› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › ASUS ZenWiFi ET12 and Pro ET12– Official Thread New ASUS ZenWiFi Pro ET12 Firmware version 3.0.0.4.388.21739 2022/11/28 Version 3.0.0.4.388.21739 1. Supported WireGuard VPN server and client. 2. Supported VPN fusion. It can easily achieve VPN connection to network...
- This topic has 83 replies, 6 voices, and was last updated 5 months, 1 week ago by
- February 4, 2023 at 5:46 pm #22682
The stability is great. Now 82 hours without an issue and 88 devices connected. Is it worthwhile for me to raise this as a separate ethernet backhaul issue with ASUS for release 388.22127?
Great news you have stability with 386 build using ethernet backhaul for your ET12.
By all means feed back these backhaul issues to ASUS, but as you are running the 386 firmware currently, ASUS may not be able to see the issues directly from you feedback logs.
Mention ‘UK Sentinel’ in the comments box and hopefully ASUS will take more notice
February 4, 2023 at 7:32 pm #22683What is the best communication channel to use to get a response please, based on your vast experience? Thanks
Always embrace change and new technology. Never say "I can't do that" instead say "I haven't done that before, but I'll give it a try"
February 4, 2023 at 8:30 pm #22685When you log onto your ASUS ET12, Go to Advanced Settings > Administration > Feedback and add your comments there, using this method will ensure ASUS have access to a copy of your system Logs ( if checkbox is selected) so they at least might see something of relevance even though you have downgraded firmware to a previous release
if you use the same email address as the one you have registered with this forum, I can then speak to ASUS about this next week if needed 👍
February 6, 2023 at 7:27 pm #22703I sent my feedback today to ASUS. I shared the logs except for the Additional WiFi DHD Log as I didn’t want to reboot the system. I mentioned I had been coordinating with UK Sentinel on UKTechHub.com. System still stable after 132 hours. Thanks for your support and advice.
February 6, 2023 at 7:34 pm #22704I sent my feedback today to ASUS. I shared the logs except for the Additional WiFi DHD Log as I didn’t want to reboot the system. I mentioned I had been coordinating with UK Sentinel on UKTechHub.com. System still stable after 132 hours. Thanks for your support and advice.
February 17, 2023 at 7:26 am #22804I sent my feedback today to ASUS. I shared the logs except for the Additional WiFi DHD Log as I didn’t want to reboot the system. I mentioned I had been coordinating with UK Sentinel on UKTechHub.com.
I spoke with ASUS and they have confirmed firmware for the ASUS ZenWiFi Pro ET12 release at the end of February.
ET12 firmware will be release at the end of Feb.
February 17, 2023 at 9:10 am #22805Thanks for the update. I’ll install it and give an update afterwards.
February 17, 2023 at 3:12 pm #22809Thanks for the update. I’ll install it and give an update afterwards
Yes, will be interesting to see if the next firmware fixes your hardwired connections also for a 388 build
March 1, 2023 at 9:03 am #22895No new ET12 firmware yet!
March 1, 2023 at 1:21 pm #22896No new ET12 firmware yet!
I will ask ASUS
March 3, 2023 at 7:52 am #22923So I spoke with ASUS and for the ASUS ZenWiFi Pro ET12, ASUS are now saying around the middle of March for next firmware
It will be released around the middle of March.
March 3, 2023 at 11:22 am #22928Appreciate the update and your great support.
March 16, 2023 at 6:57 am #23027ASUS have kindly informed me that the next firmware release for the ET12 will be postponed 1~2 weeks.
ASUS have kindly given us a sneak preview into what we can expect in the next ET12 firmware release and other ASUS models more generally.
New features in 23′ Q1 are
1. Enhance password protection
2. Surfshark VPN profile
3. DDNS transfer by Router APP
4. iPhone/Android backup WAN. (Not in ET12 since no USB).
March 21, 2023 at 7:13 pm #23280ASUS ZenWiFi Pro ET12 Firmware version 9.0.0.6.102.4856
Version 9.0.0.6.102.4856
Beta Version
49.51 MB
2023/03/21
Be noted: This is an early stage beta, there might be bugs. This version can be downgraded via web GUI only.1. Recap new features of 3.0.0.6.102: Guest network Pro(SDN), VLAN, Auto USB WAN backup, iPhone tethering, Multi-services WAN.
2. Re-defined VLAN, supports Trunk, Access mode with VLAN-only-network.
3. Synchronize Guest network pro (SDN) with VLAN, create/delete new VLAN-only-network will create/delete a new profile in Guest network as well.
4. Port isolation and AP isolation to restrict device access to each other.
5. Re-defined multi-service WAN, disable it by default.
6. Add surfshark VPN in VPN fusion.Please unzip the firmware file first then check the MD5 code.
MD5: fea839edfbcbe1f72e145ab8e02d2ee4You need to login in order to vote
March 21, 2023 at 7:19 pm #23283Great news on a ET12 release, I wonder why ASUS released another beta firmware ?
