Moved: DSL-AC750 CRC’s Despite using MediaTek, it reduces the yoyo effect in games as much as possible. Even though I used the Zyxel b10b 3312 modem in bridge mode, it was not efficient…
› UKTH forums › Wireless Routers & Modems › ASUS & Wireless › Moved: DSL-AC750 CRC’s Despite using MediaTek, it reduces the yoyo effect in games as much as possible. Even though I used the Zyxel b10b 3312 modem in bridge mode, it was not efficient...
Viewing 15 posts - 1 through 15 (of 36 total)
  • #13935
    Avatarosman
    • Replies 52
    Despite using MediaTek, it reduces the yoyo effect in games as much as possible. Even though I used the Zyxel b10b 3312 modem in bridge mode, it was not efficient on my line even though Broadcom had it. Apart from these settings, I could not find any settings that can prevent CRCs. I don’t know as others are not effective because I tried many variations. My line starts to give CRC errors such as 18:00, which starts in the evening, and calms down around 23:00 at night as the intensity decreases. At the same time, the dB value also decreases during this process. As long as the company I buy from the internet gives the promised speeds, I do not accept CRCs as a problem, and I am looking for solutions for myself.
    Fix: Doesn’t recognize CRCs as problems
    Avatarosman
    • Replies 52
    I marked the wrong thing
    • Replies 8,743
    Can  you screen dump and show CRC errors page ?
    Did the Zyxel b10b 3312  give you less synch speed ?
    #13951
    Avatarosman
    • Replies 52
    I hope I didn’t misunderstand G.INP Stability Adjustment setting made the line more stable and less CRC error.
    Avatarosman
    • Replies 52
    Zyxel modem can be thought to provide a healthier connection, but when it comes to online games, the difference increases greatly asus. There is also a situation like this. There is a firmware restriction on the modem I bought from the company where I bought the internet line. A restricted version that does not allow firmware modification. I generally don’t have the speed problem. I can get the speeds they promised on both modems.
    #13956
    • Replies 8,743
    Good to know the Zyxel modem has restriction.
    Yes, lots of CRC’s and G.inp should help with Reducing CRC’s
    Is the router near any electrical equipment (speaker) or something that is turned  on @18:00 ?
    #13957
    Avatarosman
    • Replies 52
    It only has my computer monitor with it.
    #13958
    Avatarosman
    • Replies 52
    I use headphones and it starts at the same time almost every day. There is no change in the layout in my house (washing machine, oven, etc.) The VDSL line was put into service this year, so only the panel was changed. The line dispersed in the neighborhood consists of a 15-year-old copper cable that I remember. Can overloading this copper cable network cause CRC errors? I’m sorry it’s dark, just wanted you to see. The other picture is one I found online, but they use the same small distribution board.
    #13962
    • Replies 8,743
    Can u provide a picture of router and what is nearby ?
    #13963
    Avatarosman
    • Replies 52
    Red cable of my headphones
    #13965
    Visit your neighbours and have a look at their lines before and after 18pm.
    I think they all will use their internet much more in the evening and so let go down all lines a bit and causing more errors.
    #13967
    • Replies 8,743
    Thank you for picture, I assume you PC / Monitor is using same power sockets as the Router / Modem, do you have a laptop / tablet?
    If possible remove or turn off PC / Monitor everything else (not router) in that area and see if CRC,s increase (check CRC’s with Laptop / tablet) for 24 hours ?
    #13972
    Avatarosman
    • Replies 52
    I did what you wanted me to do before. There has been no change. You asked when I first joined the forum. then i tried. You gave this link. https://support.zen.co.uk/kb/Knowledgebase/Broadband-Understanding-REIN-and-SHINE I didn’t get a chance to try it because I couldn’t find such radio. I’ve found radios that only work on the FM band. I’m still looking.
    #13973
    • Replies 8,743
    [quote quote=13972]I did what you wanted me to do before. There has been no change. You asked when I first joined the forum. then i tried. You gave this link. https://support.zen.co.uk/kb/Knowledgebase/Broadband-Understanding-REIN-and-SHINE I didn’t get a chance to try it because I couldn’t find such radio. I’ve found radios that only work on the FM band. I’m still looking.[/quote]
    Did I ask previously for you to unplug your PC / Monitor (electrical equipment) from same area as Router. not just move them ?
    This is only way to see if CRC’s from nearby electrical equipment is the fault
    #13974
    Avatarosman
    • Replies 52
    Well, I will check it over the phone by just connecting the modem as you want :) But the problem is that CRCs occur at certain times. It’s pretty normal in the morning. The hours when it increases are the hours I mentioned. On the Zyxel B10B 3312 modem, the yo-yo effect in these games becomes evident in the evening hours.
