- This topic has 1,416 replies, 25 voices, and was last updated 2 months ago by
- November 23, 2022 at 8:50 am #21792
Feedback sent, the wireless backhaul went down again and recovered. I mentioned you in the comments. The uptime did not reset.
Where all your XT8 using 21617 ?
November 23, 2022 at 10:19 am #21793Feedback sent, the wireless backhaul went down again and recovered. I mentioned you in the comments. The uptime did not reset.
Yes, all on latest official 21617
November 23, 2022 at 10:33 am #21794Yes, all on latest official 21617
Great news
November 23, 2022 at 2:28 pm #21796hi all,
Tried 3.0.0.4.388.21617 today, but reverted back to 3.0.0.4.386.49873.
- Several ‘Teams meeting’ dropouts
- Several RDP session dropouts.
reminds me of older firmwares that had the same issue.
so, unfortunately : NOGO for me.
November 23, 2022 at 2:32 pm #21797hi all, Tried 3.0.0.4.388.21617 today, but reverted back to 3.0.0.4.386.49873.
reminds me of older firmwares that had the same issue. so, unfortunately : NOGO for me.
Interesting – I’m also on 21617 and have no issues with Teams. Consistently inconsistent!
November 23, 2022 at 2:37 pm #21798so, unfortunately : NOGO for me.
Totally understandable, is your Adaptive QOS ‘Learn from Home’ still enabled ?
November 23, 2022 at 2:40 pm #21799hi all, Tried 3.0.0.4.388.21617 today, but reverted back to 3.0.0.4.386.49873.
Are you using wired or wireless backhaul?
November 23, 2022 at 2:45 pm #21800wireless backhaul : one base-station, one satelite. (V1 – hardware)
internet connection through company VPN (F5 / big ip edge client)
November 23, 2022 at 4:44 pm #21802November 23, 2022 at 4:56 pm #21803It will be good to see if Comoman is wired or wireless too
Wireless.
November 24, 2022 at 7:41 am #21804After exactly 1 day and 8 hours the wireless backhaul went down and then recovered. These are the logs for the time it happened, not sure if it shows anything, should I send feedback?
ASUS have come back to myself and say they have your feedback and are looking at the logs
November 24, 2022 at 1:33 pm #21807Hi folks, new to the forum …
My 1 year XT8 started to throw this error very often in the log
RMerlin on another forum gave me this explanation:
“Archer is Boradcom`s proprietary NAT accelerator, only they know what any of these cryptic messages mean. Quite often they are just debug output, not actual error conditions.”
https://www.snbforums.com/threads/xt8-kernel-error.81904/
Anyone experienced this?
It repeats over and over …
Nov 24 07:01:02 kernel: ^[[0;33;41m[ERROR archer] archer_mcast_activate,577: ADD_PORT: WLAN SSID has already been added: egress_port 7, current 0x0001, new 0x0001^[[0m
Nov 24 07:06:00 kernel: ^[[0;33;41m[ERROR archer] archer_mcast_activate,577: ADD_PORT: WLAN SSID has already been added: egress_port 7, current 0x0001, new 0x0001^[[0m
Nov 24 07:07:31 wlceventd: wlceventd_proc_event(494): eth4: Deauth_ind xx:xx:xx:xx:xx:E8, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:0
Nov 24 07:07:43 wlceventd: wlceventd_proc_event(530): eth4: Auth xx:xx:xx:xx:xx:E8, status: Successful (0), rssi:0
Nov 24 07:07:43 wlceventd: wlceventd_proc_event(559): eth4: Assoc xx:xx:xx:xx:xx:E8, status: Successful (0), rssi:-58
Nov 24 07:13:19 acsd: acs_build_candidates(731): eth6: number of valid chanspec is 0
Nov 24 07:19:01 kernel: ^[[0;33;41m[ERROR archer] archer_mcast_activate,577: ADD_PORT: WLAN SSID has already been added: egress_port 7, current 0x0001, new 0x0001^[[0m
Nov 24 07:27:10 wlceventd: wlceventd_proc_event(494): eth4: Deauth_ind xx:xx:xx:xx:xx:E8, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:0
Nov 24 07:27:25 acsd: acs_build_candidates(731): eth6: number of valid chanspec is 0
Nov 24 07:41:31 acsd: acs_build_candidates(731): eth6: number of valid chanspec is 0
Nov 24 07:42:47 kernel: ^[[0;33;41m[ERROR archer] archer_mcast_activate,577: ADD_PORT: WLAN SSID has already been added: egress_port 7, current 0x0001, new 0x0001^[[0m
Nov 24 07:45:38 kernel: ^[[0;33;41m[ERROR archer] archer_mcast_activate,577: ADD_PORT: WLAN SSID has already been added: egress_port 7, current 0x0001, new 0x0001^[[0m
Nov 24 07:52:02 kernel: ^[[0;33;41m[ERROR archer] archer_mcast_activate,577: ADD_PORT: WLAN SSID has already been added: egress_port 7, current 0x0001, new 0x0001^[[0m
Nov 24 07:55:37 acsd: acs_build_candidates(731): eth6: number of valid chanspec is 0
Nov 24 08:02:46 kernel: ^[[0;33;41m[ERROR archer] archer_mcast_activate,577: ADD_PORT: WLAN SSID has already been added: egress_port 7, current 0x0001, new 0x0001^[[0m
Nov 24 08:09:19 kernel: ^[[0;33;41m[ERROR archer] archer_mcast_activate,577: ADD_PORT: WLAN SSID has already been added: egress_port 7, current 0x0001, new 0x0001^[[0m
Nov 24 08:09:43 acsd: acs_build_candidates(731): eth6: number of valid chanspec is 0
Nov 24 08:22:34 kernel: ^[[0;33;41m[ERROR archer] archer_mcast_activate,577: ADD_PORT: WLAN SSID has already been added: egress_port 7, current 0x0001, new 0x0001^[[0m
Nov 24 08:23:49 acsd: acs_build_candidates(731): eth6: number of valid chanspec is 0
Nov 24 08:24:21 kernel: ^[[0;33;41m[ERROR archer] archer_mcast_activate,577: ADD_PORT: WLAN SSID has already been added: egress_port 7, current 0x0001, new 0x0001^[[0mYou need to login in order to vote
November 24, 2022 at 2:03 pm #21809I can ask ASUS XT8 team if you wish to see if they may know more ?
is the below the actual log type messages you are interested in knowing more about …
November 24, 2022 at 2:25 pm #21810That would be great!
Yes it is.
Would it be better to send you link to the actual saved log file?
November 24, 2022 at 3:24 pm #21812I will see what ASUS say, I am sure it is nothing to worry about and more annoying keep seeing that repetitive log message and would be interesting if others are seeing this also.
But as you say, RMerlin is probable correct and relates to NAT accelerator and is meaningless to us users, but no harm in checking
