PureVPN setup on DS- AC88U Does anyone have PureVPN setup on the the DSL-AC88U? I am on debug build591 and having difficulties setting this up.  Any help?
UKTH forums 🛜 Wireless Routers & Modems ASUS & Wireless PureVPN setup on DS- AC88U Does anyone have PureVPN setup on the the DSL-AC88U? I am on debug build591 and having difficulties setting this up.  Any help?
Viewing 15 posts - 1 through 15 (of 15 total)
  • #4678
    • Replies 617
    • Replies 8,458
    forum member @Mharv had similar problems with purevpn and DSL-AC88U and could not get it to work
    best to send feedback form and see if ASUS have suitable beta firmware with fix ?
    #4693
    • Replies 617
    I think my issue is regardless the VPN provider.
    In ‘Import .ovpn file’,  when I click ‘choose file’ and select a OVPN file from the provider nothing happens.
    I have sent feedback to Asus.  Not holding my breath to receive a response.
    • Replies 8,458
    I think my issue is regardless the VPN provider. In ‘Import .ovpn file’, when I click ‘choose file’ and select a OVPN file from the provider nothing happens. I have sent feedback to Asus. Not holding my breath to receive a response.
    I am running express VPN via my Netgear XR500 so may swap them over for the DSL-AC88U and see if I have the same issues
    Who’s your VPN with ?
    #4696
    • Replies 617
    I am testing PrivateVPN to see if they are any good.
    • Replies 8,458
    Have you tried any other VPN Providers and if so did they work ?
    #4699
    • Replies 617
    I have tried PureVPN and PrivateVPN.  Both with same issue.
    • Replies 8,458
    That is good news with regards that both do not work, was that with OPENVPN/L2TP ?
    Once I understand which Protocol you had issues with I will drop ASUS an email and try to dig a little deeper, can you screen dump your VPN settings so I can show them also, (hide account details) ;-)
    #4701
    • Replies 617
    It’s using the OpenVPN method and the following guide:
    https://privatevpn.com/support/getting-started/routers/asus-rt-models/openvpn
    • Replies 8,458
    It’s using the OpenVPN method and the following guide: https://privatevpn.com/support/getting-started/routers/asus-rt-models/openvpn
    Process is correct so should work, I assume you are also using the modem inbuilt into DSL-AC88U ?
    #4704
    • Replies 617
    Yes I am using the modem on the DSL-AC88U with wireless turned off.  I have Google Mesh handling the Wi-Fi.
    • Replies 1,002
    you could try it with its own WiFi (only for testing), wouldnt wonder at this working.
    • Replies 8,458
    I will chat with ASUS and see if they are able to advise ;-)
    #4709
    • Replies 8,458
    As an update, I tried to load my ExpressVPN settings upon my DSL-AC88U and can confirm that I could mot establish a VPN, my ExpressVPN settings work on both my RT-AC86U (running ASUSWRT-Merlin) and my Netgear XR500
    Looking at Logs it shows the following –
    Oct  6 12:21:10 DSL-AC88U daemon.err openvpn[7528]: Options error: Unrecognized option or missing parameter(s) in /data/openvpn/client/client.ovpn:5: remote (2.3.2)
    SO will chat with ASUS and see what they say
    #4728
    • Replies 8,458
    @dodgydrains I spoke with ASUS and they acknowledge there are VPN issues with the DSL-AC88U.
    I also asked if fix would be introduced in next firmware release and at the moment, it is unknown as work is ongoing
