ASUS ZenWiFi ET12 and Pro ET12– Official Thread New ASUS ZenWiFi Pro ET12 Firmware version 3.0.0.4.388.21739 2022/11/28 Version 3.0.0.4.388.21739 1. Supported WireGuard VPN server and client. 2. Supported VPN fusion. It can easily achieve VPN connection to network…
UKTH forums 🛜 Wireless Routers & Modems ASUS & Wireless ASUS ZenWiFi ET12 and Pro ET12– Official Thread New ASUS ZenWiFi Pro ET12 Firmware version 3.0.0.4.388.21739 2022/11/28 Version 3.0.0.4.388.21739 1. Supported WireGuard VPN server and client. 2. Supported VPN fusion. It can easily achieve VPN connection to network...
Viewing 15 posts - 31 through 45 (of 84 total)
  • #23569
    Nick HollandNick Holland
    • Replies 36
    Disappointed the new production firmware has not been released yet for the ET12 to replace version 388. I am still running version 386 for ethernet stability reasons, but want to get all the features this system can deliver.
    Has anyone installed the latest beta ASUS ZenWiFi Pro ET12 Firmware version 9.0.0.6.102.4856 and if yes, is it worth installing or is it too buggy? Any idea when the production version will be released?
    Always embrace change and new technology. Never say "I can't do that" instead say "I haven't done that before, but I'll give it a try"
    #23570
    • Replies 8,456
    Issues include web UI wont load and Node connection problems, it is a beta so probable better to avoid
    No idea on formal release but I guess they ‘ASUS’ are struggling with releases currently
    #23571
    • Replies 36
    Thanks again for your help. Seems I will have to be extremely patient and wait for the production version.
    #23572
    • Replies 8,456
    That would be wise – no point loading new ‘buggy’ beta firmware
    #23573
    • Replies 36
    We have enough problems with the production versions!!
    #23574
    • Replies 8,456
    #23804
    • Replies 8,456
    New ASUS ZenWiFi Pro ET12 Firmware version 3.0.0.4.388.23013
    Version 3.0.0.4.388.23013
    Release date: 2023/04/13
    New Features:
    -Built-in Surfshark in VPN Fusion allows you to surf the internet anonymously and securely from anywhere by encrypting connections. Please refer to https://asus.click/SurfsharkVPN
    -DDNS transfer allows you to transfer your ASUS DDNS hostname from your original router to the new one. Please refer to https://asus.click/ASUSDDNS
    -Fixed memory leak issue.
    Security updates:
    -Fixed null pointer dereference vulnerabilities. Thanks to Chengfeng Ye, Prism Research Group – cse hkust contribution.
    https://www.asus.com/networking-iot-servers/whole-home-mesh-wifi-system/zenwifi-wifi-systems/asus-zenwifi-pro-et12/helpdesk_bios/?model2Name=ASUS-ZenWiFi-Pro-ET12
    #23911
    • Replies 36
    I have installed Version 388.23013 and it seems to have fixed the ET12 wired nodes dropping connections showing a solid red LED.
    However, they did not include Guest Network Pro (which I want to use for all my IOT devices) and VLAN. Do you know when this is planned, as these features were mentioned in both of the Beta Versions?
    #23912
    • Replies 8,456
    Great news.
    I will check with ASUS and ask when they might be releasing the ‘Synchronize Guest network pro (SDN) with VLAN’ service which was part of the ASUS ZenWiFi Pro ET12 Firmware version 9.0.0.6.102.4856 beat build.
    #23918
    • Replies 36
    #23920
    • Replies 8,456
    ASUS have come back and said the following …
    Guest Network Pro and VLAN will be in 3.0.0.6.102, not be in 3.0.0.4.388. (9.0.0.x is beta).
    I believe the challenge is ASUS are not 100% sure if 3.0.0.6 will be the next release, as new 3.0.0.4 release could be required due to security or a fault/bug etc.
    But Guest Network Pro and VLAN is planned to be be included in stock firmware for the ET12, at some point
    #23929
    • Replies 36
    Thanks for the info and I appreciate your support for the small ET12 community. I am surprised by the comprehensive coverage of your expertise
    #23939
    • Replies 8,456
    Thank you and happy to help when I can
    #24695
    • Replies 36
    Just a quick update, the ET12’s wired nodes have started dropping connections again (the ET12 as the router is OK) showing a solid red LED, so I re-downgraded the firmware on all three ET12s to release 386.48823. Therefore Version 388.23013 did not fix this issue permanently.
    So it seems I will have to wait for release 3.0.0.6.102 and keep my fingers crossed!
    #24699
    • Replies 8,456
    That is a shame, hopefully release 3.0.0.6.102 when it arrives will be the big fix
Close ✖
Search forums
Advanced forum search
Back to basic search
