
    • container – fixed extract issues;
    • container – fixed VETH when using long interface name;
    • container – general container service stability fixes and improvements;
    • container – have per container layer-dir setting to be able to have separate layer stores for different sets of containers;
    • container – made it possible to set timeout on /container/shell;
    • container – make sure a working directory is created if it does not exist;
    • container – show detailed import status, helps understand long imports;
    • container – show image-id field (CLI only);
    • container – shows app URL and “running” status only when port is open;
    • container – store image import data (allows keeping container after netinstall);
    • detnet – do not try detection on slave interfaces;
    • detnet – fixed unnecessary process starting even when feature is not enabled;
    • dhcpv4-client – don’t stop client on unsuccessful client option value change;
    • dhcpv4-server – added “support-broadband-tr101” setting to pass additional Option 82 suboptions to RADIUS server;
    • dhcpv4-server – added setting allowing to select client-id, MAC address and opt82 parameters for dynamic lease addition;
    • dhcpv4-server – allow creating static DHCPv4 leases for VETH interfaces;
    • dhcpv4-server – allow to set other gateway types not just IP for dhcp lease “routes” parameter;
    • dhcpv4-server – improved logging;
    • dhcpv4-server – improved setup wizard prompts relating to DNS;
    • dhcpv4-server – respond with hlen 0 when htype is 8;
    • dhcpv4-server – send RADIUS Accounting Stop messages when interim-update is zero;
    • dhcpv6-client – do not show I flag for disabled client;
    • dhcpv6-client – fixed misleading “couldn’t acquire address, continue with prefix only” error when prefix is not even requested;
    • dhcpv6-relay – added “about” error message option;
    • dhcpv6-relay – enable configuration of options that are added to relayed DHCPv6 requests;
    • dhcpv6-server – added accounting to use-radius setting, similar to DHCPv4 server;
    • dhcpv6-server – attempt to extract MAC from DUID for dual-stack purposes when client uses DUID-EN type of DUID;
    • dhcpv6-server – improved event logging messages;
    • dhcpv6-server – improved service stability when receiving DHCP requests for PPP service clients without included IA_PD;
    • dhcpv6-server – include traffic usage statistics when accounting is stopped due to binding expiry and removal;
    • discovery – correctly report PoE dual signature per-pair class;
    • discovery – fixed MNDP IPv6 status reporting;
    • discovery – send out neighbor discovery immediately on IPv4/IPv6 changes;
    • disk – added nvme-tcp-server-nqn setting to be able to explicitly configure NQN, will default to “nqn.2000-02.com.mikrotik:slot” for new configurations;
    • disk – allow only lowercase chars in iscsi-server-iqn;
    • disk – allow to have type=file devices without rose-storage (needed for file based swap);
    • disk – allow to set smb-share only for type=smb;
    • disk – consolidate client states into single field, as each item can be only one type of “client”;
    • disk – do not allow setting raid-master when have filesystem;
    • disk – do not allow starting Btrfs replace when replace is suspended;
    • disk – do not delete partition configs on device remove and eject (fixes lost config with unstable hardware);
    • disk – fixed iscsi client;
    • disk – fixed iscsi export disable;
    • disk – fixed issue with double “/” in SMB share path for some clients;
    • disk – fixed SATA eject/scan;
    • disk – fixed SMB mount to be writable by container;
    • disk – fixed write RAID superblock;
    • disk – improved cleanup order to avoid waiting for timeouts on shutdown;
    • disk – improved RDS2216 SATA controller;
    • disk – improved system stability;
    • disk – rename nvme-tcp client name to nqn everywhere symmetrically with server;
    • disk – show NVMe critical warnings;
    • disk – unshare iscsi and nfs client/server ids, add iscsi-server-iqn;
