Viewing 15 posts - 736 through 750 (of 1,421 total)
  • #21608
    • Replies 634
    [quote quote=21607]
    Feedback sent. Reverted back to the offline beta 388.21099 you shared with me. I will be WFH next week and will need a stable connection.
    So ASUS have comeback after looking at your feedback log and have confirmed that with FW9.0.0.4_FW21493 you did have a wifi connection problem, but they cannot see any indication as to why in the logs etc. ASUS ask if you had the same issue with FW9.0.0.4_FW21101 beta firmware?[/quote]
    I do not recall having this problem with beta 21101.  I can confirm that I did not have the problem with the offline beta 21099 you shared.
    #21609
    [quote quote=21608]I do not recall having this problem with beta 21101.  I can confirm that I did not have the problem with the offline beta 21099 you shared.[/quote]
    Thanks, I will let ASUS know
    #21617
    robgbcrobgbc
    • Replies 41
    Hi All,
    Newly arrived from SNB.
    9.0.0.4.388_21493 is stable for me after 48 hours, although the router did crash and automatically recover Saturday afternoon.
    19 devices connected with a mix of Windows computers, Android & IOS phones and IoT. Free ram is currently 185MB and tends to hover around 60-65% utilization.
    No issue with wireless backhaul, 50hr up-time, setup as AX only, WPA3, 80 Mhz connection
    Cheers,
    Rob
    #21619
    [quote quote=21617]Newly arrived from SNB. 9.0.0.4.388_21493 is stable for me after 48 hours, although the router did crash and automatically recover Saturday afternoon.[/quote]
    Welcome and thank you for the feedback, it is interesting that XT8 beta firmware RT-AX95Q_9.0.0.4_388_21493-g12b5b2a_puresqubi.w has been downloaded 27 times (at least) and only a couple of issues reported.
    Keep is updated if you could
    #21621
    TomThumbTomThumb
    • Replies 31
    On beta fw 9.0.0.4.388_21493
    I’m still having the same issue with the router gui locking up after trying to access it’s web history,
    with an uptime of circa 36Hrs (1 to 2 days I normally see errors) but this time free ram is just over 100MB, definitely an improvement in ‘reported’ memory with 21493 fw
    still seems to be a max data entry limit causing errors for me.
    I had recently opened a ticket with Asus Re: my web history, but put that on hold while I took the recent beta’s for a test drive,
    so for me, I’m gonna rollback to a clean install of the general release 3.0.0.4.388.21099 fw, before I continue with my open ticket with Asus.
    Tom…
    Router gui logs from lockup, HTTPD again!
    Nov 8 12:46:21 wlceventd: wlceventd_proc_event(511): wl2.4: Disassoc 92:00:22:4E:04:B4, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
    Nov 8 12:49:13 HTTPD: waitting 10 minitues and restart
    Nov 8 12:49:13 rc_service: httpd 1585:notify_rc restart_httpd
    Nov 8 12:49:13 ZenWiFi_XT8: start httpd:80
    Nov 8 12:49:13 httpd: Save SSL certificate…80
    Nov 8 12:49:13 httpd: mssl_cert_key_match : PASS
    Nov 8 12:49:13 httpd: Succeed to init SSL certificate…80
    Nov 8 12:49:34 acsd: eth4: selected_chspec is 1008 (8)
    Nov 8 12:49:34 acsd: eth4: Adjusted channel spec: 0x1008 (8)
    #21622
    Interesting regarding ‘HTTPD: waiting ‘ are any USB drives in use ?
    #21623
    TomThumbTomThumb
    • Replies 31
    [quote quote=21622]Interesting regarding ‘HTTPD: waiting ‘ are any USB drives in use ?[/quote]
    No usb connected, never had the need,
    With the general release fw, web history seems populate correctly, then no new data entries after 1 or 2 day’s of uptime, but trying to access web history on the beta’s lock the gui up inside a similar timeframe.
    TM systems don’t seem to be 100% in the recent beta’s for me, but don’t know if that’s by design or omission.
    Tom…
    #21626
    Understood, before you roll back, can you send a feedback and mention in comments box ‘UK Sentinel’ and describe issue, at least they will have a point of reference .
    #21627
    • Replies 634
    [quote quote=21623]
    No usb connected, never had the need, With the general release fw, web history seems populate correctly, then no new data entries after 1 or 2 day’s of uptime, but trying to access web history on the beta’s lock the gui up inside a similar timeframe. TM systems don’t seem to be 100% in the recent beta’s for me, but don’t know if that’s by design or omission. Tom…[/quote]
    Might be worth testing the offline 21099 beta that UK Sentinel shared with me?
    #21628
    TomThumbTomThumb
    • Replies 31
    [quote quote=21626]Understood, before you roll back, can you send a feedback and mention in comments box ‘UK Sentinel’ and describe issue, at least they will have a point of reference .
    <noscript></noscript>[/quote]
    Will do, I did fire the same few lines of the log back to Asus support against my open ticket, marked up for info only & outlined the issue along with the beta version.
    Then I would open full communication once back on the general stable release 21099.
    Tom…[quote quote=21627]
    Might be worth testing the offline 21099 beta that UK Sentinel shared with me?[/quote]
    Can you confirm the fw dodgy, as 3.0.0.4.388.21099 is the last stable general release!
    Tom…
    #21629
    I would not worry about the 21099 offline beta, will cause more confusion 😉
    #21630
    TomThumbTomThumb
    • Replies 31
    [quote quote=21629]I would not worry about the 21099 offline beta, will cause more confusion 😉[/quote]
    No worries & feedback sent,
    altho with my typing skills being slower than slow, the 30 min auto logout did cause me to start afresh after it kicked me out,
    While working twice as hard negates the real reason of having to provide feedback twice🙈
    the former always sounds better 🤭
    Tom…
    #21649
    robgbcrobgbc
    • Replies 41
    [quote quote=21617]Hi All, Newly arrived from SNB. 9.0.0.4.388_21493 is stable for me after 48 hours, although the router did crash and automatically recover Saturday afternoon. 19 devices connected with a mix of Windows computers, Android & IOS phones and IoT. Free ram is currently 185MB and tends to hover around 60-65% utilization. No issue with wireless backhaul, 50hr up-time, setup as AX only, WPA3, 80 Mhz connection Cheers, Rob[/quote]
    Now at 94+ hours up-time, 175MB free ram, and all good with wireless backhaul.
    Wireless WAN to LAN speedtest off the node on a 1000x100mbps connection is around 800×100
    #21652
    [quote quote=21649]Now at 94+ hours up-time, 175MB free ram, and all good with wireless backhaul.[/quote]
    #21654
    AvatarNicky
    • Replies 58
    That sounds promising. Are you getting any 2.4 GHz disconnect issues?
