- This topic has 1,420 replies, 25 voices, and was last updated 3 days, 13 hours ago by
robgbc.
March 29, 2023 at 6:43 pm #23502
@dodgydrains is our resident expert on factory resetting the XT8 main router and nodes, hopefully he will see this post and comment
March 29, 2023 at 6:44 pm #23503I always first do a pin reset at the bottom of the XT8 and then hard factory reset like below:
https://www.asus.com/support/FAQ/1046973/#:~:text=Turn%20the%20power%20off.,and%20turn%20the%20router%20on.
I do this on each XT8’s.
Always find that this way it clears everything in terms of settings.
Also, try plugging the XT8 to a different power socket. I had a situation where my extension lead was faulty and caused the XT8 to reboot.
April 1, 2023 at 2:53 am #23527[quote quote=23503]I always first do a pin reset at the bottom of the XT8 and then hard factory reset like below: https://www.asus.com/support/FAQ/1046973/#:~:text=Turn%20the%20power%20off.,and%20turn%20the%20router%20on. I do this on each XT8’s. Always find that this way it clears everything in terms of settings. Also, try plugging the XT8 to a different power socket. I had a situation where my extension lead was faulty and caused the XT8 to reboot.[/quote]
may i ask, so you haven’t had any downtimes or wireless backhaul switching to 2.4ghz ever since updating to this latest update (and doin the factory reset)?
April 1, 2023 at 3:02 am #23528[quote quote=23494]
Just adding that I have a MACID lookup table and 44:a8:fc is showing as “Apple” device of some kind. And in reference to the May 5 date in the log – that is normal when it reboots until it can connect to NTP to get current date/time. I also had my node drop to 2.4 after 33-34 days of uptime, which is still great in my mind. I’ve just decided to schedule a once a week 4am reboot and hopefully things stay as stable as they have been for me. I have my backhaul locked to channel 173 and locked to 160 and GUI shows “Great” for connection strength.[/quote]
am doin this now too, i bought a smart wifi outlet plug, set a sked to turn off the node everyday 4am and turn back on again after 2mins. Small annoyance but hopefully keeps my 5ghz wireless backhaul up and steady daily.
April 1, 2023 at 3:09 am #23529[quote quote=23527]
may i ask, so you haven’t had any downtimes or wireless backhaul switching to 2.4ghz ever since updating to this latest update (and doin the factory reset)?[/quote]
I have had no occasion where my backhaul went to 2.4GHz on FW 22525.
April 1, 2023 at 4:23 am #23530[quote quote=23529]
I have had no occasion where my backhaul went to 2.4GHz on FW 22525.[/quote]
well, that’s really encouraging. I suppose resetting is really the key to this problem. Thanks again.
April 1, 2023 at 4:29 am #23531Reset may resolve your issues, but your setup may be very different to mine.
April 12, 2023 at 8:20 am #23691ASUS ZenWiFi AX XT8 Firmware version 3.0.0.4.388.23012
New features:
-Built-in Surfshark in VPN Fusion allows you to surf the internet anonymously and securely from anywhere by encrypting connections. Please refer to https://asus.click/SurfsharkVPN-iPhone/Android USB auto backup WAN allows you to connect your phone to the router’s USB port and use it as an internet source. Please refer to https://asus.click/AutobackupWAN
-DDNS transfer allows you to transfer your ASUS DDNS hostname from your original router to the new one. Please refer to https://asus.click/ASUSDDNS
-Fixed the AiCloud login issue after unplugging and plugging the HDD into the USB port.
-Modified the USB application option text in dual WAN.
-Allowed WireGuard Server clients to access the Samba server.
-Fixed memory leak issue.
-Enabled the failback function when using the iOS/Android USB backup WAN.Security updates:
-Fixed null pointer dereference vulnerabilities. Thanks to Chengfeng Ye, Prism Research Group – cse hkust contribution.V2 – https://dlcdnets.asus.com/pub/ASUS/wireless/ZenWiFi_XT8/FW_ZENWIFI_XT8_V2_300438823012..zip?model=ASUS%20ZenWiFi%20AX%20(XT8)
April 12, 2023 at 8:45 am #23693April 12, 2023 at 1:42 pm #23698April 12, 2023 at 1:47 pm #23699[quote quote=23698]What the heck… Dirty upgrade done. Let’s see how it goes.[/quote]
Perfect
April 12, 2023 at 2:02 pm #23702I have also updated as soon as I saw it. If it’s as good as 22525 then it’s a winner for me. Only had one small bug with that.
April 12, 2023 at 2:19 pm #23703[quote quote=23702]If it’s as good as 22525 then it’s a winner for me. Only had one small bug with that.[/quote]
What was bug with 22525 ?
April 12, 2023 at 2:27 pm #23704I had to manually set 160MHz on the backhaul on 22525. Once set, it was perfectly stable. When set to Auto, it always defaulted to 80MHz and stayed there.
April 12, 2023 at 3:01 pm #23709 -