    • disk – update interface type/speed after scan;
    • disk – use default label when nothing specified when formatting from WinBox;
    • dns – added VRF support to “:resolve” command;
    • dns – added VRF support to DNS servers;
    • email – added “certificate-verification” parameter;
    • email – return all errors to console when executed from console;
    • eoipv6,gre6,ipip6 – added “dont-fragment” setting to control packet fragmentation for packet sizes exceeding underlay interface MTU;
    • ethernet – added “unsupported speed” warning for forced 1Gbps, 2.5Gbps, 5Gbps, 10Gbps baseT modes;
    • ethernet – change default L2MTU 1518 to 1596 for RB5009;
    • ethernet – fixed 2.5G-baseT link-partner-advertising on RB5009, hAP ax3, Chateau ax devices;
    • ethernet – improved Ethernet port mapping to ensure a consistent and reliable interface order for wAP ax;
    • ethernet – improved system stability for RB912, RB911 devices;
    • evpn – fixed Ethernet Segment (ES) routes;
    • fetch – added “http-percent-encoding” parameter;
    • fetch – fixed http headers appearance when received payload is empty;
    • fetch – send http-data for any http method;
    • file – distinguish empty mount points from disks;
    • file – improved error messages provided to GUI;
    • file – improved stability and interoperability with WinBox and console;
    • firewall – added “h” flag indicating that firewall service helper is applied for particular connection;
    • firewall – added support for TOS/mask matching for raw rules;
    • firewall – clear relevant masqueraded connection tracking entries on IP address change;
    • firewall – fixed “tls-host” not matching expected hosts;
    • firewall – fixed hotspot value loss on rule enable/disable;
    • firewall – fixed strip-ipv4-options always passthrough;
    • firewall – hide hw-offload setting from devices that do not support it;
    • firewall – improved system stability and memory allocation when using firewall services;
    • firewall – make hw-offload=yes default setting in /ip/firewall/filter menu;
    • firewall – use the highest TTL as timeout value for domain address list entries if multiple domain names resolve to same IP;
    • health – upgraded fan controller firmware to latest version;
    • hotspot – added TOTP support for local hotspot users;
    • hotspot – improved system stability;
    • hotspot – prevent service from starting unnecessarily in the background on export/print commands;
    • ike2 – adapt rekey procedure for compatibility with Libreswan;
    • iot – added LoRa Round Trip Time monitoring support;
    • iot – added Modbus rx-switch-offset parameter which helps offset Rx window;
    • iot – added mqtt disconnect/connect GUI options;
    • iot – added support for Modbus port baud-rates from 9600 to 115200;
    • iot – changed LoRa packet’s timestamp format, which fixes duty cycle issues for some servers;
    • iot – improved Modbus multi-write registers handling;
    • ip-service – do not duplicate entries for containers running in same netns;
    • ip-settings – limit IPv4/IPv6 max-neighbor-entries maximum value;
    • ippool6 – added “Valid Lifetime” and “Preferred Lifetime” options and use them when constructing IPv6 address;
    • ippool6 – fixed minor memory leak;
    • ippool6 – log address removal;
    • ippool6 – take into account “subnet-id” when specified on address;
    • ipsec – fixed CHACHA20 typo in log messages;
    • ipsec – support Post-Quantum Pre-shared Key (PPK) with QKD integration (CLI only);
    • ipv6 – added “none” option for IPv6/ND/Prefix when advertising just options, not prefix;
    • ipv6 – added “self” option for IPv6/ND DNS advertise settings;
    • ipv6 – allow to specify on which interfaces to accept Router-Advertisements;
    • ipv6 – do not disable/enable Router-Advertisements functionality based on IPv6/ND configuration;
    • ipv6 – initialize RA receiving when enabled and without any other IPv6 configuration;
    • ipv6 – properly remove SLAAC installed route when prefixes expire;
