Moved: DSL-AC750 CRC’s Despite using MediaTek, it reduces the yoyo effect in games as much as possible. Even though I used the Zyxel b10b 3312 modem in bridge mode, it was not efficient…
› UKTH forums › Wireless Routers & Modems › ASUS & Wireless › Moved: DSL-AC750 CRC’s Despite using MediaTek, it reduces the yoyo effect in games as much as possible. Even though I used the Zyxel b10b 3312 modem in bridge mode, it was not efficient...
Viewing 6 posts - 31 through 36 (of 36 total)
  • #14025
    Avatarosman
    • Replies 52
    [quote quote=14021]New Firmware so maybe worth trying <noscript></noscript>https://www.asuswebstorage.com/navigate/a/#/s/EEC625C71D7A4859A30D12858B7F0193Y[/quote]
    I will try
    #14026
    Avatarosman
    • Replies 52
    I can’t download
    Correction: I downloaded
    • Replies 8,743
    [quote quote=14024]Thanks to you, I was able to drastically reduce the CRCs. I was unaware of these settings, thanks to the forum, I was able to fix it. Thank you [/quote]
    #14695
    osman hocam 946 ile crc hataları düzel di mi?
    #14751
    Avatarosman
    • Replies 52
    I recommend that you write in English. So that others can help. The condition of the internet line is important. No firmware or dsl settings became useless because the SNR value decreased over time on my line. For these reasons, I use the modem of the company I am connected to in bridge mode and I use Asus as a router. There is a new modem in our country, but the price is high, ax82u, I am trying to buy this modem now.
    #14752
    yes, that modem is unfortunately too expensive for Turkey conditions. I bought a new asus dsl51, I think it will work for a while. My only problem is that when I make a setting, it takes at least 5 minutes to reconnect. When you turn the modem off and on, it connects immediately.
