Viewing 15 posts - 796 through 810 (of 1,421 total)
  • #21813
    AvatarNicky
    • Replies 58
    Not such a good day today. The router done a random reboot at 15:11 (GMT) and then wouldn’t connect to all wireless devices, so I had to power cycle the router.  All seems ok for the moment.
    I’ve sent to logs to ASUS via the feedback tab.
    The system setup is: 2x ZenWiFi XT8 (1x main router, 1x node) Firmware Version:3.0.0.4.388_21617 + 2x ZenWiFi Mini AX1800 (2x nodes) Firmware Version 3.0.0.4.386_49599 with hardwire Backhaul to all nodes.
    #21814
    [quote quote=21813]I’ve sent to logs to ASUS via the feedback tab.[/quote]
    Hopefully just a blip
    #21815
    lifeisfun
    • Replies 11
    [quote quote=21812]I will see what ASUS say, I am sure it is nothing to worry about and more annoying keep seeing that repetitive log message and would be interesting if others are seeing this also. But as you say, RMerlin is probable correct and relates to NAT accelerator and is meaningless to us users, but no harm in checking [/quote]
    That’s great! Thanks!
    I was surprised that no one else chimed in experiencing this.
    There is couple reports about it from last year but no real  answers.
    https://www.snbforums.com/threads/asus-xt8-kernel-error-after-running-newest-beta-xt8-9-0-1-4-386_46197_gfc5aa34_nodpi-for-1-week.75946/
    #21825
    • Replies 634
    [quote quote=21815]
    That’s great! Thanks! I was surprised that no one else chimed in experiencing this. There is couple reports about it from last year but no real answers. https://www.snbforums.com/threads/asus-xt8-kernel-error-after-running-newest-beta-xt8-9-0-1-4-386_46197_gfc5aa34_nodpi-for-1-week.75946/[/quote]
    I do not get this continuously, which is why I haven’t taken notice at all.  Twice in the log in 2 hours (again no idea what it means though):
    Nov 24 20:38:22 kernel: ^[[0;33;41m[ERROR archer] archer_mcast_activate,577: ADD_PORT: WLAN SSID has already been added: egress_port 7, current 0x0002, new 0x0002^[[0m
    Nov 24 20:47:01 kernel: ^[[0;33;41m[ERROR archer] archer_mcast_activate,577: ADD_PORT: WLAN SSID has already been added: egress_port 7, current 0x0002, new 0x0002^[[0m
    #21826
    lifeisfun
    • Replies 11
    [quote quote=21825]
    I do not get this continuously, which is why I haven’t taken notice at all. Twice in the log in 2 hours (again no idea what it means though): Nov 24 20:38:22 kernel: ^[[0;33;41m[ERROR archer] archer_mcast_activate,577: ADD_PORT: WLAN SSID has already been added: egress_port 7, current 0x0002, new 0x0002^[[0m Nov 24 20:47:01 kernel: ^[[0;33;41m[ERROR archer] archer_mcast_activate,577: ADD_PORT: WLAN SSID has already been added: egress_port 7, current 0x0002, new 0x0002^[[0m[/quote]
    Thanks for posting this!
    There is periods where it calms down on my router as well but then it goes nutz
    Can’t wait to se what ASUS techs explanation is.
    #21838
    • Replies 634
    [quote quote=21774]
    Happy to test. Thanks. What is different between the offline and the online 21617 available here?
    After I spoke with ASUS, the new Offline seems pointless, (older revision number and less improvements) and ASUS agreed[/quote]
    Are you still able to share that new offline beta for testing?
    The new release is proving to be very problematic for me with wireless backhaul connection issues once a day.
    #21840
    I am out tonight but just checked the link ASUS sent myself and it is no longer valid for that particular firmware.
    Sometimes to go forward  you have to go back 😉
    #21841
    • Replies 634
    [quote quote=21840]I am out tonight but just checked the link ASUS sent myself and it is no longer valid for that particular firmware. Sometimes to go forward you have to go back 😉[/quote]
    Thanks, if it the link is gone I will revert to the last offline beta you shared.  Come on ASUS, get your act together……
    #21842
    • Replies 634
    Decided to test gnuton 388.1 alpha 1, cannot be any worse than official 21617…..
    https://github.com/gnuton/asuswrt-merlin.ng/releases/download/388.1_0-gnuton0_alpha1/RT-AX95Q_388.1_0-gnuton0_alpha1_puresqubi.w
    #21844
    robgbcrobgbc
    • Replies 41
    3.0.0.4.388_21617 from Asus XT8 site
    I’m sitting at 72 hours of up-time, 173MB free ram and no wireless backhaul disconnects.
    I’ve attached a screenshot of my backhaul setup. The only “controversial” setting may be channel bandwidth @20/40/80, but I’ve found since owning the XT8 that if you give it the opportunity to fall back to 20/40 if needed, it’ll never drop off 5G, that being said I’ve never actually noticed the backhaul drop below 80Mhz. When I had it locked to 80Mhz, it did fallback to 2.4 a few times on older fw.
    The router and node connections generally speed test above 700mbps on my 1000×100 connection.
    Edit: attached current router and node speedtest results
    #21851
    [quote quote=21844]I’ve attached a screenshot of my backhaul setup. The only “controversial” setting may be channel bandwidth @20/40/80, but I’ve found since owning the XT8 that if you give it the opportunity to fall back to 20/40 if needed, it’ll never drop off 5G, that being said I’ve never actually noticed the backhaul drop below 80Mhz. When I had it locked to 80Mhz, it did fallback to 2.4 a few times on older fw.[/quote]
    That is very interesting especially the @20/40/80 setting,  thanks you for sharing
    #21852
    [quote quote=21826]Can’t wait to se what ASUS techs explanation is.[/quote]
    I have not had anything back from ASUS as yet, hopefully should have feedback early next week
    #21853
    lifeisfun
    • Replies 11
    [quote quote=21852]
    I have not had anything back from ASUS as yet, hopefully should have feedback early next week<noscript></noscript>[/quote]
    Thank you! :)
    #21854
    AvatarNicky
    • Replies 58
    I’ve had another router crash this evening and when it recovered a number of my 2.4GHz devices refused to connect. I done a power cycle of the router and all the nodes and still they wouldn’t connect, so I regreased back from “3.0.0.4.388_21617 ” to “3.0.0.4.386_49873-g72159cc” and everything came back online?
    Looks like I’ll be sticking with “3.0.0.4.386_49873-g72159cc” until Asus sort things out.
    Just a though, but up until now all the firmware upgrades had been stable, until they added the new VPN and wire guard settings. Could that be the issue?