    • ipv6 – remove SLAAC installed DNS server and route on expire;
    • isis – improved stability;
    • isis – improved system stability when changing passive flag;
    • isis – improved system stability when receiving a hello packet;
    • l3hw – added per-VLAN “l3-hw-offloading” setting and “H” flag for /interface/vlan menu;
    • l3hw – display warning when partial offloading is active (suggest users to use suppress-hw-offloading to control which routes get HW offloaded and which are CPU processed);
    • l3hw – fixed issue with IPv4 ARP and IPv6 neighbor resolve for CRS812;
    • l3hw – fixed partial offloading with /31 routes;
    • l3hw – fixed per-VLAN counters when packets are going through CPU;
    • l3hw – fixed VLAN and VXLAN counters for CRS520 device;
    • l3hw – improved stability and performance during L3HW enable with many routes;
    • l3hw – improvements and optimizations for IPv4 /32 and IPv6 /128 route offloading;
    • l3hw – prioritize local IP address over ARP/neighbor entry with same IP (fixes incorrect packet flow);
    • log – fixed ISO8601 time format;
    • log – fixed memory leak;
    • log – fixed remote logging on remote-protocol configuration change;
    • log – fixed unnecessary file creation when configuring a disabled log action with “target=disk”;
    • log – hide irrelevant log action parameters;
    • log – limit firewall log prefix length;
    • log – limit log socket buffer memory size;
    • lte – added “force-delete” command to allow deletion of active eSIM profiles;
    • lte – added additional logging for error reported by modem during APN profile setup;
    • lte – added command to send out EUICC generated notifications manually;
    • lte – added confirmation prompt when deleting eSIM profile;
    • lte – added support for additional D-Link DWM-222 variation (vendor-id=”0x2001″ device-id=”0x7e46″);
    • lte – added support for additional Huawei E3372-325 variation (vendor-id=”0x3566″ device-id=”0x2001″);
    • lte – added support for R11e-LTE6 v039 firmware release and availability notification;
    • lte – ask for user confirmation before installing eSIM profile;
    • lte – clear SIM not present error when performing modem FW upgrade;
    • lte – discontinued support for RBSXTLTE3-7, further versions will use v7.20 LTE firmware package;
    • lte – do not retry activation for IPv4 and IPv6 APNs on QMI modems if only one address family is assigned;
    • lte – fixed cases where LTE monitor could show abnormalities;
    • lte – fixed LTE interface IPv6 address generation to use EUI-64 (introduced in v7.20);
    • lte – fixed MTU inheritance from master interface in multi-APN setups;
    • lte – fixed MTU setting for AT modems;
    • lte – fixed no re-connection after cellular network requested APN deactivation on Chateau 5G ax R17;
    • lte – force sms-protocol to AT for FG621-EA modem;
    • lte – improved AT modems at-chat control channel handling after modem has closed AT channel unexpectedly;
    • lte – improved modem recovery for Chateau 5G and Chateau 5G R16;
    • lte – improved stability for FG621-EA modem;
    • lte – improved system stability when receiving SMS messages;
    • lte – provide firmware download URL when no LTE package installed on “SXT LTE3-7”;
    • lte – relay EUICC generated notifications after profile enable/disable/remove/provision;
    • lte – rework multiapn support for AT modems;
    • lte – unify “SIM not present” status for all modems;
    • macsec – added initial support for hardware-offloaded support (available only on QCA8081 PHY: RB5009, hAP ax3, Chateau ax ether1 port);
    • media – fixed console autocomplete for path parameter;
    • mpls – fixed LDP filter upgrade from v6 where neighbor parameter is not specified;
    • mpls – fixed update of LDP Address message when local addresses change;
    • mpls – properly renew services when LDP transport address changes its state;
    • netinstall – fixed install with old RouterBOOT;
    • ospf – changed nssa-translator default value from no to candidate;
    • ospf – fixed OSPF interface “Standby” state detection;
