› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › ASUS DSL-AC68U Help Hi All, First post here, so go easy please. Soon I’ll be receiving aAc68U router. Once it arrives it will be connected to my ISP router (virgin media hub 3)...
- This topic has 33 replies, 3 voices, and was last updated 6 years, 10 months ago by
Grisu.
- November 22, 2019 at 1:59 pm #5079
Hi All,
will it be possible to use ASUS DDNS if the asus router is effectively sitting behind the hub 3 ??
I was planning on giving it a fixed ip address from the hub 3, and the putting that fixed ip into the DMZ on the hub 3. Turning off wifi on hub3 & creating a VPN on asus router + wifi
your thoughts please
November 22, 2019 at 2:20 pm #5081Welcome, The Sky router ( I believe) supports DynDNS, is that not good enough ? or do you need extra functionality of ASUS DDNS ?
From Sky ISP, is your External IP address Fixed as this would be the major issue you would have using the ASUSDNS behind the SKY router (double NAT) and no Fixed External IP address that could change at any time.
November 22, 2019 at 2:41 pm #5083Thanks, but not sure of the relevance of a sky router for my situation.
As I don’t have sky or sky equipment
November 22, 2019 at 5:19 pm #5084no idea why I thought Sky (i’ll get my Jacket) …….
I believe your ISP (virgin media hub 3) has a Modem Mode option as this would cure a lot of issues when using ASUS DDNS ?
https://www.virginmedia.com/help/virgin-media-hub-modem-mode
Out of Interest, why are you getting the DSL-AC68U, as the RT-AC68U would be more suitable as the DSL-AC68U has an inbuilt modem already ?
November 25, 2019 at 12:44 pm #5091Hi
Sorry for the late reply.
I have got the VM hub in modem mode, and the asus router receives its connection from the VM hub, via WAN port (not using the DSL part of asus router)
I have now successfully registered a asuscomm.com DDNS address
But is there anything else I need to configure, as putting the new url I have created does not get me to the router when browsing
November 25, 2019 at 3:44 pm #5092So you have set WAN Port as LAN1 ?
If so and connection is via PPPoE then this sounds like it should work OK?
Sounds like you maybe double Natting, check above to see if you have set-up as a above ?
November 25, 2019 at 3:55 pm #5093November 25, 2019 at 3:59 pm #5094Is your connection to VM Hub via PPPoE ?
Have you seen this ?
https://www.asus.com/support/FAQ/1011725/
November 25, 2019 at 4:02 pm #5095Not sure tbh, where will I find that, the VM is in modem mode only, so cant really check that.
November 25, 2019 at 4:35 pm #5096Not sure tbh, where will I find that, the VM is in modem mode only, so cant really check that.
I meant from ASUS to VM Hub (WAN Settings > Internet Connection on your ASUS unit) WAN connection Type ?
November 25, 2019 at 4:39 pm #5097Wan type = Ethernet WAN
from the dropdown, the only option is Ethernet WAN or USB
November 25, 2019 at 5:17 pm #5098November 25, 2019 at 6:52 pm #5099SSH WAN access enabled on Asus and using strong user/password?
In below link is UI of DSL-AC68U, under PVC settings is the option for PPPoE ? do you have similar ? If not can you screen dump what you do have ?
Alas do not have easy access to DSL-AC68U so am relying on my memory
November 25, 2019 at 7:05 pm #5101Similar,
But not using DSL
So I have wan port set to ethernet
Only other option is usb
Will send a screenshot later
November 25, 2019 at 9:21 pm #5103I meant this under Admin to open SSH access from WAN/internet: https://www.asus.com/support/FAQ/1000926/
But its somehow insecure, better to use VPN to connect to your intranet from abroad.
