› UKTH forums › 🛜 Wireless Routers & Modems › ISP Kit/Other Stuff etc. › ZISA G100 g.fast cpe for BT ultrafast G.fast modem ZISA G100 g.fast cpe for BT ultrafast G.fast modem Setup Guide: The instructions are very similar to how you configure the unlocked BT VDSL modems. Go to “Advanced Setup, WAN...
- This topic has 0 replies, 1 voice, and was last updated 6 years, 10 months ago by
- December 11, 2019 at 9:47 pm #5381
Setup Guide:
The instructions are very similar to how you configure the unlocked BT VDSL modems. Go to “Advanced Setup, WAN Service”. Remove anything already there and Add a new entry as follows:
Default Password should be Admin > admin (but not checked)
Interface: ptm0
WAN service type: Bridging
Service description: br_0_1_1.101
802.1P Priority: 0
802.1Q VLAN ID: 101
VLAN TPID: Don’t select anythingGo through the other settings and get rid of anything not needed:
UPnP: Disable
Quality of Service: Disable (if managed by your router)In “Management, Access Control, Passwords”, change your “admin” password. This is also used by Telnet and SSH services.
In “Management, Access Control, Services Control” untick EVERYTHING in the WAN column and then Save. This is very important otherwise you will be exposing telnet and the other services to the Internet. You should also untick anything from the LAN column you don’t need (except for HTTP, which you need to manage it).