    • ospf – improved stability;
    • ospf – show interface as separate prop for interface and neighbor;
    • ovpn – fixed OVPN server handling on reboot (introduced in v7.20);
    • ovpn – improved system stability when using cipher=blowfish128;
    • ovpn-server – added support for pushing IPv6 routes;
    • poe-out – added input name hint to poe max-power settings;
    • poe-out – added LED blink on error for RB5009;
    • poe-out – firmware update for 802.3at capable boards (the update will cause brief power interruption to poe-out interfaces);
    • poe-out – fixed CRS354 misreporting approved LLDP power;
    • poe-out – improved firmware update stability;
    • poe-out – improved power-on mechanism for 802.3at capable boards;
    • port – added comment for /port/remote-access (CLI only);
    • port – added support for additional baudrates for USB to serial adapters;
    • port – do not show serial port for ATL 5G R16;
    • port – fixed displaying “baud-rate=auto” on x86;
    • port – fixed export for default serial port name;
    • port – give “gps” prefix for R11e-LR8G and R11e-LR9G GPS ports;
    • ppp – added multi-APN support to ppp-client dialer;
    • ppp – added setting to set BG77 modem cellular connection mode (auto; lte-m; nb-iot) (CLI only);
    • ppp – improved service stability when using IPv6 with DHCP and RADIUS accounting;
    • qos-hw – added “default” flags to default entries;
    • qos-hw – added “mirror-profile” which allows to select profile (traffic-class) for mirrored traffic;
    • qos-hw – always show usage and PFC counters, even when they are zero;
    • qos-hw – fixed counters for ports that are configured with “offline” tx-manager;
    • qos-hw – fixed profile add/remove for CRS812;
    • qos-hw – fixed shared-pools for CRS812;
    • qos-hw – remove unnecessary “offline” tx-manager for CRS812 (not supported by hardware);
    • queue – improved system stability when using SFQ kind of queues;
    • route – added options in /routing/settings to adjust check-gateway=ping timers;
    • route – fixed SNMP output for ECMP routes having interface gateways;
    • route – hide suppress-hw-offload setting from devices that do not support it;
    • route – improved stability;
    • route – improved system stability with multicast routing;
    • route – make check-gateway=ping work on p2p interface gateways;
    • route – removed /routing stats mem-blocks;
    • routerboot – fixed boot MAC for CRS305-1G-4S+ and CRS328-4C-20S-4S+ switches (“/system routerboard upgrade” required);
    • sfp – expose sfp-cmis-module-state to monitor;
    • sfp – filter out non-breakout modes for breakout modules;
    • sfp – fixed “sfp-tx-fault” state indication for CRS520-4XS-16XQ;
    • sfp – fixed combo-mode change for CRS326-4C+20G+2Q+;
    • sfp – fixed missing link up/down notifies;
    • sfp – improved initialization and linking for 25G DAC on CRS812;
    • sfp – improved system stability with some GPON modules for CRS418, CCR2004 and CCR2116 devices;
    • sfp – recognize 40G Active Cable (XLPPI);
    • sfp – remove 40G-baseCR4, 40G-baseSR4-LR4 from sfp-supported list for qsfp28-x-3 interfaces;
    • snmp – added lldpLocChassisId OID;
    • snmp – count only “bound” leases for mtxrDHCPLeaseCount OID;
    • snmp – make lldpLocPortId and lldpLocPortDesc OIDs information consistent with LLDP TLVs;
    • socksify – improved system stability when using Socksify service;
    • ssh – added support for ED25519-SK keys;
    • ssh – improved logging of failed login attempts;
    • ssh – refactored SSH service internal processes;
    • ssh – renamed User SSH keys “key-owner” field to “info”;
    • ssh – replaced “always-allow-password-login” with “password-authentication” in SSH settings;
    • supout – added info log entry when autosupout.rif is generated;
    • switch – added dynamic “copy-to-cpu” ACL rule for loop-protect;
    • switch – automatically add local bridge MAC to switch FDB;
    • switch – fixed non-IP multicast packet receive on 98DX8208, 98DX8216, 98DX8212, 98DX8332, 98DX3257, 98DX4310, 98DX8525, 98DX3255, 98CX8410 switches;
