- This topic has 1,420 replies, 25 voices, and was last updated 3 days, 14 hours ago by
robgbc.
March 25, 2023 at 12:07 pm #23406
[quote quote=23403]If the above does not work, then try try disabling the 5Ghz (backhaul) roaming assistant. Do you live near an airport or military establishment as issue maybe radar interference ?[/quote]
will do. Thanks a lot again!
March 27, 2023 at 10:35 am #23445[quote quote=23314]
I also have some background information which may help other ASUS ZenWifi XT8 owners. ASUS ZenWifi XT8 Details
- The ASUS ZenWifi XT8 can support upto 9 wireless AiMesh Nodes
- The ASUS ZenWifi XT8 can support upto a theoretical maximum number of wifi clients.
- 2.4G: 128 wifi clients
- 5G-1: 128 wifi clients
- 5G-2: 64 wifi clients
‘note: this is a theoretical maximum ‘ [/quote]
Are those limits per XT8 system (router plus all nodes) or per XT8 unit?
March 27, 2023 at 12:08 pm #23447March 28, 2023 at 2:17 pm #23465Welp. Hehehe after 4 days, node’s LED light turned yellow again (weak signal). So frustrating.
will try disabling roaming assistant now. Sigh.
March 28, 2023 at 2:46 pm #23467Is there any clues in the General log to suggest what is happening ?
March 28, 2023 at 6:06 pm #23480[quote quote=23467]Is there any clues in the General log to suggest what is happening ?[/quote]
Sorry. Is this the log i am supposed to get?
(log remove by admin – privacy concern)
March 28, 2023 at 6:53 pm #23482Yes, have a look through the log and see if anything is detailed in log when XT8 backhual dropped back to 2.4GHz ?
( I removed the link you provided to the logs – security)
Alas, hopefully you know what time this happened, so this will enable you to pinpoint logs for that time period.
March 29, 2023 at 3:33 pm #23490[quote quote=23482]Yes, have a look through the log and see if anything is detailed in log when XT8 backhual dropped back to 2.4GHz ? ( I removed the link you provided to the logs – security) Alas, hopefully you know what time this happened, so this will enable you to pinpoint logs for that time period.[/quote]
after scrolling thru backwards, was looking for ‘weak signal’ or backhaul and after seeing the first weak and disconnect words, i saw something weird. The words diaconnect was logged at March 29, but the next line at the log says May 5???
Copied and pasted some of the ‘weird logs’ here:
https://mega.nz/file/gV5ySLKb#je995lu0sw0v_UNztWP1AK8AOvsDO56uPQ6ntUmdO4w
March 29, 2023 at 4:47 pm #23492Interesting, what is device [44:a8:fc:de:65:6a] ? and was this event log around the time the Aimesh backhaul dropped to 2.4GHz ?
If disabling roaming assistant for you backhaul doesn’t prevent wireless backhaul from dropping to 2.4GHz, I would suggest you factory reset your AiMesh XT8 routers (all) and rebuild all (factory reset all) your mesh system from scratch
Edit: as per @larryr comments below, could the XT8 router or node be rebooting without your knowledge ?
March 29, 2023 at 5:45 pm #23494[quote quote=23492]Interesting, what is device [44:a8:fc:de:65:6a] ? and was this event log around the time the Aimesh backhaul dropped to 2.4GHz ? If disabling roaming assistant for you backhaul doesn’t prevent wireless backhaul from dropping to 2.4GHz, I would suggest you factory reset your AiMesh XT8 routers (all) and rebuild all (factory reset all) your mesh system from scratch
[/quote]Just adding that I have a MACID lookup table and 44:a8:fc is showing as “Apple” device of some kind. And in reference to the May 5 date in the log – that is normal when it reboots until it can connect to NTP to get current date/time.
I also had my node drop to 2.4 after 33-34 days of uptime, which is still great in my mind. I’ve just decided to schedule a once a week 4am reboot and hopefully things stay as stable as they have been for me. I have my backhaul locked to channel 173 and locked to 160 and GUI shows “Great” for connection strength.
March 29, 2023 at 6:12 pm #23495[quote quote=23494]I also had my node drop to 2.4 after 33-34 days of uptime, which is still great in my mind.[/quote]
Great news
March 29, 2023 at 6:15 pm #23497[quote quote=23492]Interesting, what is device [44:a8:fc:de:65:6a] ? and was this event log around the time the Aimesh backhaul dropped to 2.4GHz ? If disabling roaming assistant for you backhaul doesn’t prevent wireless backhaul from dropping to 2.4GHz, I would suggest you factory reset your AiMesh XT8 routers (all) and rebuild all (factory reset all) your mesh system from scratch
[/quote]it’s an iphone.
I dread the factory settings reset, but if it would cure the backhaul problem, then i will have to try it and rebuild all my settings.
thanks always!You need to login in order to vote
March 29, 2023 at 6:17 pm #23499[quote quote=23497]I dread the factory settings reset, but if it would cure the backhaul problem, then i will have to try it and rebuild all my settings.[/quote]
Alas, every time ASUS release a new firmware, tweaking is usually required, so alas no guarantees
March 29, 2023 at 6:17 pm #23500[quote quote=23495]
Great news
[/quote][quote quote=23494]
Just adding that I have a MACID lookup table and 44:a8:fc is showing as “Apple” device of some kind. And in reference to the May 5 date in the log – that is normal when it reboots until it can connect to NTP to get current date/time. I also had my node drop to 2.4 after 33-34 days of uptime, which is still great in my mind. I’ve just decided to schedule a once a week 4am reboot and hopefully things stay as stable as they have been for me. I have my backhaul locked to channel 173 and locked to 160 and GUI shows “Great” for connection strength.[/quote]
thanks also Larry!
March 29, 2023 at 6:31 pm #23501[quote quote=23499]
[/quote]do i reset to factory settings via the web interface in the : Administration-Restore/Save/Upload Settin-Restore and click on the initialize all settings?
or do i reset via button on the router?