    • switch – improved HW bond load balancing by adding MPLS labels to transmit hash for 98DXxxxx, 98CXxxxx switches;
    • switch – improved stability on MediaTek switch chips;
    • swos – fixed “allow-from” setting for MIPSBE devices;
    • system – added disks to /system/resource/hardware list;
    • system – detect policy mismatch sooner if script is executed internally by some other service;
    • system – fixed local update package filename generation;
    • system – fixed network header offset for interfaces with MAC (fixes VRRP Tx on IGMP snooping bridge);
    • system – fixed potential configuration loss when available disk space was insufficient;
    • system – fixed saving panic logs to autosupout.rif for ARM CRS3xx devices;
    • system – improved system stability when processing different kinds of lists;
    • system – improved system stability when processing GRE packets on TILE devices;
    • system – improved system stability;
    • system – limit number of interface-lists to 244;
    • tr069-client – added LTE link recovery timer setting;
    • tr069-client – allow disabling Device.WiFi.AccessPoint;
    • tr069-client – expose 5G NR signal metrics for the Chateau R17 ax;
    • traffic-generator – added support for injecting pcapng files;
    • undo – do not show internally issued commands in /system/history;
    • undo – show console commands in WinBox/WebFig for /system/history entries;
    • ups – fixed board hibernation shutdown;
    • usb – fixed cases where USB bus order could change on D53 devices;
    • usb – LTE modem and USB-Serial Controller enumeration fix;
    • usb – support video capture devices for arm64 and x86, for passthrough to containers;
    • user-manager – added RadSec support;
    • veth – add container-mac-address setting;
    • veth – added default print brief table mode;
    • veth – added dhcp setting that allows to auto-configure IPv4 address, works when VETH is bridged with other interfaces and there is a DHCP server running somewhere on that network;
    • veth – complain immediately when VETH gateway not reachable, more detailed error message when network setup fails;
    • veth – fixed IP address not appearing in the app menu when VETH uses DHCP;
    • veth – fixed VETH interface not getting an IP address in a vlan-aware bridge containing multiple DHCP servers;
    • veth – show only when container package installed;
    • vrf – added read-only property to IPv4/IPv6 addresses, ARP and IPv6 neighbor;
    • vrf – allow setting comment on default “lo” interface;
    • vrrp – do not show “ttl not 255” warning when received VRRP VRID does not match with configured VRID;
    • vrrp – fixed gratuitous ARP being sent after VRRP is disabled (fixes packet forwarding on HW offloaded bridge after VRRP is disabled);
    • w60g – fixed possible memory leak when an interface is disabled;
    • webfig – added a hint for Undo/Redo buttons;
    • webfig – added Apps menu to login;
    • webfig – added capability to check/uncheck entry tree in skin designer;
    • webfig – added Copy capability;
    • webfig – added missing PPP types to Skin Designer;
    • webfig – added TCP State column for connection tracking table;
    • webfig – check if device is still reachable before disconnect on error;
    • webfig – fixed container config memory high input;
    • webfig – fixed issue where routes and PIM table did not load;
    • webfig – fixed issue where Torch stops running;
    • webfig – fixed name and title store in skins;
    • webfig – fixed new item window name when using skins;
    • webfig – improved mikrotik_logo.svg;
    • webfig – improved service stability after deleting a skin;
    • webfig – increase graph width for better scaling;
    • webfig – increase maximum number size in forms;
    • webfig – make close button as a button instead of link;
    • webfig – make combobox accessible to screen readers;
    • webfig – remember last user in login page;
    • webfig – turn off auto-capitalize and auto-correct for on-screen keyboards;
    • wifi – added “CAP” information field on interfaces view;
    • wifi – added CAPsMAN forwarding support (datapath.traffic-processing=on-capsman);
    • wifi – added configuration parameters relevant to the upcoming WiFi 7 products;
    • wifi – enable configuration of “3gpp-info-raw” and “realms-raw” interworking parameters;
    • wifi – fixed issue when trying to use interface as bonding slave;
    • wifi – fixed multi-passphrase usage in combination with access-list;
    • wifi – fixed possible duplicate values for WPA3 authentication types in scan results;
    • wifi – fixed possible memory leak when failing to start AP on chosen channel;
    • wifi – fixed some CAPsMAN settings to be optional;
    • wifi – improved formatting of FT request action frames;
    • wifi – improved interface stability when encountering authentication failures;
    • wifi – improved stability when capturing data at high rates with wifi sniffer;
    • wifi – increased accounting interval, maximum client entry count for 2.4GHz probe response delay feature;
    • wifi – rename ft-wpa2-eap authentication type to “ft-eap”;
    • wifi – split access-list time property in days and time;
    • wifi-mediatek – added Superchannel regulatory profile;
    • wifi-qcom – added Unsolicited BSS Transition Management Request support;
    • wifi-qcom – improved default RTS/CTS policy for CPE station radios;
    • wifi-qcom – multicast-enhance will no longer apply for station mode configured devices;
    • wifi,wireless – include “Event-Timestamp” in RADIUS accounting messages;
    • winbox – added “Last Status” and “Last Address” fields in “Tools/Email” menu;
    • winbox – added file selector for BTH files;
    • winbox – added Forwarding Table in “MPLS” menu;
    • winbox – added missing “SM-DP+ Oid” LTE eSIM provisioning field;
    • winbox – added Sessions tab in “Routing/RPKI” menu;
    • winbox – added support for new settings and fixed several existing ones;
    • winbox – Bandwidth test, Speed test, Ping, Traceroute tools use RouterOS DNS service to resolve domain names;
    • winbox – fixed “Too many entries” not showing in WinBox v4;
    • winbox – fixed Disk iscsi/smb configuration;
    • winbox – fixed Disk NVMe-TCP configuration;
    • winbox – fixed Dude/Tools appearance after Apply action;
    • winbox – fixed graphs in some forms with big numbers;
    • winbox – fixed Keepalive Time format in “Routing/BGP” menus;
    • winbox – fixed Preshared Key “auto” and “none” options for WireGuard Peer;
    • winbox – fixed switch QoS monitor for mirror properties;
    • winbox – hide certificate “Issuer” field for certificate template;
    • winbox – hide IPv6 addresses for IP neighbors that no longer have them;
    • winbox – make multiple address fields required;
    • winbox – make separate inputs for WiFi Interworking “Authentication Types” and “Connection Capabilities” fields;
    • winbox – make VETH gateway fields not required;
    • winbox – move VRF from Ethernet to generic Interface table;
    • winbox – removed “Add” for dynamic DNS servers;
    • winbox – reorder BGP and OSPF tabs in logical order;
    • winbox – restore route max object 10000 limit;
    • winbox – show “Trusted” field for certificate template;
    • winbox – show warnings in “Routing/BGP” menus;
    • winbox – show warnings in Disk menu;
    • winbox – updated and shortened window titles (e.g. Address List -> Addresses);
    • wireguard – added VRF option (CLI only);
    • wireguard – allow to add AllowedIPs configuration for client configuration template;
    • wireless – added last-ip parameter for the CAPSMAN registration-table tab;
    • wireless – improved system stability when stopping scan process;
    • www – added option to disable individual web services in /ip/service/webserver and IP>Services>Web Server;
    • www – handle escaped characters in resource IDs and names for REST API requests;
    • www – process REST API requests only after user authentication is completed;
    • www – removed ability to publish directories via “/files” www service;
    https://forum.mikrotik.com/t/v7-21-stable-is-released/267773
